This is a collection of several thermostat drivers from ST, I wanted to be able to support the Hold button on the thermostat. The Generic ZigBee Thermostat driver in Hubitat may eventually support everything that this driver does. Fixes/Improvements welcome!
* Centralite Pearl Thermostat
metadata {
definition (name: "CentraLite Pearl Thermostat", namespace: "hubitat", author: "dagrider") {
capability "Actuator"
capability "Temperature Measurement"
capability "Thermostat"
capability "Configuration"
capability "Refresh"
capability "Sensor"
capability "Polling"
capability "Battery"
// Custom commands
command "raiseHeatLevel"
command "lowerHeatLevel"
command "raiseCoolLevel"
command "lowerCoolLevel"
//command "setTemperature"
command "setThermostatHoldMode"
//command "getPowerSource"
// thermostat capability commands
// setHeatingSetpoint(number)
// setCoolingSetpoint(number)
// off()
// heat()
// emergencyHeat()
// cool()
// setThermostatMode(enum)
// fanOn()
// fanAuto()
// fanCirculate()
// setThermostatFanMode(enum)
// auto()
// thermostat capability attributes
// temperature
// heatingSetpoint
// coolingSetpoint
// thermostatSetpoint
// thermostatMode (auto, emergency heat, heat, off, cool)
// thermostatFanMode (auto, on, circulate)
// thermostatOperatingState (heating, idle, pending cool, vent economizer, cooling, pending heat, fan only)
attribute "thermostatHoldMode", "string"
attribute "powerSource", "string"
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0020,0201,0202,0204,0B05", outClusters: "000A, 0019"
def installed() {
log.debug "installed"
configure()
def updated() {
log.debug "updated"
configure()
def configure() {
log.debug "configure"
def cmds =
"zdo bind 0x${device.deviceNetworkId} 1 1 0x0001 {${device.zigbeeId}} {}", "delay 500",
"zcl global send-me-a-report 0x0001 0x20 0x20 3600 86400 {}", "delay 500", //battery report request
"send 0x${device.deviceNetworkId} 1 1",
"zdo bind 0x${device.deviceNetworkId} 1 1 0x0201 {${device.zigbeeId}} {}", "delay 500",
"zcl global send-me-a-report 0x0201 0x0000 0x29 5 300 {3200}", "delay 500", // report temperature changes over 0.5°C (0x3200 in little endian)
"zcl global send-me-a-report 0x0201 0x0011 0x29 5 300 {3200}", "delay 500", // report cooling setpoint delta: 0.5°C
"zcl global send-me-a-report 0x0201 0x0012 0x29 5 300 {3200}", "delay 500", // report heating setpoint delta: 0.5°C
"zcl global send-me-a-report 0x0201 0x001C 0x30 5 300 {}", "delay 500", // report system mode
"zcl global send-me-a-report 0x0201 0x0029 0x19 5 300 {}", "delay 500", // report running state
"zcl global send-me-a-report 0x0201 0x0023 0x30 5 300 {}", "delay 500", // report hold mode
"zdo bind 0x${device.deviceNetworkId} 1 1 0x0202 {${device.zigbeeId}} {}", "delay 500",
"zcl global send-me-a-report 0x0202 0 0x30 5 300 {}","delay 500", // report fan mode
def refresh() {
log.debug "refresh called"
// 0000 07 power source
// 0201 00 temperature
// 0201 11 cooling setpoint
// 0201 12 heating setpoint
// 0201 1C thermostat mode
// 0201 1E run mode
// 0201 23 hold mode
// 0001 20 battery
// 0202 00 fan mode
def cmds = zigbee.readAttribute(0x0000, 0x0007) +
zigbee.readAttribute(0x0201, 0x0000) +
zigbee.readAttribute(0x0201, 0x0011) +
zigbee.readAttribute(0x0201, 0x0012) +
zigbee.readAttribute(0x0201, 0x001C) +
zigbee.readAttribute(0x0201, 0x001E) +
zigbee.readAttribute(0x0201, 0x0023) +
zigbee.readAttribute(0x0201, 0x0029) +
zigbee.readAttribute(0x0001, 0x0020) +
zigbee.readAttribute(0x0202, 0x0000)
return cmds
def raiseHeatLevel(){
