Try to capture for a bit longer period as well so outliers will stick out more.
The links work after you replace APPID or DEVICEID with the ID in question.
Yeah, that was dumb on my part.
What do you consider "bad" in these results? I've used these and discarded a couple of apps/devices that seemed to have absurdly long runtime, but I've no measuring stick to evaluate....suggestions?
Hmm the run time is milliseconds isn't it?
S
I am only going by what I have seen. According to Lewis Heidrick, "runtime over 100 is suspect".
To further quote Lewis: (formatting edited by me)
I don't know what the real answer here is, but a few hundred millseconds at most would seem to be normal. If you think about how long it should take to sense something, contact the hub, and to process that and do an action, you are talking about maybe 500ms (1/2 second) or so. I would say 1000ms or more would be pretty ridiculous with this processor and memory, UNLESS you are involving the cloud or doing some fairly intense rule logic processing.
I do see very heavy and long processing with Echo Speaks on my hub, for example. It is the worst of any app I have. But I can see why with the heavy cloud reliance, and how large the app is, and how many app and driver codes it takes to make this app.
Even then, it doesn't seem to affect my hub, maybe because this is the only app that is so memory intensive? Everything else is a fraction of what I see compared to the Echo device and Echo app shown below.
device id 442 runcount 28 total runtime 47108 average run time 1682.4285714286
app id 309 runcount 140 total runtime 49531 average run time 353.7928571429
Other apps, like a motion lighting and it's sensor are more something like this: (stats taken a few seconds apart so they don't match how many times they have run)
device id 801 runcount 5 total runtime 46 average run time 9.2
app id 1127 runcount 2 total runtime 218 average run time 109
Thanks @neonturbo!
What you and @lewis.heidrick are stating seems to go along with what I'm seeing on my hub(s).
I ended up removing 2 apps which seemed to produce run times in the seconds, and given what they were doing, it probably made sense that they produced such long run-times. One was the Unifi gateway app, which has to parse a stupid amount of data from the Ubiquiti gateway, and I only installed it as a lark, as I don't really use presence for anything, and that was all I was getting out of that.
I also removed a Idle Node Refresher, which I installed as an experiment.
Of my remaining devices, even the long winded (Sonos) devices seem to stay under the 1 Second Mark, although the Sonos App (which ran once), seemed to take 2.7 seconds to complete. Not sure what that's about, and I'll run stats a few times over the next few days to see whether that's consistent.
Intersting stuff for sure.
S.
You have to consider what the app or device is doing to know if it's an issue. An outlet with a ton of runcounts would lead me to think power reporting is too frequent. Or say a local motion app with a very high run time, you may want to reconsider how you structure it. A motion sensor with lux enabled and a ton of runcounts would also be a good example where you could flood your mesh. Or a contact sensor with an average run time of 300 is probably a problem.
Local apps tend to have a runtime of around 150 or less and usually around 70 while cloud enabled apps can be much much higher depending on what they are doing.
If you have very high runtime apps consider what they are providing and make an educated evaluation about whether the load is worth what they are providing. Especially if it's not showing an impact on your automations. Then if you do have a problem with them in the future you have an idea of things you can disable to track down the source.
Devices on the mesh are going to be more impactful because of the bandwidth limitations of zwave and zigbee. Lan is less of an issue because it's all on the cpu, memory, and local network.
It was snappy last night at 9:30.
Fell asleep on couch. Woke up to slow world at 4:00 AM.
Restarted the Status routine, but didn't think it was/would provide anything at that point.
Stopped Status.
Rebooted the hub from the settings screen.
It started up in slow world!
Restarted Status.
Went to bed. Still in slow world at 8:30AM.
FreeOSMemory is 540652 , if that means anything.
