Yes, I did remember to hit Configure. I copied the code direct from the page and pasted it into the driver code. To the right of the configure/initialize buttons, there is a list and this is what shows up:
Current States
currentHsmMode : disarmed
currentMode : Home
data : [hardwareID:000D, zigbeeEui:000D6F00168FA93D, zigbeeChannel:0x14 (20), zigbeePanID:5428, localSrvPortTCP:39501, localIP:192.168.1.130]
firmwareVersionString : 2.3.0.124
formattedUptime : 0d,0h,58m,15s
hardwareID : 000D
hubModel : C-7
hubUpdateStatus : NO_UPDATE_AVAILABLE
hubUpdateVersion : 2.3.0.124
hubVersion : 2.3.0.124
lastHubRestart : 1647810116345
lastHubRestartFormatted : 2022-03-20 17:01:56
lastUpdated : 1647813611402
latitude : 35.971763
localIP : 192.168.1.130
localSrvPortTCP : 39501
locationId : 1
locationName : Haffly_Home_Automation
longitude : -78.517388
temperatureScale : F
timeZone : sun.util.calendar.ZoneInfo[id="US/Eastern",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=US/Eastern,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]]
type : PHYSICAL
uptime : 3495
zigbeeChannel : 0x14 (20)
zigbeeEui : 000D6F00168FA93D
zigbeeId : 000D6F00168FA93D
zigbeeStatus : enabled
zipCode : 27587
zwaveStatus : enabled
Edit: I switched on the Enable HTML Attribute Creation and these lines were added into the list:
html :
Name	Haffly_Home_Automation Hub
Version	C-7 / 2.3.0.124
IP Addr	192.168.1.130
Free Mem
Last Restart	2022-03-20 17:01:57
Uptime	0d,1h,6m,50s
Temperature
ZB Channel	0x14 (20)
You will note that the Free Mem line is blank.
