Logs
dev:31572024-01-04 07:02:25.431 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0008, attrId:FFFB, value:[00, 01, 0F, 4000, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:8, attrInt:65531] description:read attr - endpoint: 01, cluster: 0008, attrId: FFFB, value: 1604000401040F05004005F8FF05F9FF05FBFF05FCFF05FDFF18
dev:31572024-01-04 07:02:25.409 PMinfoMatter bulb [FFF9] AcceptedCommandList = [00, 01, 02, 03, 04, 05, 06, 07]
dev:31572024-01-04 07:02:25.406 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0008
dev:31572024-01-04 07:02:25.404 PMwarnMatter bulb skipped level, attribute:FFF9, value:[00, 01, 02, 03, 04, 05, 06, 07]
dev:31572024-01-04 07:02:25.400 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0008, attrId:FFF9, value:[00, 01, 02, 03, 04, 05, 06, 07], clusterInt:8, attrInt:65529] description:read attr - endpoint: 01, cluster: 0008, attrId: FFF9, value: 160400040104020403040404050406040718
dev:31572024-01-04 07:02:25.380 PMinfoMatter bulb [FFF8] GeneratedCommandList = 0x1618 (5656)
dev:31572024-01-04 07:02:25.377 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0008
dev:31572024-01-04 07:02:25.375 PMwarnMatter bulb skipped level, attribute:FFF8, value:1618
dev:31572024-01-04 07:02:25.371 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0008, attrId:FFF8, value:1618, clusterInt:8, attrInt:65528] description:read attr - endpoint: 01, cluster: 0008, attrId: FFF8, value: 1618
dev:31572024-01-04 07:02:25.354 PMinfoMatter bulb [0001] RemainingTime = 00
dev:31572024-01-04 07:02:25.351 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0008
dev:31572024-01-04 07:02:25.348 PMwarnMatter bulb skipped level, attribute:0001, value:00
dev:31572024-01-04 07:02:25.345 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0008, attrId:0001, value:00, clusterInt:8, attrInt:1] description:read attr - endpoint: 01, cluster: 0008, attrId: 0001, value: 0400
dev:31572024-01-04 07:02:25.325 PMinfoMatter bulb [0000] CurrentLevel = 0xFE (254)
dev:31572024-01-04 07:02:25.322 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0008
dev:31572024-01-04 07:02:25.319 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0008, attrId:0000, value:FE, clusterInt:8, attrInt:0] description:read attr - endpoint: 01, cluster: 0008, attrId: 0000, value: 04FE
dev:31572024-01-04 07:02:25.305 PMinfoMatter bulb [4000] StartUpCurrentLevel = 0x80 (128)
dev:31572024-01-04 07:02:25.302 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0008
dev:31572024-01-04 07:02:25.287 PMwarnMatter bulb skipped level, attribute:4000, value:80
dev:31572024-01-04 07:02:25.284 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0008, attrId:4000, value:80, clusterInt:8, attrInt:16384] description:read attr - endpoint: 01, cluster: 0008, attrId: 4000, value: 0480
dev:31572024-01-04 07:02:25.191 PMdebugMatter bulb sendToDevice (String): (he rattrs [{"ep":"0x01","cluster":"0x0008","attr":"0x0000"},{"ep":"0x01","cluster":"0x0008","attr":"0x0001"},{"ep":"0x01","cluster":"0x0008","attr":"0x000F"},{"ep":"0x01","cluster":"0x0008","attr":"0x4000"},{"ep":"0x01","cluster":"0x0008","attr":"0xFFF8"},{"ep":"0x01","cluster":"0x0008","attr":"0xFFF9"},{"ep":"0x01","cluster":"0x0008","attr":"0xFFFB"},{"ep":"0x01","cluster":"0x0008","attr":"0xFFFC"},{"ep":"0x01","cluster":"0x0008","attr":"0xFFFD"}])
dev:31572024-01-04 07:02:25.127 PMdebugMatter bulb requestMatterClusterAttributesValues: attrList:[0, 1, 15, 16384, 65528, 65529, 65531, 65532, 65533]
dev:31572024-01-04 07:02:25.124 PMinfoMatter bulb Requesting Cluster LevelControl (0x0008) endpoint 01 attributes values ...
