Not sure what you mean by the same results since your problem is that MQTT commands are not triggering the door to open. How can you tell with the second one since it’s not wired?
To be clear, you have to do this on a wired ratgdo and confirm your door opens:
publish in MQTT Explorer
topic: ratgdo/ratgdo-8229/command/door the message open (RAW)
Replace ratgdo-8229`` with your device name (Device Name & Web Config Username``` in the ratgdo web UI)
Verify that the MQTT Topic Prefix is set to ratgdo/
nothing changed. for example this morning for the heck of it i just pushed the HE open button and it opened. it did not close and none of the other buttons worked. i closed it with the garage door closer and it would not open again from HE.
i know the board is getting the command because the blue light blinks instantly everytime i press any HE buttons.
there are only 4 wires coming out of the wall. 2 (red,white) for the wall button and 2(red,white) for the obstruction sensor. what other sensors are you referring to?
Most obstruction sensors are attached to the opener in pairs. I guess they are likely wired together somewhere in your system. I've got a security 2 opener, so I can't really say much about a 1 opener.
If you look at the settings of the device in HK, you'll see you can split it in two controls (if I recall correctly). One is lock and the other one door control. The integration doesn't see it as a light even though it declares that capability.
It's been discussed early on and if HE doesn't improve that implementation, it might be necessary to use child device and split the ratgo as three devices, light, door control, lock (and maybe obstruction sensor).
TBH, I only use it for the door open and close through Homekit (using Carplay) and I haven't had a use for the lock or light. But I'll be happy to look into child devices in the future.
I remember the function you're referring to. I think they removed that when they put the lights in the room and the sensors at the top of the room. I see the open/close button and i see the door sensor for open/closed but no lock or light. also i don't know if i would use the lock/light functions but if there were there i might.