Here is the Status log:
Device Stats enabled: true
Device stats start time: 1606556289653
Device stats total run time: 13847890
device id 175 runcount 699 total runtime 28455 average run time 40.7081545064
device id 147 runcount 702 total runtime 27776 average run time 39.5669515670
device id 116 runcount 16 total runtime 476 average run time 29.75
device id 76 runcount 20 total runtime 382 average run time 19.1
device id 46 runcount 20 total runtime 286 average run time 14.3
device id 174 runcount 18 total runtime 178 average run time 9.8888888889
device id 7 runcount 30 total runtime 568 average run time 18.9333333333
device id 33 runcount 12 total runtime 145 average run time 12.0833333333
device id 117 runcount 14 total runtime 192 average run time 13.7142857143
device id 8 runcount 12 total runtime 111 average run time 9.25
device id 42 runcount 4 total runtime 79 average run time 19.75
device id 124 runcount 1 total runtime 6 average run time 6
device id 129 runcount 1 total runtime 5 average run time 5
device id 130 runcount 1 total runtime 6 average run time 6
device id 161 runcount 40 total runtime 341 average run time 8.525
device id 98 runcount 52 total runtime 1992 average run time 38.3076923077
device id 119 runcount 2 total runtime 107 average run time 53.5
device id 114 runcount 9 total runtime 511 average run time 56.7777777778
device id 113 runcount 8 total runtime 346 average run time 43.25
device id 138 runcount 2 total runtime 133 average run time 66.5
device id 120 runcount 2 total runtime 98 average run time 49
device id 156 runcount 2 total runtime 107 average run time 53.5
device id 96 runcount 60 total runtime 851 average run time 14.1833333333
device id 97 runcount 60 total runtime 757 average run time 12.6166666667
device id 118 runcount 36 total runtime 639 average run time 17.75
device id 162 runcount 18 total runtime 241 average run time 13.3888888889
device id 160 runcount 18 total runtime 787 average run time 43.7222222222
device id 169 runcount 10 total runtime 164 average run time 16.4
device id 95 runcount 12 total runtime 348 average run time 29
device id 168 runcount 4 total runtime 28 average run time 7
device id 102 runcount 4 total runtime 98 average run time 24.5
device id 101 runcount 8 total runtime 56 average run time 7
device id 103 runcount 9 total runtime 87 average run time 9.6666666667
device id 40 runcount 2 total runtime 64 average run time 32
device id 170 runcount 2 total runtime 43 average run time 21.5
device id 123 runcount 3 total runtime 21 average run time 7
App Stats enabled: true
App stats start time: 1606556289682
App stats total run time: 13847886
app id 134 runcount 13 total runtime 1632 average run time 125.5384615385
app id 176 runcount 1 total runtime 285 average run time 285
app id 103 runcount 9 total runtime 399 average run time 44.3333333333
app id 139 runcount 67 total runtime 3158 average run time 47.1343283582
app id 144 runcount 21 total runtime 1266 average run time 60.2857142857
app id 143 runcount 18 total runtime 662 average run time 36.7777777778
app id 141 runcount 18 total runtime 892 average run time 49.5555555556
app id 140 runcount 9 total runtime 587 average run time 65.2222222222
app id 142 runcount 18 total runtime 1358 average run time 75.4444444444
app id 157 runcount 9 total runtime 349 average run time 38.7777777778
app id 153 runcount 9 total runtime 653 average run time 72.5555555556
app id 154 runcount 9 total runtime 647 average run time 71.8888888889
app id 156 runcount 14 total runtime 1190 average run time 85
app id 160 runcount 6 total runtime 418 average run time 69.6666666667
app id 167 runcount 2 total runtime 110 average run time 55
app id 148 runcount 2 total runtime 78 average run time 39
app id 118 runcount 2 total runtime 75 average run time 37.5
devices
175 and 147 are ST presence sensors, which are Zigbee, and have been working just fine.
apps
134 is for basement lights
176 is for wife's car presence
I removed direct association for the 3 devices that had it: still slow.
I added a rule to take the place of one direct association for closet lighting: still slow.
I added two rules to take the place of the two basement pseudo 3-way switches' direct association. It wouldn't 'take' at first. I went upstairs to open and close the door that trips all the light down in the basement, then tried the switches again. They then started working. The basement automation also was fast.
I went upstairs. Master bathroom still slow...although that might have been the result of the workaround I had to do because of a broken simple automation 1.1 feature, delay off after open on a contact sensor. Probably not though.
I wonder if overnight radio repair somehow screws things up for your zwave network. I've looked at the logs from your hub several times over the last few days, even ramping up log level to make sure nothing untowardly is happening. There's definitely not enough going on to explain the slowdown, yet the pattern is things grind down to a crawl overnight.
I'm going to add some sort of a switch to disable nightly radio cleanup, but in the meantime let's just have your hub reboot itself after that radio repair job runs. Below is a link to one thread with instructions to set up reboot @ 4am. This is totally a band aid, but you should have a working setup while we're putting together a solution.
Thanks very much for looking into this.
I made the 4:00AM Hub Reboot Rule, but I'm no whiz at Rule Machine. Are the quotes around the log entry okay? The example did not have them.
