Hi all.
I have moes smart touch switches and they work well with zemismart driver.
But led indicator on the panel turn on ( blue led ) when light is on.
I need just the opposite, when lights are off it needs to be on.
It is possible change it with moes hub ( which i don't have ).
Inside the code there is possibility to change it but it does not shown in the device settings.
Thanks,
Please post the device manufacturer and model, there are dozens of different switches branded 'Moes'..
Also, share the link to the zemismart driver you are using, there are many drivers with 'zemismart' name on them too.
Hi @kkossev ,
i hope these pic helps:
code:
- Zemismart ZigBee Wall Switch Multi-Gang
- Device Driver for Hubitat Elevation hub
- Based on Muxa's driver Version 0.2.0, last updated Feb 5, 2020
- Ver. 0.0.1 2019-08-21 Muxa - first version
- Ver. 0.1.0 2020-02-05 Muxa - Driver name "Zemismart ZigBee Wall Switch Multi-Gang"
- Ver. 0.2.1 2022-02-26 kkossev - TuyaBlackMagic for TS0003 _TZ3000_vjhcenzo
- Ver. 0.2.2 2022-02-27 kkossev - TS0004 4-button, logEnable, txtEnable, ping(), intercept cluster: E000 attrId: D001 and D002 exceptions;
- Ver. 0.2.3 2022-03-04 kkossev - powerOnState options
- Ver. 0.2.4 2022-04-16 kkossev - _TZ3000_w58g68s3 Yagusmart 3 gang zigbee switch fingerprint
- Ver. 0.2.5 2022-05-28 kkossev - _TYZB01_Lrjzz1UV Zemismart 3 gang zigbee switch fingerprint; added TS0011 TS0012 TS0013 models and fingerprints; more TS002, TS003, TS004 manufacturers
- Ver. 0.2.6 2022-06-03 kkossev - powerOnState and Debug logs improvements; importUrl; singleThreaded
- Ver. 0.2.7 2022-06-06 kkossev - command '0B' (command response) bug fix; added Tuya Zugbee mini switch TMZ02L (_TZ3000_txpirhfq); bug fix for TS0011 single-gang switches.
- Ver. 0.2.8 2022-07-13 kkossev - added _TZ3000_18ejxno0 and _TZ3000_qewo8dlz fingerprints; added TS0001 wall switches fingerprints; added TS011F 2-gang wall outlets; added switchType configuration
- Ver. 0.2.9 2022-09-29 kkossev - added _TZ3000_hhiodade (ZTS-EU_1gang); added TS0001 _TZ3000_oex7egmt; _TZ3000_b9vanmes; _TZ3000_zmy4lslw
- Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0 - Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
import hubitat.device.HubAction
import hubitat.device.Protocol
import groovy.transform.Field
def version() { "0.2.9" }
def timeStamp() {"2022/09/29 7:47 AM"}
@Field static final Boolean debug = false
metadata {
definition (name: "Zemismart ZigBee Wall Switch Multi-Gang", namespace: "muxa", author: "Muxa", importUrl: "https://raw.githubusercontent.com/kkossev/hubitat-muxa-fork/development/drivers/zemismart-zigbee-multigang-switch.groovy", singleThreaded: true ) {
capability "Initialize"
capability "Actuator"
capability "Configuration"
capability "Refresh"
capability "Switch"
capability "Health Check"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0001", manufacturer:"_TZ3000_npzfdcof", deviceJoinName: "Tuya Zigbee Switch" // https://www.aliexpress.com/item/1005002852788275.html
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0001", manufacturer:"_TZ3000_hktqahrq", deviceJoinName: "Tuya Zigbee Switch"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0001", manufacturer:"_TZ3000_mx3vgyea", deviceJoinName: "Tuya Zigbee Switch"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0001", manufacturer:"_TZ3000_5ng23zjs", deviceJoinName: "Tuya Zigbee Switch"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0001", manufacturer:"_TZ3000_rmjr4ufz", deviceJoinName: "Tuya Zigbee Switch"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0001", manufacturer:"_TZ3000_v7gnj3ad", deviceJoinName: "Tuya Zigbee Switch"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0001", manufacturer:"_TZ3000_qsp2pwtf", deviceJoinName: "Tuya Zigbee Switch"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS000F", manufacturer:"_TZ3000_m9af2l6g", deviceJoinName: "Tuya Zigbee Switch"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0001", manufacturer:"_TZ3000_oex7egmt", deviceJoinName: "Tuya 1 gang Zigbee switch MYQ-KLS01L" //https://expo.tuya.com/product/601097