if (isHoldOn()) return
def currentLevel = device.currentValue("heatingSetpoint")
int nextLevel = currentLevel.toInteger() + 1
log.debug "raiseHeatLevel: calling setHeatingSetpoint with ${nextLevel}"
setHeatingSetpoint(nextLevel)
def lowerHeatLevel(){
int nextLevel = currentLevel.toInteger() - 1
log.debug "lowerHeatLevel: calling setHeatingSetpoint with ${nextLevel}"
def raiseCoolLevel(){
def currentLevel = device.currentValue("coolingSetpoint")
log.debug "raiseCoolLevel: calling setCoolingSetpoint with ${nextLevel}"
setCoolingSetpoint(nextLevel)
def lowerCoolLevel(){
log.debug "lowerCoolLevel: calling setCoolingSetpoint with ${nextLevel}"
log.debug "Parse description $description"
def map = [:]
if (description?.startsWith("read attr -")) {
def descMap = zigbee.parseDescriptionAsMap(description)
if (descMap.cluster == "0201" && descMap.attrId == "0000") {
log.debug "TEMPERATURE"
map.name = "temperature"
map.value = getTemperature(descMap.value)
} else if (descMap.cluster == "0201" && descMap.attrId == "0011") {
log.debug "COOLING SETPOINT"
map.name = "coolingSetpoint"
} else if (descMap.cluster == "0201" && descMap.attrId == "0012") {
log.debug "HEATING SETPOINT"
map.name = "heatingSetpoint"
} else if (descMap.cluster == "0201" && descMap.attrId == "001C") {
log.debug "MODE"
map.name = "thermostatMode"
map.value = getModeMap()[descMap.value]
} else if (descMap.cluster == "0202" && descMap.attrId == "0000") {
log.debug "FAN MODE"
map.name = "thermostatFanMode"
map.value = getFanModeMap()[descMap.value]
} else if (descMap.cluster == "0001" && descMap.attrId == "0020") {
log.debug "BATTERY"
map.name = "battery"
map.value = getBatteryLevel(descMap.value)
} else if (descMap.cluster == "0201" && descMap.attrId == "001E") {
log.debug "RUN MODE"
map.name = "thermostatRunMode"
} else if (descMap.cluster == "0201" && descMap.attrId == "0023") {
log.debug "HOLD MODE"
map.name = "thermostatHoldMode"
map.value = getHoldModeMap()[descMap.value]
} else if (descMap.cluster == "0201" && descMap.attrId == "0029") {
log.debug "OPERATING MODE"
map.name = "thermostatOperatingState"
map.value = getThermostatOperatingStateMap()[descMap.value]
} else if (descMap.cluster == "0000" && descMap.attrId == "0007") {
log.debug "POWER SOURCE"
map.name = "powerSource"
map.value = getPowerSource()[descMap.value]
def result = null
if (map) {
result = createEvent(map)
log.debug "Parse returned $map"
return result
def getModeMap() {
"00":"off",
"01":"auto",
"03":"cool",
"04":"heat",
"05":"emergency heat",
"06":"precooling",
"07":"fan only",
"08":"dry",
"09":"sleep"
def modes() {
["off", "cool", "heat", "emergencyHeat"]
def getHoldModeMap() {
"00":"holdOff",
"01":"holdOn",
def getPowerSource() {
"01":"24VAC",
"03":"Battery",
"81":"24VAC"
def getFanModeMap() {
"04":"fanOn",
"05":"fanAuto"
def getThermostatOperatingStateMap() {
/** Bit Number
// 0 Heat State
// 1 Cool State
// 2 Fan State
// 3 Heat 2nd Stage State
// 4 Cool 2nd Stage State
// 5 Fan 2nd Stage State
// 6 Fan 3rd Stage Stage
"0000":"idle",
"0001":"heating",
"0002":"cooling",
"0004":"fan only",
"0005":"heating",
"0006":"cooling",
"0008":"heating",
"0009":"heating",
"000A":"heating",
"000D":"heating",
"0010":"cooling",
"0012":"cooling",
"0014":"cooling",
"0015":"cooling"
def getTemperature(value) {
if (value != null) {
def celsius = Integer.parseInt(value, 16) / 100
if (getTemperatureScale() == "C") {
return celsius
} else {
def fahrenheit = Math.round(celsiusToFahrenheit(celsius))
return fahrenheit
def setThermostatHoldMode() {