As I noted, when I did a "safe restart" earlier from the Settings page, things remained slow. It's still fast as when I last posted about it, but at this point I'm not optimistic, lol.
FreeOSMemory is now 494424, so it's going down, if that means anything.
There's a URL to show memory use since last reboot: /hub/advanced/freeOSMemoryHistory
But it's more of a curiosity in this case - there's plenty of free memory on the hub, and usage in general is pretty light.
Thanks. This is what the last entry looks like:
2020-11-28 18:44:00,493468,244944,106468
You can quickly test it by clicking the "Run Actions" button.
That will run the actions - if your hub reboots, you're good.
I see mine is getting pretty low every hour. Down to about 40 or 50 mb every hour.
Summary
Date/time,Free OS,Total JVM,Free JVM
2020-11-27 00:39:56,545712,250084,80876
2020-11-27 00:44:55,528048,264952,113654
2020-11-27 00:49:56,528008,264952,130045
2020-11-27 00:54:57,527832,264952,165690
2020-11-27 00:59:57,515244,264952,58005
2020-11-27 01:04:58,495328,264952,60098
2020-11-27 01:09:59,494880,264952,154100
2020-11-27 01:15:05,496512,264952,169851
2020-11-27 01:20:06,496392,264952,152570
2020-11-27 01:25:07,495724,264952,124574
2020-11-27 01:30:07,492260,264952,162902
2020-11-27 01:35:08,491612,264952,145311
2020-11-27 01:40:08,491384,264952,139615
2020-11-27 01:45:09,490856,264952,157076
2020-11-27 01:50:09,490544,264952,128532
2020-11-27 01:55:10,489880,264952,103733
2020-11-27 02:00:15,489328,264952,136927
2020-11-27 02:05:15,488800,264952,138854
2020-11-27 02:10:16,471596,264952,109279
2020-11-27 02:15:17,471348,264952,157087
2020-11-27 02:20:17,470408,264952,151749
2020-11-27 02:25:18,470496,264952,123622
2020-11-27 02:30:19,466960,264952,151321
2020-11-27 02:35:19,467024,264952,157560
2020-11-27 02:40:20,466128,264952,138522
2020-11-27 02:45:20,466232,264952,115848
2020-11-27 02:50:21,465472,264952,117927
2020-11-27 02:55:22,463252,264952,100963
2020-11-27 03:00:27,463240,264952,141432
2020-11-27 03:05:29,452264,271868,124632
2020-11-27 03:10:28,451248,271868,99720
2020-11-27 03:15:31,452212,271868,160498
2020-11-27 03:20:33,451648,271868,127918
2020-11-27 03:25:35,450884,271868,146467
2020-11-27 03:30:37,450420,271996,78587
2020-11-27 03:35:36,449448,273536,128820
2020-11-27 03:40:39,449360,273536,138667
2020-11-27 03:45:41,448952,273536,142533
2020-11-27 03:50:44,447976,273536,139370
2020-11-27 03:55:45,436160,280708,102378
2020-11-27 04:00:44,435428,280708,88896
2020-11-27 04:05:47,436776,280708,155113
2020-11-27 04:10:49,436484,280708,175235
2020-11-27 04:15:52,436308,280708,174836
2020-11-27 04:20:54,436352,280708,173093
2020-11-27 04:25:56,435464,280708,133434
2020-11-27 04:30:58,435016,280708,169918
2020-11-27 04:36:01,434484,280708,167929
2020-11-27 04:41:03,434072,280708,151612
2020-11-27 04:46:05,433944,280708,149191
2020-11-27 04:51:04,421984,280708,119252
2020-11-27 04:56:03,425096,280964,103471
2020-11-27 05:01:02,418312,280964,85398
2020-11-27 05:06:05,417660,280964,124249
2020-11-27 05:11:07,417880,280964,153474
2020-11-27 05:16:10,417588,280964,155146
2020-11-27 05:21:13,411672,280964,146785
2020-11-27 05:26:15,411572,280964,129988
2020-11-27 05:31:18,410992,280964,143558
2020-11-27 05:36:20,410468,280964,172843
2020-11-27 05:41:22,410952,280964,147341
2020-11-27 05:46:25,410476,280964,144225