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005 0006", outClusters:"0019", model:"TS0002", manufacturer:"Zemismart", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,000A,0004,0005,0006", outClusters:"0019", model:"TS0002", manufacturer:"_TZ3000_tas0zemd", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,000A,0004,0005,0006", outClusters:"0019", model:"TS0002", manufacturer:"_TYZB01_tas0zemd", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,000A,0004,0005,0006", outClusters:"0019", model:"TS0002", manufacturer:"_TZ3000_7hp93xpr", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0004,0005,0006", outClusters:"0019", model:"TS0002", manufacturer:"_TZ3000_7hp93xpr", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0004,0005 0006", outClusters:"0019,000A", model:"TS0002", manufacturer:"_TZ3000_vjhyd6ar", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0002", manufacturer:"_TZ3000_tonrapsk", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0002", manufacturer:"_TZ3000_bvrlqyj7", deviceJoinName: "Avatto Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0002", manufacturer:"_TZ3000_atp7xmd9", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0002", manufacturer:"_TZ3000_h34ihclt", deviceJoinName: "Tuya Zigbee Switch Multi-Gang" //// check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0002", manufacturer:"_TYZB01_wmak4qjy", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006,E000,E001", outClusters:"0019,000A", model:"TS0002", manufacturer:"_TZ3000_qn8qvk9y", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0002", manufacturer:"_TZ3000_b9vanmes", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,0702,0B04,E000,E001,0000", outClusters:"0019,000A", model:"TS0002", manufacturer:"_TZ3000_zmy4lslw", deviceJoinName: "Tuya Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,000A,0004,0005,0006", outClusters:"0019", model:"TS0003", manufacturer:"_TYZB01_pdevogdj", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,000A,0004,0005,0006", outClusters:"0019", model:"TS0003", manufacturer:"_TZ3000_pdevogdj", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0003", manufacturer:"_TZ3000_odzoiovu", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0003", manufacturer:"_TZ3000_vsasbzkf", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0003", manufacturer:"_TZ3000_34zbimxh", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0004,0005,0006", outClusters:"0019", model:"TS0003", manufacturer:"_TZ3000_wqfdvxen", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0004,0005,0006", outClusters:"0019", model:"TS0003", manufacturer:"_TZ3000_c0wbnbbf", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0004,0005,0006", outClusters:"0019", model:"TS0003", manufacturer:"_TZ3000_c0wbnbbf", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001", outClusters:"0019,000A", model:"TS0003", manufacturer:"_TZ3000_tbfw3xj0", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0004", manufacturer:"_TZ3000_ltt60asa", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0004", manufacturer:"_TZ3000_excgg5kb", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0004", manufacturer:"_TZ3000_a37eix1s", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,000A,0004,0005,0006", outClusters:"0019", model:"TS0004", manufacturer:"_TZ3000_go9rahj5", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001", outClusters:"0019", model:"TS0004", manufacturer:"_TZ3000_aqgofyol", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0004", manufacturer:"_TZ3000_excgg5kb" // 4-relays module