dev:31572024-01-04 07:02:22.185 PMdebugMatter bulb pareseAttributeList: state.matter[0x0008] = [00, 01, 0F, 4000, FFF8, FFF9, FFFB, FFFC, FFFD]
dev:31572024-01-04 07:02:22.182 PMdebugMatter bulb pareseAttributeList: descMap:[endpoint:01, cluster:0008, attrId:FFFB, value:[00, 01, 0F, 4000, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:8, attrInt:65531]
dev:31572024-01-04 07:02:22.179 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0008, attrId:FFFB, value:[00, 01, 0F, 4000, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:8, attrInt:65531] description:read attr - endpoint: 01, cluster: 0008, attrId: FFFB, value: 1604000401040F05004005F8FF05F9FF05FBFF05FCFF05FDFF18
dev:31572024-01-04 07:02:22.099 PMdebugMatter bulb sendToDevice (String): (he rattrs [{"ep":"0x01","cluster":"0x0008","attr":"0xFFFB"}])
dev:31572024-01-04 07:02:22.096 PMinfoMatter bulb Requesting Cluster LevelControl (0x0008) endpoint 01 attributes list ...
dev:31572024-01-04 07:02:19.077 PMinfoMatter bulb Cluster OnOff (0x0006) endpoint 01 attributes and values list :
[4000] GlobalSceneControl = 01
[0000] Switch = 01
[4001] OnTime = 00
[4002] OffWaitTime = 00
[4003] StartUpOnOff = 00
[FFF9] AcceptedCommandList = [00, 01, 02, 40, 41, 42]
[FFFC] FeatureMap = 01
[FFFD] ClusterRevision = 04
dev:31572024-01-04 07:02:10.468 PMinfoMatter bulb parse: Switch: ClusterRevision = 04
dev:31572024-01-04 07:02:10.465 PMdebugMatter bulb parseOnOffCluster: descMap:[endpoint:01, cluster:0006, attrId:FFFD, value:04, clusterInt:6, attrInt:65533]
dev:31572024-01-04 07:02:10.463 PMinfoMatter bulb [FFFD] ClusterRevision = 04
dev:31572024-01-04 07:02:10.460 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0006
dev:31572024-01-04 07:02:10.457 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:FFFD, value:04, clusterInt:6, attrInt:65533] description:read attr - endpoint: 01, cluster: 0006, attrId: FFFD, value: 0404
dev:31572024-01-04 07:02:10.441 PMinfoMatter bulb parse: Switch: FeatureMap = 01
dev:31572024-01-04 07:02:10.438 PMdebugMatter bulb parseOnOffCluster: descMap:[endpoint:01, cluster:0006, attrId:FFFC, value:01, clusterInt:6, attrInt:65532]
dev:31572024-01-04 07:02:10.436 PMinfoMatter bulb [FFFC] FeatureMap = 01
dev:31572024-01-04 07:02:10.433 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0006
dev:31572024-01-04 07:02:10.430 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:FFFC, value:01, clusterInt:6, attrInt:65532] description:read attr - endpoint: 01, cluster: 0006, attrId: FFFC, value: 0401
dev:31572024-01-04 07:02:10.410 PMdebugMatter bulb pareseAttributeList: state.matter[0x0006] = [00, 4000, 4001, 4002, 4003, FFF8, FFF9, FFFB, FFFC, FFFD]
dev:31572024-01-04 07:02:10.408 PMdebugMatter bulb pareseAttributeList: descMap:[endpoint:01, cluster:0006, attrId:FFFB, value:[00, 4000, 4001, 4002, 4003, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:6, attrInt:65531]
dev:31572024-01-04 07:02:10.405 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:FFFB, value:[00, 4000, 4001, 4002, 4003, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:6, attrInt:65531] description:read attr - endpoint: 01, cluster: 0006, attrId: FFFB, value: 16040005004005014005024005034005F8FF05F9FF05FBFF05FCFF05FDFF18
