I've created a generic zigbee siren driver that should support all capabilities by Zigbee specifications. Please note that most of zigbee sirens support just a small subset of them, so IE changing siren volume or strobe light doesn't have any effect.
It exposes also a Speech Synthesis capability so it's possible to use different configurations depending where it's used (example Warning WarningMode=1 UseStrobe=1 SirenLevel=2 WarningDuration=20 )
@gabriele, Firstly thanks for creating the driver. I am using trying to use your driver on Swann one is Outdoor siren. Hubitat originally detects it as a "Device"'. I then change it to your driver.
However, when I attempted to trigger the siren and strobe with HSM (contact sensor open), all I got was a single beep.
Attached is a screen shot of the logs. Any idea how to make it work or where did I go wrong? Thanks for your help.
If you tap "Siren" and "Strobe" buttons on device page what happens? BTW that's what HSM is using.
Please consider that driver it's strictly based on Zigbee siren protocol definition, but it's up to the manufacturer to implement all options in the device.
What I suggest is trying to change some settings (making different combinations), save and test with the buttons.
@gabriele, ok playing with the HSM, instead of selecting both Siren and Strobe, I selected siren as the only alert and that works. It actually triggers both siren and strobe!
HSM sends the "siren" command unless you select both strobe and siren, in which case it sends "on" command. That should be changed so that if both selected, it sends "siren" and "strobe" commands, not "on".
I don't remember what driver is doing for "On" but probably that's the issue and probably it has never been fixed on HSM side. I'm using just siren BTW.
@gabriele, yes I saw that too, hence why I selected only siren in HSM.
This issue is supposed to have been fixed in 1.1.5, However, selecting both siren and strobe seems to send a "on" signal to the generic zigbee device which is just the beep sound..
Ok, crazy as it sounds, it has just started working, I have no idea why, although i have just updated the HE firmware, so maybe that had something to do with it!