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0004", manufacturer:"_TZ3000_w58g68s3" // Yagusmart 3 gang zigbee switch
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0011", manufacturer:"_TZ3000_ybaprszv", deviceJoinName: "Zemismart Zigbee Switch No Neutral"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0011", manufacturer:"_TZ3000_txpirhfq", deviceJoinName: "Tuya Zigbee Mini Switch TMZ02L"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0011", manufacturer:"_TZ3000_hhiodade", deviceJoinName: "Moes ZTS-EU_1gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0001,0007,0000,0003,0004,0005,0006,E000,E001,0002", outClusters:"0019,000A", model:"TS0012", manufacturer:"_TZ3000_k008kbls", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0012", manufacturer:"_TZ3000_uz5xzdgy", deviceJoinName: "Zemismart Zigbee Switch No Neutral"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0004,0005,0006", outClusters:"0019,000A", model:"TS0012", manufacturer:"_TZ3000_fvh3pjaz", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0004,0005,0006,EF00", outClusters:"0019,000A", model:"TS0012", manufacturer:"_TZ3000_lupfd8zu", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001", outClusters:"0019,000A", model:"TS0012", manufacturer:"_TZ3000_jl7qyupf", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006,E000,E001", outClusters:"0019,000A", model:"TS0012", manufacturer:"_TZ3000_18ejxno0", deviceJoinName: "Tuya Zigbee Switch Multi-Gang" // @dingyang.yee
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,E000,E001,0000", outClusters:"0019,000A", model:"TS0012", manufacturer:"_TZ3000_18ejxno0", deviceJoinName: "Tuya Zigbee Switch Multi-Gang" // check! ^^^^
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0006", outClusters:"0019", model:"TS0013", manufacturer:"_TYZB01_Lrjzz1UV", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0006", outClusters:"0019", model:"TS0013", manufacturer:"_TZ3000_bvrlqyj7", deviceJoinName: "Avatto Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0006", outClusters:"0019", model:"TS0013", manufacturer:"_TZ3000_wu0shw0i", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0006", outClusters:"0019", model:"TS0013", manufacturer:"_TYZB01_stv9a4gy", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0004,0005,0006", outClusters:"0019,000A", model:"TS0013", manufacturer:"_TZ3000_wyhuocal", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0004,0005,0006", outClusters:"0019", model:"TS0013", manufacturer:"_TYZB01_mqel1whf", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0006", outClusters:"0019", model:"TS0013", manufacturer:"_TZ3000_fvh3pjaz", deviceJoinName: "Zemismart Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0006", outClusters:"0019", model:"TS0013", manufacturer:"_TYZB01_mtlhqn48", deviceJoinName: "Lonsonho Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0006", outClusters:"0019", model:"TS0013", manufacturer:"TUYATEC-O6SNCwd6", deviceJoinName: "TUYATEC Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0006", outClusters:"0019", model:"TS0013", manufacturer:"_TZ3000_h34ihclt", deviceJoinName: "Tuya Zigbee Switch Multi-Gang" // check!
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006", outClusters:"0019", model:"TS0013", manufacturer:"_TZ3000_k44bsygw", deviceJoinName: "Zemismart Zigbee Switch No Neutral"
fingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,0000", outClusters:"0019,000A", model:"TS0013", manufacturer:"_TZ3000_qewo8dlz", deviceJoinName: "Tuya Zigbee Switch 3 Gang No Neutral" // @dingyang.yee https://www.aliexpress.com/item/4000298926256.html https://github.com/Koenkk/zigbee2mqtt/issues/6138#issuecomment-774720939