dev:31572024-01-04 07:02:10.385 PMinfoMatter bulb parse: Switch: AcceptedCommandList = [00, 01, 02, 40, 41, 42]
dev:31572024-01-04 07:02:10.382 PMdebugMatter bulb parseOnOffCluster: descMap:[endpoint:01, cluster:0006, attrId:FFF9, value:[00, 01, 02, 40, 41, 42], clusterInt:6, attrInt:65529]
dev:31572024-01-04 07:02:10.379 PMinfoMatter bulb [FFF9] AcceptedCommandList = [00, 01, 02, 40, 41, 42]
dev:31572024-01-04 07:02:10.377 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0006
dev:31572024-01-04 07:02:10.374 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:FFF9, value:[00, 01, 02, 40, 41, 42], clusterInt:6, attrInt:65529] description:read attr - endpoint: 01, cluster: 0006, attrId: FFF9, value: 1604000401040204400441044218
dev:31572024-01-04 07:02:10.355 PMinfoMatter bulb parse: Switch: GeneratedCommandList = 1618
dev:31572024-01-04 07:02:10.352 PMdebugMatter bulb parseOnOffCluster: descMap:[endpoint:01, cluster:0006, attrId:FFF8, value:1618, clusterInt:6, attrInt:65528]
dev:31572024-01-04 07:02:10.349 PMinfoMatter bulb [FFF8] GeneratedCommandList = 0x1618 (5656)
dev:31572024-01-04 07:02:10.347 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0006
dev:31572024-01-04 07:02:10.344 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:FFF8, value:1618, clusterInt:6, attrInt:65528] description:read attr - endpoint: 01, cluster: 0006, attrId: FFF8, value: 1618
dev:31572024-01-04 07:02:10.327 PMinfoMatter bulb parse: Switch: StartUpOnOff = 00 (Off)
dev:31572024-01-04 07:02:10.325 PMdebugMatter bulb parseOnOffCluster: descMap:[endpoint:01, cluster:0006, attrId:4003, value:00, clusterInt:6, attrInt:16387]
dev:31572024-01-04 07:02:10.322 PMinfoMatter bulb [4003] StartUpOnOff = 00
dev:31572024-01-04 07:02:10.320 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0006
dev:31572024-01-04 07:02:10.317 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:4003, value:00, clusterInt:6, attrInt:16387] description:read attr - endpoint: 01, cluster: 0006, attrId: 4003, value: 0400
dev:31572024-01-04 07:02:10.300 PMinfoMatter bulb parse: Switch: OffWaitTime = 00
dev:31572024-01-04 07:02:10.298 PMdebugMatter bulb parseOnOffCluster: descMap:[endpoint:01, cluster:0006, attrId:4002, value:00, clusterInt:6, attrInt:16386]
dev:31572024-01-04 07:02:10.295 PMinfoMatter bulb [4002] OffWaitTime = 00
dev:31572024-01-04 07:02:10.293 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0006
dev:31572024-01-04 07:02:10.290 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:4002, value:00, clusterInt:6, attrInt:16386] description:read attr - endpoint: 01, cluster: 0006, attrId: 4002, value: 0400
dev:31572024-01-04 07:02:10.274 PMinfoMatter bulb parse: Switch: OnTime = 00
dev:31572024-01-04 07:02:10.271 PMdebugMatter bulb parseOnOffCluster: descMap:[endpoint:01, cluster:0006, attrId:4001, value:00, clusterInt:6, attrInt:16385]
dev:31572024-01-04 07:02:10.269 PMinfoMatter bulb [4001] OnTime = 00
dev:31572024-01-04 07:02:10.266 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0006
dev:31572024-01-04 07:02:10.263 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:4001, value:00, clusterInt:6, attrInt:16385] description:read attr - endpoint: 01, cluster: 0006, attrId: 4001, value: 0400
