Relatively new to Hubitat but love it so far! Sysem was very well thought out...
I have a small problem: I have a Jasco Z-Wave Plus Smart Motion Switch and would like to use it in a Button Controller app. However it appears that the driver I have does not expose buttons for this device and my seaches have not found any other drivers that do. Anyone know of one?
Try the JasonJoel drivers. Not sure if you really mean switch, or dimmer? There are also a couple different version of these switches, you might have to dig a bit to figure out which driver to use. I think it also depends upon if you want the motion separate from the switch, which the second set of drivers does.
Thanks...tried those with no luck. Further research shows that hardware for the Jasco 26931 Motion Switch does not support button functionality(double tap, hold, etc)....
No, that model doesn't have them. At least that's what I remember, I'm not by a computer to double check actually.
There was a smart things driver that did it in software based on button press plus a timer (kind of worked but not well), but there are are no double tap hardware events on the 26931 or 26933.
Maybe if they make a new 700 series version someday...