2020-11-27 05:51:27,410184,280964,134327
2020-11-27 05:56:29,409464,281860,74670
2020-11-27 06:01:28,404776,285580,68255
2020-11-27 06:06:31,404904,288384,152249
2020-11-27 06:11:34,404388,288384,141386
2020-11-27 06:16:36,403684,288384,162100
2020-11-27 06:21:38,403424,288384,144202
2020-11-27 06:26:41,403080,288384,166294
2020-11-27 06:31:40,399884,288384,117580
2020-11-27 06:36:42,399796,288384,160909
2020-11-27 06:41:44,395988,288384,131159
2020-11-27 06:46:46,395772,288384,127201
2020-11-27 06:51:49,395312,288384,132432
2020-11-27 06:56:51,395416,288384,96874
2020-11-27 07:01:53,393120,288384,164692
2020-11-27 07:06:56,393768,288384,176763
2020-11-27 07:11:58,393364,288384,181517
2020-11-27 07:17:00,393248,288384,135800
2020-11-27 07:22:02,392864,288384,159110
2020-11-27 07:27:04,392024,288384,169642
2020-11-27 07:32:06,391168,288384,170424
2020-11-27 07:37:09,390844,288384,151955
2020-11-27 07:42:10,390436,288384,155795
2020-11-27 07:47:13,390344,288384,137752
2020-11-27 07:52:15,389872,288384,134198
2020-11-27 07:57:17,389248,288384,62760
2020-11-27 08:02:20,389276,288384,166517
2020-11-27 08:07:22,388588,288384,170315
2020-11-27 08:12:25,388224,288384,135135
2020-11-27 08:17:27,388220,288384,137468
2020-11-27 08:22:30,387996,288384,167702
2020-11-27 08:27:32,387304,288384,142262
2020-11-27 08:32:34,387636,288384,181785
2020-11-27 08:37:37,386852,288384,149196
2020-11-27 08:42:39,386608,288384,128553
2020-11-27 08:47:41,386348,288384,184582
2020-11-27 08:52:44,386012,288384,134793
2020-11-27 08:57:45,385616,288384,73023
2020-11-27 09:02:44,384952,288384,56301
2020-11-27 09:07:46,384800,288384,146156
2020-11-27 09:12:49,383676,288384,133681
2020-11-27 09:17:51,383272,288384,180923
2020-11-27 09:22:54,382800,288384,182716
2020-11-27 09:27:56,382576,288384,136682
2020-11-27 09:32:59,382536,288384,139052
2020-11-27 09:38:00,381796,288384,140297
2020-11-27 09:43:02,381624,288384,133733
2020-11-27 09:48:04,381860,288384,182937
2020-11-27 09:53:06,381696,288384,137963
2020-11-27 09:58:09,381440,288384,91780
2020-11-27 10:03:08,381228,288384,51077
2020-11-27 10:08:10,379332,288384,64092
2020-11-27 10:13:13,378736,288384,173448
2020-11-27 10:18:16,378112,288384,140528
2020-11-27 10:23:18,378112,288384,130639
2020-11-27 10:28:21,378244,288384,143136
2020-11-27 10:33:20,377640,288384,130156
2020-11-27 10:38:19,376540,288384,115979
2020-11-27 10:43:18,376876,288384,106842
2020-11-27 10:48:17,376072,288384,62957
2020-11-27 10:53:16,375724,288384,90759
2020-11-27 10:58:15,376360,288384,54437
2020-11-27 11:03:14,376116,288384,64428
2020-11-27 11:08:13,376268,288384,147913
2020-11-27 11:13:12,374452,288384,143928
2020-11-27 11:18:11,374084,288384,140437
2020-11-27 11:23:10,373684,288384,132250
2020-11-27 11:28:09,372904,288384,91442
2020-11-27 11:33:08,372840,288384,114873
2020-11-27 11:38:07,372768,288384,141099
2020-11-27 11:43:06,372676,288384,137016
2020-11-27 11:48:05,371892,288384,143202
2020-11-27 11:53:04,371400,288384,97767
2020-11-27 11:58:03,371612,288384,120107
2020-11-27 12:03:02,371068,288384,113402
2020-11-27 12:08:01,370660,288384,102400
2020-11-27 12:13:00,370252,288384,89297
2020-11-27 12:17:59,371100,288384,166054
2020-11-27 12:22:58,370500,288384,126159
2020-11-27 12:27:57,370276,288384,141741
2020-11-27 12:32:56,369868,288384,97555