dev:31572024-01-04 07:02:10.247 PMdebugMatter bulb ignored duplicated switch event, value:on
dev:31572024-01-04 07:02:10.244 PMdebugMatter bulb parseOnOffCluster: descMap:[endpoint:01, cluster:0006, attrId:0000, value:01, clusterInt:6, attrInt:0]
dev:31572024-01-04 07:02:10.242 PMinfoMatter bulb [0000] Switch = 01
dev:31572024-01-04 07:02:10.239 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0006
dev:31572024-01-04 07:02:10.236 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:0000, value:01, clusterInt:6, attrInt:0] description:read attr - endpoint: 01, cluster: 0006, attrId: 0000, value: 09
dev:31572024-01-04 07:02:10.221 PMinfoMatter bulb parse: Switch: GlobalSceneControl = 01
dev:31572024-01-04 07:02:10.218 PMdebugMatter bulb parseOnOffCluster: descMap:[endpoint:01, cluster:0006, attrId:4000, value:01, clusterInt:6, attrInt:16384]
dev:31572024-01-04 07:02:10.215 PMinfoMatter bulb [4000] GlobalSceneControl = 01
dev:31572024-01-04 07:02:10.213 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 0006
dev:31572024-01-04 07:02:10.210 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:4000, value:01, clusterInt:6, attrInt:16384] description:read attr - endpoint: 01, cluster: 0006, attrId: 4000, value: 09
dev:31572024-01-04 07:02:10.112 PMdebugMatter bulb sendToDevice (String): (he rattrs [{"ep":"0x01","cluster":"0x0006","attr":"0x0000"},{"ep":"0x01","cluster":"0x0006","attr":"0x4000"},{"ep":"0x01","cluster":"0x0006","attr":"0x4001"},{"ep":"0x01","cluster":"0x0006","attr":"0x4002"},{"ep":"0x01","cluster":"0x0006","attr":"0x4003"},{"ep":"0x01","cluster":"0x0006","attr":"0xFFF8"},{"ep":"0x01","cluster":"0x0006","attr":"0xFFF9"},{"ep":"0x01","cluster":"0x0006","attr":"0xFFFB"},{"ep":"0x01","cluster":"0x0006","attr":"0xFFFC"},{"ep":"0x01","cluster":"0x0006","attr":"0xFFFD"}])
dev:31572024-01-04 07:02:10.052 PMdebugMatter bulb requestMatterClusterAttributesValues: attrList:[0, 16384, 16385, 16386, 16387, 65528, 65529, 65531, 65532, 65533]
dev:31572024-01-04 07:02:10.049 PMinfoMatter bulb Requesting Cluster OnOff (0x0006) endpoint 01 attributes values ...
dev:31572024-01-04 07:02:07.111 PMdebugMatter bulb pareseAttributeList: state.matter[0x0006] = [00, 4000, 4001, 4002, 4003, FFF8, FFF9, FFFB, FFFC, FFFD]
dev:31572024-01-04 07:02:07.108 PMdebugMatter bulb pareseAttributeList: descMap:[endpoint:01, cluster:0006, attrId:FFFB, value:[00, 4000, 4001, 4002, 4003, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:6, attrInt:65531]
dev:31572024-01-04 07:02:07.105 PMdebugMatter bulb parse: descMap:[endpoint:01, cluster:0006, attrId:FFFB, value:[00, 4000, 4001, 4002, 4003, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:6, attrInt:65531] description:read attr - endpoint: 01, cluster: 0006, attrId: FFFB, value: 16040005004005014005024005034005F8FF05F9FF05FBFF05FCFF05FDFF18
dev:31572024-01-04 07:02:07.030 PMdebugMatter bulb sendToDevice (String): (he rattrs [{"ep":"0x01","cluster":"0x0006","attr":"0xFFFB"}])
dev:31572024-01-04 07:02:07.027 PMinfoMatter bulb Requesting Cluster OnOff (0x0006) endpoint 01 attributes list ...
