I'm trying to get my Fibaro 2 Dimmers working with Hubitat to be able to locally and via Hubitat switch them on and off, I'd also like to be able to use the second switch to switch other devices on/off via Hubitat and finally retreive power readings from the device.
I've tried the integrated one, Erocm123 and Robin Winbourne's with different results with each, so wondered what most people are using for the aboe and then I can use that one and work out my issues from there.
This is the best one by @ericm , everything works 100%. I use the button events created from the 2nd input to control my zigbee lamps and send the house to night mode and stuff.
I can turn the light On/Off using the On/Off buttons in the device page and using the light switch, however if I use the light switch the status of the device does not update to reflect the change. The power status does change to show power being used irrelevant of how the light is switched On/Off.
If I use the light switch to try to turn light off when it is On then I get the following in the log:
This particular switch is a Toggle switch, I have saved and clicked configure many times but still the same issue. I've also tried setting momentary and just doing a quick toggle of the switch but same result. I've unassociated and added again as well.
If I click Refresh from the device then the device and dashboard update correctly.
Mine is unsecure paired and it's best to not pair securely if not needed.
Try clicking save but don't click configure
There is some differences in some of the firmware I know @ericm had some issues with his at first because he had extra settings than mine, but that was corrected in the hub a while ago. What firmware and hardware are you on for the device.
Just to put my 2 pence worth in, some time ago when I was getting some errors and inconsistencies with my hub, it was recommended by support to re-pair my Fibaro dimmers in 'unsecure' mode. (They were in secure mode).
This was several builds ago though so this information may not be current.
Just thought I'd pass the info on.
Just to throw some more info out there.
Turn logging on for the device.
Set the configuration settings of the dimmer to what you want in the device on the UI.
Open another log window at the same time.
Press the B button 3 times to get it in configuration mode and then press the configure button on the UI for the device.
Do you see the config being set in the logs?
