For inclusion or exclusion you can just toggle the light switch 3 times rather than having to get the device out, does the same as the B button for that. But I've also used the B button too with the same results.
The only time I can see config messages is after Inclusion and pressing the Save parameters button.
dev:692019-07-30 21:53:24.770 debugLivingroom Lights parameter '54' with a byte size of '1' is set to '0'
dev:692019-07-30 21:53:23.230 debugLivingroom Lights parameter '53' with a byte size of '2' is set to '10'
dev:692019-07-30 21:53:21.709 debugLivingroom Lights parameter '52' with a byte size of '2' is set to '3600'
dev:692019-07-30 21:53:20.185 debugLivingroom Lights parameter '50' with a byte size of '1' is set to '0'
dev:692019-07-30 21:53:18.674 debugLivingroom Lights parameter '44' with a byte size of '2' is set to '600'
dev:692019-07-30 21:53:17.135 debugLivingroom Lights parameter '43' with a byte size of '1' is set to '1'
dev:692019-07-30 21:53:15.656 debugLivingroom Lights parameter '42' with a byte size of '1' is set to '3'
dev:692019-07-30 21:53:14.138 debugLivingroom Lights parameter '41' with a byte size of '1' is set to '2'
dev:692019-07-30 21:53:12.636 debugLivingroom Lights parameter '40' with a byte size of '1' is set to '0'
dev:692019-07-30 21:53:11.098 debugLivingroom Lights parameter '39' with a byte size of '2' is set to '250'
dev:692019-07-30 21:53:09.589 debugLivingroom Lights parameter '35' with a byte size of '1' is set to '1'
dev:692019-07-30 21:53:08.080 debugLivingroom Lights parameter '28' with a byte size of '1' is set to '0'
dev:692019-07-30 21:53:06.538 debugLivingroom Lights parameter '26' with a byte size of '1' is set to '0'
dev:692019-07-30 21:53:05.026 debugLivingroom Lights parameter '23' with a byte size of '1' is set to '1'
dev:692019-07-30 21:53:03.493 debugLivingroom Lights parameter '22' with a byte size of '1' is set to '0'
dev:692019-07-30 21:53:01.974 debugLivingroom Lights parameter '20' with a byte size of '1' is set to '1'
dev:692019-07-30 21:53:00.452 debugLivingroom Lights parameter '19' with a byte size of '1' is set to '0'
dev:692019-07-30 21:52:58.957 debugLivingroom Lights parameter '10' with a byte size of '2' is set to '0'
dev:692019-07-30 21:52:57.431 debugLivingroom Lights parameter '9' with a byte size of '1' is set to '1'
dev:692019-07-30 21:52:55.914 debugLivingroom Lights parameter '8' with a byte size of '2' is set to '5'
dev:692019-07-30 21:52:54.417 debugLivingroom Lights parameter '7' with a byte size of '1' is set to '1'
dev:692019-07-30 21:52:52.884 debugLivingroom Lights parameter '6' with a byte size of '2' is set to '1'
dev:692019-07-30 21:52:51.379 debugLivingroom Lights parameter '5' with a byte size of '1' is set to '1'
dev:692019-07-30 21:52:49.863 debugAssociationReport AssociationReport(groupingIdentifier:2, maxNodesSupported:5, reportsToFollow:0, nodeId:[1])
dev:692019-07-30 21:52:46.835 debugAssociationReport AssociationReport(groupingIdentifier:1, maxNodesSupported:1, reportsToFollow:0, nodeId:[1])
dev:692019-07-30 21:52:43.829 debugFirmware Report FirmwareMdReport(checksum:null, firmwareId:null, manufacturerId:null)
dev:692019-07-30 21:52:43.635 debugCurrent value of parameter 54 is unknown
dev:692019-07-30 21:52:43.631 debugCurrent value of parameter 53 is unknown
dev:692019-07-30 21:52:43.628 debugCurrent value of parameter 52 is unknown
dev:692019-07-30 21:52:43.626 debugCurrent value of parameter 50 is unknown
dev:692019-07-30 21:52:43.623 debugCurrent value of parameter 44 is unknown
dev:692019-07-30 21:52:43.620 debugCurrent value of parameter 43 is unknown
dev:692019-07-30 21:52:43.618 debugCurrent value of parameter 42 is unknown
dev:692019-07-30 21:52:43.615 debugCurrent value of parameter 41 is unknown
dev:692019-07-30 21:52:43.612 debugCurrent value of parameter 40 is unknown
dev:692019-07-30 21:52:43.609 debugCurrent value of parameter 39 is unknown