dev:31572024-01-04 07:02:04.007 PMinfoMatter bulb Cluster Descriptor (0x001D) endpoint 00 attributes and values list :
[0000] DeviceTypeList = [16, 1818]
[0001] ServerList = [04, 1D, 1F, 28, 2A, 30, 31, 33, 36, 3C, 3E, 3F]
[0002] ClientList = [29]
[0003] PartsList = [01]
[FFF9] AcceptedCommandList = 0x1618 (5656)
[FFFC] FeatureMap = 00
[FFFD] ClusterRevision = 01
dev:31572024-01-04 07:01:55.363 PMinfoMatter bulb [FFFD] ClusterRevision = 01
dev:31572024-01-04 07:01:55.355 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 001D
dev:31572024-01-04 07:01:55.352 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:FFFD, value:01, clusterInt:29, attrInt:65533] description:read attr - endpoint: 00, cluster: 001D, attrId: FFFD, value: 0401
dev:31572024-01-04 07:01:55.330 PMinfoMatter bulb [FFFC] FeatureMap = 00
dev:31572024-01-04 07:01:55.328 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 001D
dev:31572024-01-04 07:01:55.325 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:FFFC, value:00, clusterInt:29, attrInt:65532] description:read attr - endpoint: 00, cluster: 001D, attrId: FFFC, value: 0400
dev:31572024-01-04 07:01:55.261 PMdebugMatter bulb pareseAttributeList: state.matter[0x001D] = [00, 01, 02, 03, FFF8, FFF9, FFFB, FFFC, FFFD]
dev:31572024-01-04 07:01:55.259 PMdebugMatter bulb pareseAttributeList: descMap:[endpoint:00, cluster:001D, attrId:FFFB, value:[00, 01, 02, 03, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:29, attrInt:65531]
dev:31572024-01-04 07:01:55.256 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:FFFB, value:[00, 01, 02, 03, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:29, attrInt:65531] description:read attr - endpoint: 00, cluster: 001D, attrId: FFFB, value: 16040004010402040305F8FF05F9FF05FBFF05FCFF05FDFF18
dev:31572024-01-04 07:01:55.230 PMinfoMatter bulb [FFF9] AcceptedCommandList = 0x1618 (5656)
dev:31572024-01-04 07:01:55.227 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 001D
dev:31572024-01-04 07:01:55.224 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:FFF9, value:1618, clusterInt:29, attrInt:65529] description:read attr - endpoint: 00, cluster: 001D, attrId: FFF9, value: 1618
dev:31572024-01-04 07:01:55.204 PMinfoMatter bulb [FFF8] GeneratedCommandList = 0x1618 (5656)
dev:31572024-01-04 07:01:55.201 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 001D
dev:31572024-01-04 07:01:55.198 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:FFF8, value:1618, clusterInt:29, attrInt:65528] description:read attr - endpoint: 00, cluster: 001D, attrId: FFF8, value: 1618
dev:31572024-01-04 07:01:55.179 PMinfoMatter bulb [0003] PartsList = [01]
dev:31572024-01-04 07:01:55.177 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 001D
dev:31572024-01-04 07:01:55.174 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:0003, value:[01], clusterInt:29, attrInt:3] description:read attr - endpoint: 00, cluster: 001D, attrId: 0003, value: 16040118
dev:31572024-01-04 07:01:55.154 PMinfoMatter bulb [0002] ClientList = [29]
dev:31572024-01-04 07:01:55.152 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 001D
dev:31572024-01-04 07:01:55.149 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:0002, value:[29], clusterInt:29, attrInt:2] description:read attr - endpoint: 00, cluster: 001D, attrId: 0002, value: 16042918