command "powerOnState", [
[name:"powerOnState", type: "ENUM", constraints: ["--- Select ---", "OFF", "ON", "Last state"], description: "Select Power On State"]
command "switchType", [
[name:"switchType", type: "ENUM", constraints: ["--- Select ---", "toggle", "state", "momentary"], description: "Select Switch Type"] // 0: 'toggle', 1: 'state', 2: 'momentary'
attribute "lastCheckin", "string"
preferences {
input (name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true)
input (name: "txtEnable", type: "bool", title: "Enable description text logging", defaultValue: true)
// Parse incoming device messages to generate events
checkDriverVersion()
//log.debug "${device.displayName} Parsing '${description}'"
def descMap = [:]
try {
descMap = zigbee.parseDescriptionAsMap(description)
catch ( e ) {
if (settings?.logEnable) log.warn "${device.displayName} exception caught while parsing description ${description} \r descMap: ${descMap}"
return null
logDebug "Parsed: $descMap"
Map map = null // [:]
if (descMap.cluster == "0006" && descMap.attrId == "0000") {
// descMap.command =="0A" - switch toggled physically
// descMap.command =="01" - get switch status
// descMap.command =="0B" - command response
def cd = getChildDevice("${device.id}-${descMap.endpoint}")
if (cd == null) {
if (!(device.data.model in ['TS0011', 'TS0001'])) {
log.warn "${device.displayName} Child device ${device.id}-${descMap.endpoint} not found. Initialise parent device first"
return
def switchAttribute = descMap.value == "01" ? "on" : "off"
if (cd != null ) {
if (descMap.command in ["0A", "0B"]) {
// switch toggled
cd.parse([[name: "switch", value:switchAttribute, descriptionText: "Child switch ${descMap.endpoint} turned $switchAttribute"]])
else if (descMap.command =="01") {
// report switch status
cd.parse([[name: "switch", value:switchAttribute, descriptionText: "Child switch ${descMap.endpoint} is $switchAttribute"]])
if (switchAttribute == "on") {
logDebug "Parent switch on"
return createEvent(name: "switch", value: "on")
else if (switchAttribute == "off") {
def cdsOn = 0
// cound number of switches on
getChildDevices().each {child ->
if (getChildId(child) != descMap.endpoint && child.currentValue('switch') == "on") {
cdsOn++
if (cdsOn == 0) {
logDebug "Parent switch off"
return createEvent(name: "switch", value: "off")
} // OnOff cluster, attrId "0000"
else if (descMap.cluster == "0006" && descMap.attrId != "0000") { // other attr
processOnOfClusterOtherAttr( descMap )
else if (descMap.cluster == "E001") { // Tuya Switch Mode cluster
else {
logDebug "${device.displayName} unprocessed EP: ${descMap.sourceEndpoint} cluster: ${descMap.clusterId} attrId: ${descMap.attrId}"
def off() {
if (settings?.txtEnable) log.info "${device.displayName} Turning all child switches off"
"he cmd 0x${device.deviceNetworkId} 0xFF 0x0006 0x0 {}"
def on() {
if (settings?.txtEnable) log.info "${device.displayName} Turning all child switches on"
"he cmd 0x${device.deviceNetworkId} 0xFF 0x0006 0x1 {}"
def refresh() {
logDebug "refreshing"
"he rattr 0x${device.deviceNetworkId} 0xFF 0x0006 0x0"
def ping() {
refresh()
private Integer convertHexToInt(hex) {
Integer.parseInt(hex,16)
private String getChildId(childDevice) {
return childDevice.deviceNetworkId.substring(childDevice.deviceNetworkId.length() - 2)
def componentOn(childDevice) {
logDebug "sending componentOn ${childDevice.deviceNetworkId}"
sendHubCommand(new HubAction("he cmd 0x${device.deviceNetworkId} 0x${getChildId(childDevice)} 0x0006 0x1 {}", Protocol.ZIGBEE))
def componentOff(childDevice) {
logDebug "sending componentOff ${childDevice.deviceNetworkId}"
sendHubCommand(new HubAction("he cmd 0x${device.deviceNetworkId} 0x${getChildId(childDevice)} 0x0006 0x0 {}", Protocol.ZIGBEE))
def componentRefresh(childDevice) {