2020-11-27 12:37:55,369028,288384,63114
2020-11-27 12:42:54,368528,288384,85196
2020-11-27 12:47:53,369660,288384,145294
2020-11-27 12:52:52,369728,288384,163266
2020-11-27 12:57:51,369348,288384,95910
2020-11-27 13:02:50,369324,288384,40582
2020-11-27 13:07:49,368068,288384,26350
2020-11-27 13:12:48,368072,288384,119519
2020-11-27 13:17:47,368092,288384,115745
2020-11-27 13:22:46,367376,288384,132525
2020-11-27 13:27:45,367900,288384,100022
2020-11-27 13:32:44,366976,288384,109540
2020-11-27 13:37:43,366352,288384,62247
2020-11-27 13:42:42,366988,288384,143793
2020-11-27 13:47:41,366944,288384,142690
2020-11-27 13:52:40,365732,288384,124000
2020-11-27 13:57:39,366524,288384,144482
2020-11-27 14:02:38,366212,288384,98429
2020-11-27 14:07:37,364912,288384,46491
2020-11-27 14:12:36,364204,288384,153856
2020-11-27 14:17:35,362572,288384,135223
2020-11-27 14:22:34,362264,288384,159996
2020-11-27 14:27:33,361040,288384,136670
2020-11-27 14:32:32,360912,288384,95824
2020-11-27 14:37:31,360468,288384,78585
2020-11-27 14:42:31,357924,288384,95074
2020-11-27 14:47:30,357764,288384,45261
2020-11-27 14:52:29,357152,288384,68750
2020-11-27 14:57:28,361964,288384,44729
2020-11-27 15:02:27,361220,288384,153047
2020-11-27 15:07:26,361068,288384,164726
2020-11-27 15:12:25,360728,288384,117957
2020-11-27 15:17:24,360524,288384,107275
2020-11-27 15:22:23,359748,288384,118818
2020-11-27 15:27:22,360680,288384,63582
2020-11-27 15:32:21,359916,288384,72107
2020-11-27 15:37:20,359872,288384,171221
2020-11-27 15:42:19,359648,288384,111792
2020-11-27 15:47:18,359716,288384,122736
2020-11-27 15:52:17,359296,288384,96760
2020-11-27 15:57:16,359732,288384,91796
2020-11-27 16:02:15,359292,288384,90112
2020-11-27 16:07:14,344468,288384,61122
2020-11-27 16:12:13,342916,288384,37631
2020-11-27 16:17:12,344000,288384,128909
2020-11-27 16:22:11,342840,288384,143019
2020-11-27 16:27:10,340536,288384,118139
2020-11-27 16:32:09,339604,288384,86736
2020-11-27 16:37:08,340584,288384,140506
2020-11-27 16:42:07,338244,288384,105987
2020-11-27 16:47:06,337620,288384,86343
2020-11-27 16:52:05,337172,288384,86604
2020-11-27 16:57:04,339248,288384,92472
2020-11-27 17:02:03,338908,288384,61457
2020-11-27 17:07:02,339124,288384,157314
2020-11-27 17:12:01,339004,288384,139438
2020-11-27 17:17:00,338596,288384,125952
2020-11-27 17:21:59,338124,288384,89714
2020-11-27 17:26:58,337788,288384,67640
2020-11-27 17:31:57,337404,288384,96414
2020-11-27 17:36:56,336780,288384,60071
2020-11-27 17:41:55,337956,288384,92993
2020-11-27 17:46:54,337152,288384,120527
2020-11-27 17:51:53,333444,288384,130409
2020-11-27 17:56:52,334712,288384,154858
2020-11-27 18:01:51,334428,288384,139408
2020-11-27 18:06:50,333820,288384,105348
2020-11-27 18:11:49,333568,288384,72083
2020-11-27 18:16:48,334396,288384,112857
2020-11-27 18:21:47,334524,288384,113493
2020-11-27 18:26:46,333996,288384,66420
2020-11-27 18:31:45,333244,288384,77778
2020-11-27 18:36:44,332852,288384,80913
2020-11-27 18:41:43,333932,288384,137223
2020-11-27 18:46:43,333596,288384,83791
2020-11-27 18:51:42,333060,288384,83138
2020-11-27 18:56:41,334596,288384,115363
2020-11-27 19:01:40,329520,288384,105613
2020-11-27 19:06:39,329028,288384,71601
2020-11-27 19:11:38,328968,288384,83426
2020-11-27 19:16:37,328332,288384,82153
2020-11-27 19:21:36,330272,288384,111516