dev:31572024-01-04 07:01:55.130 PMinfoMatter bulb [0001] ServerList = [04, 1D, 1F, 28, 2A, 30, 31, 33, 36, 3C, 3E, 3F]
dev:31572024-01-04 07:01:55.128 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 001D
dev:31572024-01-04 07:01:55.125 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:0001, value:[04, 1D, 1F, 28, 2A, 30, 31, 33, 36, 3C, 3E, 3F], clusterInt:29, attrInt:1] description:read attr - endpoint: 00, cluster: 001D, attrId: 0001, value: 160404041D041F0428042A0430043104330436043C043E043F18
dev:31572024-01-04 07:01:55.103 PMinfoMatter bulb [0000] DeviceTypeList = [16, 1818]
dev:31572024-01-04 07:01:55.101 PMdebugMatter bulb gatherAttributesValuesInfo: isInfo:true state.states['cluster'] = 001D
dev:31572024-01-04 07:01:55.098 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:0000, value:[16, 1818], clusterInt:29, attrInt:0] description:read attr - endpoint: 00, cluster: 001D, attrId: 0000, value: 16152400162401011818
dev:31572024-01-04 07:01:55.000 PMdebugMatter bulb sendToDevice (String): (he rattrs [{"ep":"0x00","cluster":"0x001D","attr":"0x0000"},{"ep":"0x00","cluster":"0x001D","attr":"0x0001"},{"ep":"0x00","cluster":"0x001D","attr":"0x0002"},{"ep":"0x00","cluster":"0x001D","attr":"0x0003"},{"ep":"0x00","cluster":"0x001D","attr":"0xFFF8"},{"ep":"0x00","cluster":"0x001D","attr":"0xFFF9"},{"ep":"0x00","cluster":"0x001D","attr":"0xFFFB"},{"ep":"0x00","cluster":"0x001D","attr":"0xFFFC"},{"ep":"0x00","cluster":"0x001D","attr":"0xFFFD"}])
dev:31572024-01-04 07:01:54.991 PMdebugMatter bulb requestMatterClusterAttributesValues: attrList:[0, 1, 2, 3, 65528, 65529, 65531, 65532, 65533]
dev:31572024-01-04 07:01:54.988 PMinfoMatter bulb Requesting Cluster Descriptor (0x001D) endpoint 00 attributes values ...
dev:31572024-01-04 07:01:53.771 PMdebugMatter bulb pareseAttributeList: state.matter[0x001D] = [00, 01, 02, 03, FFF8, FFF9, FFFB, FFFC, FFFD]
dev:31572024-01-04 07:01:53.768 PMdebugMatter bulb pareseAttributeList: descMap:[endpoint:00, cluster:001D, attrId:FFFB, value:[00, 01, 02, 03, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:29, attrInt:65531]
dev:31572024-01-04 07:01:53.765 PMdebugMatter bulb parse: descMap:[endpoint:00, cluster:001D, attrId:FFFB, value:[00, 01, 02, 03, FFF8, FFF9, FFFB, FFFC, FFFD], clusterInt:29, attrInt:65531] description:read attr - endpoint: 00, cluster: 001D, attrId: FFFB, value: 16040004010402040305F8FF05F9FF05FBFF05FCFF05FDFF18
dev:31572024-01-04 07:01:51.966 PMdebugMatter bulb sendToDevice (String): (he rattrs [{"ep":"0x00","cluster":"0x001D","attr":"0xFFFB"}])
dev:31572024-01-04 07:01:51.964 PMinfoMatter bulb Requesting Cluster Descriptor (0x001D) endpoint 00 attributes list ...
dev:31572024-01-04 07:01:49.951 PMinfoMatter bulb Cluster BasicInformation (0x0028) endpoint 00 attributes and values list :
[0000] DataModelRevision = 01
[0001] VendorName = Zemismart Technology Limited
[0002] VendorID = 0x139C (5020)
[0003] ProductName = Zemismart bulb
[0004] ProductID = 0xD002 (53250)
[0006] Location = US
[0007] HardwareVersion = 00
[0008] HardwareVersionString = 1.0
[0009] SoftwareVersion = 00
[000A] SoftwareVersionString = 1.10
[0013] CapabilityMinima = 1524000324010318