dev:692019-07-30 21:52:43.607 debugCurrent value of parameter 35 is unknown
dev:692019-07-30 21:52:43.604 debugCurrent value of parameter 28 is unknown
dev:692019-07-30 21:52:43.601 debugCurrent value of parameter 26 is unknown
dev:692019-07-30 21:52:43.599 debugCurrent value of parameter 23 is unknown
dev:692019-07-30 21:52:43.596 debugCurrent value of parameter 22 is unknown
dev:692019-07-30 21:52:43.593 debugCurrent value of parameter 20 is unknown
dev:692019-07-30 21:52:43.590 debugCurrent value of parameter 19 is unknown
dev:692019-07-30 21:52:43.587 debugCurrent value of parameter 10 is unknown
dev:692019-07-30 21:52:43.584 debugCurrent value of parameter 9 is unknown
dev:692019-07-30 21:52:43.581 debugCurrent value of parameter 8 is unknown
dev:692019-07-30 21:52:43.572 debugCurrent value of parameter 7 is unknown
dev:692019-07-30 21:52:43.569 debugCurrent value of parameter 6 is unknown
dev:692019-07-30 21:52:43.566 debugCurrent value of parameter 5 is unknown
dev:692019-07-30 21:52:43.521 debugSetting association group 2
dev:692019-07-30 21:52:43.518 debugSetting association group 1
dev:692019-07-30 21:52:43.515 debugRequesting device firmware version
dev:692019-07-30 21:52:43.474 debugupdated() is being called
dev:12019-07-30 21:51:09.729 infoSpare Motion Sensor: motion is inactive
dev:692019-07-30 21:50:52.832 debugskip: Crc16Encap(checksum:65535, command:6, commandClass:112, data:[58, 1, 0])
dev:692019-07-30 21:50:52.828 debugparse description: zw device: 14, command: 5601, payload: 70 06 3A 01 00 1D 2A , isMulticast: false
dev:692019-07-30 21:50:52.820 debugskip: Crc16Encap(checksum:65535, command:6, commandClass:112, data:[33, 1, 0])
dev:692019-07-30 21:50:52.813 debugparse description: zw device: 14, command: 5601, payload: 70 06 21 01 00 AE B8 , isMulticast: false
dev:692019-07-30 21:50:52.801 debugskip: Crc16Encap(checksum:65535, command:6, commandClass:112, data:[32, 1, 2])
dev:692019-07-30 21:50:52.796 debugparse description: zw device: 14, command: 5601, payload: 70 06 20 01 02 B9 CA , isMulticast: false
dev:692019-07-30 21:50:52.774 debugskip: Crc16Encap(checksum:65535, command:6, commandClass:112, data:[30, 1, 2])
dev:692019-07-30 21:50:52.767 debugskip: Crc16Encap(checksum:65535, command:6, commandClass:112, data:[31, 1, 1])
dev:692019-07-30 21:50:52.763 debugparse description: zw device: 14, command: 5601, payload: 70 06 1F 01 01 60 3D , isMulticast: false
dev:692019-07-30 21:50:52.760 debugparse description: zw device: 14, command: 5601, payload: 70 06 1E 01 02 67 6E , isMulticast: false
dev:692019-07-30 21:50:52.737 debugskip: Crc16Encap(checksum:65535, command:6, commandClass:112, data:[14, 1, 1])
dev:692019-07-30 21:50:52.732 debugparse description: zw device: 14, command: 5601, payload: 70 06 0E 01 01 14 6E , isMulticast: false
dev:692019-07-30 21:50:52.722 debugskip: Crc16Encap(checksum:65535, command:6, commandClass:112, data:[2, 1, 70])
dev:692019-07-30 21:50:52.713 debugparse description: zw device: 14, command: 5601, payload: 70 06 02 01 46 59 2C , isMulticast: false
dev:692019-07-30 21:50:52.701 debugskip: Crc16Encap(checksum:65535, command:6, commandClass:112, data:[1, 1, 6])
dev:692019-07-30 21:50:52.692 debugparse description: zw device: 14, command: 5601, payload: 70 06 01 01 06 48 B8 , isMulticast: false
dev:692019-07-30 21:50:37.811 infoFibaro Dimmer is off [digital]
dev:692019-07-30 21:50:37.756 debugdimmerEvents value: 0
dev:692019-07-30 21:50:37.752 infoBasicReport value: 0
dev:692019-07-30 21:50:37.748 debugparse description: zw device: 14, command: 2003, payload: 00 , isMulticast: false
sys:12019-07-30 21:50:37.438 infoZ-Wave Discovery Stopped
sys:12019-07-30 21:50:37.435 infoZ-Wave Device Discovered: Fibaro Dimmer
dev:692019-07-30 21:50:37.425 debugrefresh
dev:692019-07-30 21:50:37.344 warnconfigure...
sys:12019-07-30 21:50:32.165 infoInitializing Z-Wave Device : 14
sys:12019-07-30 21:50:19.144 infoZ-Wave Discovery Running