logDebug "sending componentRefresh ${childDevice.deviceNetworkId} ${childDevice}"
sendHubCommand(new HubAction("he rattr 0x${device.deviceNetworkId} 0x${getChildId(childDevice)} 0x0006 0x0", Protocol.ZIGBEE))
def setupChildDevices() {
logDebug "Parent setupChildDevices"
deleteObsoleteChildren()
def buttons = 0
switch (device.data.model) {
case 'TS0004' :
case 'TS0014' :
buttons = 4
break
case 'TS0003' :
case 'TS0013' :
buttons = 3
break
case 'TS0002' :
case 'TS0012' :
buttons = 2
break
case 'TS0011' :
case 'TS0001' :
buttons = 0
break
default :
break
logDebug "model: ${device.data.model} buttons: $buttons"
createChildDevices((int)buttons)
def createChildDevices(int buttons) {
logDebug "Parent createChildDevices"
if (buttons == 0)
return
for (i in 1..buttons) {
def childId = "${device.id}-0${i}"
def existingChild = getChildDevices()?.find { it.deviceNetworkId == childId}
if (existingChild) {
log.info "${device.displayName} Child device ${childId} already exists (${existingChild})"
} else {
log.info "${device.displayName} Creatung device ${childId}"
addChildDevice("hubitat", "Generic Component Switch", childId, [isComponent: true, name: "Switch EP0${i}", label: "${device.displayName} EP0${i}"])
def deleteObsoleteChildren() {
logDebug "Parent deleteChildren"
getChildDevices().each {child->
if (!child.deviceNetworkId.startsWith(device.id) || child.deviceNetworkId == "${device.id}-00") {
log.info "${device.displayName} Deleting ${child.deviceNetworkId}"
deleteChildDevice(child.deviceNetworkId)
def driverVersionAndTimeStamp() {version()+' '+timeStamp()}
def checkDriverVersion() {
if (state.driverVersion == null || (driverVersionAndTimeStamp() != state.driverVersion)) {
if (txtEnable==true) log.debug "${device.displayName} updating the settings from the current driver version ${state.driverVersion} to the new version ${driverVersionAndTimeStamp()}"
initializeVars( fullInit = false )
state.driverVersion = driverVersionAndTimeStamp()
void initializeVars(boolean fullInit = true) {
if (settings?.txtEnable) log.info "${device.displayName} InitializeVars()... fullInit = ${fullInit}"
if (fullInit == true ) {
state.clear()
if (settings?.logEnable == null) device.updateSetting("logEnable", true)
if (settings?.txtEnable == null) device.updateSetting("txtEnable", true)
def initialize() {
logDebug "Initializing..."
initializeVars(fullInit = true)
setupChildDevices()
def installed() {
logDebug "Parent installed"
def updated() {
logDebug "Parent updated"
def tuyaBlackMagic() {
return zigbee.readAttribute(0x0000, [0x0004, 0x000, 0x0001, 0x0005, 0x0007, 0xfffe], [:], delay=200)
def configure() {
logDebug " configure().."
List cmds = []
cmds += tuyaBlackMagic()
//cmds += refresh()
cmds += zigbee.onOffConfig()
cmds += zigbee.onOffRefresh()
sendZigbeeCommands(cmds)
void sendZigbeeCommands(List cmds) {
logDebug "sendZigbeeCommands received : ${cmds}"
sendHubCommand(new hubitat.device.HubMultiAction(cmds, hubitat.device.Protocol.ZIGBEE))
def logDebug(msg) {
String sDnMsg = device.displayName + " " + msg
if (settings?.logEnable) log.debug sDnMsg
def powerOnState(relayMode) {
List cmds = []
int modeEnum = 99
switch(relayMode) {
case "OFF" :
modeEnum = 0
break
case "ON" :
modeEnum = 1
break
case "Last state" :
modeEnum = 2
break
default :
log.error "${device.displayName} please select a Power On State option"
return
logDebug ("setting Power On State option to: ${relayMode} (${modeEnum}")
cmds += zigbee.writeAttribute(0x0006, 0x8002, DataType.ENUM8, modeEnum)
def switchType(type) {
List cmds = []
int modeEnum = 99
switch(type) {
case "toggle" :
modeEnum = 0
break
case "state" :
modeEnum = 1
break
case "momentary" :
modeEnum = 2
break
default :
log.error "${device.displayName} please select a Switch Type"
return