log.debug "setThermostatHoldMode"
def currentHoldMode = device.currentState("thermostatHoldMode")?.value
def returnCommand
if (!currentHoldMode) {
log.debug "Unable to determine thermostat hold mode, setting to hold off"
returnCommand = holdOff()
} else {
log.debug "Switching thermostat from current mode: $currentHoldMode"
switch (currentHoldMode) {
case "holdOff":
returnCommand = holdOn()
break
case "holdOn":
break
returnCommand
def setThermostatMode(String value) {
log.debug "setThermostatMode to {$value}"
"$value"()
def setThermostatFanMode(String value) {
log.debug "setThermostatFanMode({$value})"
"$value"()
def setThermostatHoldMode(String value) {
log.debug "setThermostatHoldMode({$value})"
"$value"()
def off() {
log.debug "off"
sendEvent("name":"thermostatMode", "value":"off")
zigbee.writeAttribute(0x0201, 0x1C, 0x30, 0)
def cool() {
log.debug "cool"
sendEvent("name":"thermostatMode", "value":"cool")
zigbee.writeAttribute(0x0201, 0x1C, 0x30, 3)
def heat() {
log.debug "heat"
sendEvent("name":"thermostatMode", "value":"heat")
zigbee.writeAttribute(0x0201, 0x1C, 0x30, 4)
def emergencyHeat() {
log.debug "emergencyHeat"
sendEvent("name":"thermostatMode", "value":"emergencyHeat")
zigbee.writeAttribute(0x0201, 0x1C, 0x30, 5)
def on() {
log.debug "on"
fanOn()
def fanOn() {
log.debug "fanOn"
sendEvent("name":"thermostatFanMode", "value":"fanOn")
zigbee.writeAttribute(0x0202, 0x00, 0x30, 4)
def auto() {
log.debug "auto"
// thermostat doesn't support auto
def fanAuto() {
log.debug "fanAuto"
sendEvent("name":"thermostatFanMode", "value":"fanAuto")
zigbee.writeAttribute(0x0202, 0x00, 0x30, 5)
def holdOn() {
log.debug "holdOn"
sendEvent("name":"thermostatHoldMode", "value":"holdOn")
zigbee.writeAttribute(0x0201, 0x23, 0x30, 1)
def holdOff() {
log.debug "Set Hold Off for thermostat"
sendEvent("name":"thermostatHoldMode", "value":"holdOff")
zigbee.writeAttribute(0x0201, 0x23, 0x30, 0)
// Commment out below if no C-wire since it will kill the batteries.
def poll() {
// log.debug "Executing 'poll'"
// refresh()
private getBatteryLevel(rawValue) {
def intValue = Integer.parseInt(rawValue,16)
def min = 2.1
def max = 3.0
def vBatt = intValue / 10
return ((vBatt - min) / (max - min) * 100) as int
private cvtTemp(value) {
new BigInteger(Math.round(value))
private isHoldOn() {
if (device.currentState("thermostatHoldMode")?.value == "holdOn") return true
return false
def setHeatingSetpoint(degrees) {
log.debug "setHeatingSetpoint to $degrees"
if (degrees != null) {
def temperatureScale = getTemperatureScale()
def degreesInteger = Math.round(degrees)
def maxTemp
def minTemp
if (temperatureScale == "C") {
maxTemp = 44
minTemp = 7
log.debug "Location is in Celsius, maxTemp: $maxTemp, minTemp: $minTemp"
} else {
maxTemp = 86
minTemp = 30
log.debug "Location is in Farenheit, maxTemp: $maxTemp, minTemp: $minTemp"
if (degreesInteger > maxTemp) degreesInteger = maxTemp
if (degreesInteger < minTemp) degreesInteger = minTemp
log.debug "setHeatingSetpoint degrees $degreesInteger $temperatureScale"
def celsius = (temperatureScale == "C") ? degreesInteger : (fahrenheitToCelsius(degreesInteger) as Double).round(2)
zigbee.writeAttribute(0x0201, 0x12, 0x29, cvtTemp(celsius * 100))
def setCoolingSetpoint(degrees) {
log.debug "setCoolingSetpoint to $degrees"
def maxTemp
def minTemp
maxTemp = 44
minTemp = 7
} else {
maxTemp = 86
minTemp = 30
log.debug "setCoolingSetpoint degrees $degreesInteger $temperatureScale"
zigbee.writeAttribute(0x0201, 0x11, 0x29, cvtTemp(celsius * 100))
