[BETA] Matter Advanced RGBW Light w/ healthStatus [MATTER]
I hadn’t tried any of the advanced options yet.
Ok, leave the defaults.
After several days of use (without restarting the HE hub) it will be interesting to see what will be this device CPU usage statistics.
Incase you are interested in adding the Color temp into your parser you can simply take the convert he raw value from hex and then divide 1,000,000 by that number and it will give you the CT.
Thank you for your contribution!
There were many changes in this driver's development branch that I forgot to merge into the main branch months ago.... I have performed the merge manually now.
Any suggestions for a driver to use with this Matter RGBW bulb?
Lightinginside Matter WiFi Smart Light Bulbs 100W Equivalent, Compatible with Alexa/Siri/Apple Home/Google Home/SmartThings, 2.4GHz WiFi Only, A19 E26 Light Bulb, 1350LM 11W, ETL Listed,2PC - Amazon.com
The driver in this thread didn't work, and the Generic Matter RGBW didn't either. It paired initially with the Third Reality Matter Multi-function Night Light, but that didn't seem to work either.
Full disclosure: I am able to control from Amazon Alexa app, and some command from some of the mentioned drivers actually perform a command or two. But then they stop working.
Before you ask why I'd buy a bulb that I didn't know how I was going to use it, I didn't. I'm an Amazon Vine reviewer so these things kind of fall into my lap.
Well it is Matter, so a driver should be universal, up to a point anyway. Isn't that the point of the Matter protocol? It is all just supposed to just magically work together!
I am both surprised and not surprised that it doesn't work. The bulb should do most common things like on/off/dim without a special driver. But on the other hand, Matter is sorta half-baked. So...