logDebug ("setting Switch Type to: ${type} (${modeEnum})")
cmds += zigbee.writeAttribute(0xE001, 0xD030, DataType.ENUM8, modeEnum)
// [name:"switchType", type: "ENUM", constraints: ["--- Select ---", "toggle", "state", "state"], description: "Select Switch Type"] // 0: 'toggle', 1: 'state', 2: 'momentary'
def processOnOfClusterOtherAttr( descMap ) {
logDebug "cluster OnOff attribute ${descMap.attrId} reported: value=${descMap.value}"
def mode
def attrName
def value = descMap.value as int
switch (descMap.attrId) {
case "8000" :
attrName = "Child Lock"
mode = value == 0 ? "off" : "on"
break
case "8001" :
attrName = "LED mode"
mode = value == 0 ? "Disabled" : value == 1 ? "Lit when On" : value == 2 ? "Lit when Off" : null
break
case "8002" :
attrName = "Power On State"
mode = value == 0 ? "off" : value == 1 ? "on" : value == 2 ? "Last state" : null
break
case "D030" : // cluster E001
attrName = "Switch Type"
mode = value == 0 ? "toggle" : value == 1 ? "state" : value == 2 ? "momentary state" : null
break
default :
logDebug "processOnOfClusterOtherAttr: UNPROCESSED On/Off Cluster attrId: ${descMap.attrId} value: ${descMap.value}"
break
if (txtEnable) log.info "${device.displayName} ${attrName} is: ${mode}"
thanks
Anybody?
Hi @Reuven ,
You can try the dev. branch version 0.2.14 timestamp "2022/11/22 7:58 AM" - added 'ledMOode' command.
Update May 2024 : this driver is now available for installation and update from HPM.
Hello! Is it possible to configure the led mode individually Component Devices (childs)?
Yes without any problems.
Please see the last message from @kkossev .
Actually, the configuration of the LED mode is in effect for all the gangs / for each child. It is a single configuration command that affects all channels.
Hey I've tried and tried to get the led in the switch to be on when the switch is off but i cant get it to work.
I can see the option to change the led mode in the device screen but when i change it to on when off and save preferences it just goes back to -select-
What am i doing wrong
The answer is yes. You need to choose when lights are on and press lower button. Please send me the print screen.
Thanks for trying to help me but how do I send you the print screen.
Sorry I'm very new to this
OH MY GOD THANK YOU.
You're a legend
Does it work?
Thanks to @kkossev
Sorry i couldn't reply apparently newbies are only allowed a couple of replies to start with.
Yes it worked thank you.
But now ive had this awesome idea of been able to use a motion sensor to change the led in the switch to come on when it sensors motion near it do you know if thats possible?
Yes, it is possible to change the LED status 'on the fly'. This can be done from HE Rule Machine - try to send a Custom command 'Led Mode' with a parameter "Lit when On" or "Lit when Off".
@user6344
Let me be sure if I understood you right.
You want to turn on lights when you are close to them right? If so you can go to rules app and make a rule for it. But don't forget that there is 30 sec. waiting time (depending on sensor) from trigger to trigger. There are lots of sensors but I would suggest motion sensor with human presence.
Hi. The Driver shared by kkossev, November 2022 (above) is working for me and a "Tuya" 3-Gang Switch (XMH store on aliEx) - THANKS!
BUT, it has a RED/GREEN LED on each of the 3 switches, and i want them Reversed.
Right now, ON is RED / OFF is GREEN - Consensus in the family is, GREEN should indicate it is ON.
the LED Mode in the Device page, "Lit when ON, Lit when Off", has no effect
How can this be done?
They must be different switches to what i have, my can only be blue and on or off.
In the device right down the bottom under data what model does it say it is?
Mine is TS0011
Hi. I see this:
- manufacturer: _TZ3000_eabfqnbm
- model: TS0003
