I am not aware of any way to view the garage light status or toggle it. It would be a nice feature though!
Same problem as other things with myq. They have said they will ban anyone they find polling their apis. This is the unfortunate state of cloud based devices
Seems like you could put a dry contact relay with its coil driven by the 110 v to the LiftMaster light, put the dry contacts to a contact sensor that has external inputs (e.g., Aeotec Door/Window Sensor 7 (non-Pro and Pro)).
When I ask alexa to turn on or off the garage door opener it will open or close but alexa says I am not quite sure what went wrong. Is there a way to keep this from happening?
Did you try the following option in Amazon Echo Skill app (in Hubitat) like below? It may or may not help...
I tried that. It did not help.
Does the garage opener device in the Devices tab show the correct door state (Right top corner of the Device setting page) when you open and close the door? And are you using a contact sensor, NOT the MYQ one, a Zigbee or Zwave sensor?
The correct states are shown. I am not using a contact sensor,, I am using a smartthings multipurpose sensor which is zigbee..
Mine does the same thing, something changed on the Alexa end about a month ago. It still works fine, Alexa still closes the door, she just complains that something went wrong. I ignore her. Yes, everything works perfectly on the Hubitat side. Driver works, Dashboard control and tiles work. Yes, using Aeotec Door/Window Sensor 7 (Z-Wave Plus, 700 series chip).
No, the switch you suggested changing doesn’t help.
Eventually, things will stabilize on the Alexa end. I look at the SmartThings thread every so often to monitor if a fix goes in over there to Brian Beaird’s app/driver (of which the Hubitat app/driver is a straightforward port). SmartThings has bigger problems right now than this. Brian Beaird says it’s a mess, too.
Nope, that is fine. Misspoke a bit, but either one is fairly equivalent in this case. Just wanted to be sure the app was aware of door state somehow.
So you think this is a Hubitat, MyQ or Alexa issue? Sounds like you are blaming Alexa. She sure is a stubborn one sometimes. I know what she gets called in my household anyway.
I just know that nothing has changed on the Hubitat side in a year or so. Regardless whose issue it is, I am certain that Brian Beaird and/or Dominic Meglio (@dman2306) will figure it out once things stabilize. It’s just an annoyance.
It look like GE Fan controllers have the same issue. 2.2.3.118 - GE Smart Fan Control and Alexa - Support - Hubitat
Some people in the discussion suggested using a virtual switch or giving the alexa comand in a different way. It sounds like alexa cannot handle too many commands at once like turning on a fan and also setting a speed.
If it gets too annoying before there is a fix I might try a virtual switch.
Is is normal to have 2 instances of the app installed? If I go to settings and hit remove will it delete both and force me to set it up again?
No. No, it will remove the instance you remove.
Just in case, back up first, download and save. There is a very remote possibility the double instances are from a corrupted database, probably not. I’ve never seen corruption cause that.
Perfect, as you said it only removed the double. Thx
Hi there!! I am new to hubitat and this community. Can you tell me what you did to resolve this? I am getting the same error. Thanks in advance.
The sensor indexing error? That means you probably don't have a dedicated Zigbee or Zwave tilt sensor, but are using the code for use with a sensor.
A tilt sensor is highly recommended. And no, the MyQ sensor doesn't work for this app.
I spent that last few hours getting my open/close garage doors to show up in the dashboard. I tried to refresh the devices. Even reboot my hub and no luck. Would be nice if someone can put the directions at the top of the postings.
