That is why I could not find it. I had no idea to look for "Actuators."
What is Hia Update?
Hub Information Aggregation
The command lets me overwrite the HTML attribute with a custom attribute that combines information from 2 or more hubs.
Here is the rule I made for rebooting if the memory is low:
Once I am sure it will work reliably, I will probably change the time to while I am asleep. Until then, I want to be awake to observe whether it works or not.
It will work. I have been using the same rule for quite some time now, except that mine runs at 3:48am. I'm getting about 3 days between reboots on my C5 since changing my threshold to 250k.
It took me a bit to wrap my head around "Required Expression" rather than an If condition AND condition Then rule. Normally, I would think of it as
If
Time=8:05(F)
AND
Hub Information freeMemory (current memory) < 250000.0(F) [FALSE]
THEN
Notify . . .
AND
Speak . . .
AND
reboot() on Hub information
EndIf
The new way to write a rule does make sense though and should be easier once I get used to it. It just seems that Required Expression is just another way to say Condition.
I'm creating the above rule to auto reboot at 3am if the hub memory is low. I want to get a notification on my phone that it happened, but not at 3am. I always forget what survives a reboot. If I put "send notification delay 6h" will I still get notified at 9am or will the reboot wipeout the delay?
if the notification time is not during the reboot you should get it.
