First, sorry if you got this questions a dozen times before but I would appreciate your help.
Were best to buy Hubitat if I want the latest version? I typically buy off Amazon but not sure if they carry v1 or v2?
I write my own applications and in my little study it appears HE is similar. True? Any guideline documents?
Is there an IDE like in ST and if not how do you include your own apps into HE?
Is there a recommended coding examples repository?
All my questions are related to writing my own apps, so can you generate Android notifications and send SMS messages?
How is presence sensing handled? I use my Android phone in ST.
Can I schedule events to occur at specific time (like using cron times)?
Kasa tp-link (wifi) is important to me. ST allows this through custom handlers and a management tool in SmartApps. Is it possible to use tp-link devices in HE?
My devices are: Nest stat, several Inovelli switches & plugs (NZW30, NZW97), GE/Jasco Z-Wave Plus On/Off Switch, Zooz power switch & indoor double plug, Aeon Labs Multifunction Siren, Fibaro Flood Sensor, and tp-link devices (HS100, HS105, KP400). Any issues with integration into HE?
I seen the documentation on Nest thermostat but I’m confused. Can I use Nest stat within HE?
Can I create/use virtual switches (on/off and momentary) in HE?
Do I have to remove device from both ST and Alexa before moving it to HE?