2020-11-27 19:26:35,330400,288384,116661
2020-11-27 19:31:34,330344,288384,128613
2020-11-27 19:36:33,329912,288384,79797
2020-11-27 19:41:32,328480,288384,89709
2020-11-27 19:46:31,328180,288384,120759
2020-11-27 19:51:30,327896,288384,102694
2020-11-27 19:56:29,329728,288384,89349
2020-11-27 20:01:28,329332,288384,90240
2020-11-27 20:06:27,328268,288384,57090
2020-11-27 20:11:26,328616,288384,80628
2020-11-27 20:16:25,328532,288384,111518
2020-11-27 20:21:24,328268,288384,99939
2020-11-27 20:26:23,327756,288384,65206
2020-11-27 20:31:22,328444,288384,180457
2020-11-27 20:36:21,328544,288384,166376
2020-11-27 20:41:20,327976,288384,74832
2020-11-27 20:46:19,327540,288384,98879
2020-11-27 20:51:18,327684,288384,61233
2020-11-27 20:56:18,329436,288384,70157
2020-11-27 21:01:17,328556,288384,49595
2020-11-27 21:06:16,329376,288384,144897
2020-11-27 21:11:15,328504,288384,157667
2020-11-27 21:16:14,328584,288384,141686
2020-11-27 21:21:13,329460,288384,173093
2020-11-27 21:26:12,329040,288384,138223
2020-11-27 21:31:11,328296,288384,125137
2020-11-27 21:36:10,326992,288384,92725
2020-11-27 21:41:09,327300,288384,105165
2020-11-27 21:46:08,327104,288384,114723
2020-11-27 21:51:07,326624,288384,103934
2020-11-27 21:56:06,327620,288384,121797
2020-11-27 22:01:05,326728,288384,116510
2020-11-27 22:06:04,326504,288384,70714
2020-11-27 22:11:03,327168,288384,117327
2020-11-27 22:16:02,325844,288384,104268
2020-11-27 22:21:01,325328,288384,72779
2020-11-27 22:26:00,324288,288384,40871
2020-11-27 22:30:58,323320,288384,136267
2020-11-27 22:35:57,323364,288384,157168
2020-11-27 22:40:56,323424,288384,68340
2020-11-27 22:45:55,322544,288384,51275
2020-11-27 22:50:54,322536,288384,55307
2020-11-27 22:55:53,324428,288384,114086
2020-11-27 23:00:52,324592,288384,146522
2020-11-27 23:05:51,323592,288384,149967
2020-11-27 23:10:50,323524,288384,136873
2020-11-27 23:15:50,322744,288384,114027
2020-11-27 23:20:49,322288,288384,76967
2020-11-27 23:25:48,321780,288384,70576
2020-11-27 23:30:47,321624,288384,93633
2020-11-27 23:35:46,320960,288384,60756
2020-11-27 23:40:45,323300,288384,143116
2020-11-27 23:45:44,322828,288384,119529
2020-11-27 23:50:43,322244,288384,93465
2020-11-27 23:55:42,323148,288384,122638
2020-11-28 00:00:41,322500,288384,104364
2020-11-28 00:05:40,320104,288384,155604
2020-11-28 00:10:39,320136,288384,99842
2020-11-28 00:15:38,319836,288384,116278
2020-11-28 00:20:37,319796,288384,95951
2020-11-28 00:25:36,320508,288384,142557
2020-11-28 00:30:35,319836,288384,136549
2020-11-28 00:35:34,319308,288384,131803
2020-11-28 00:40:33,320208,288384,158193
2020-11-28 00:45:32,319576,288384,137029
2020-11-28 00:50:31,318568,288384,109341
2020-11-28 00:55:30,320256,288384,132965
2020-11-28 01:00:29,320372,288384,143970
2020-11-28 01:05:28,319544,288384,89755
2020-11-28 01:10:27,319700,288384,85349
2020-11-28 01:15:26,320412,288384,153989
2020-11-28 01:20:25,319788,288384,120191
2020-11-28 01:25:25,319584,288384,148858
2020-11-28 01:30:24,319144,288384,89930
2020-11-28 01:35:23,318804,288384,92182
2020-11-28 01:40:22,320348,288384,153768
2020-11-28 01:45:21,319284,288384,138504
2020-11-28 01:50:20,318584,288384,126049
2020-11-28 01:55:19,319452,288384,132542
2020-11-28 02:00:18,319280,288384,116800
2020-11-28 02:05:17,318468,288384,122299
2020-11-28 02:10:16,317976,288384,88875
2020-11-28 02:15:15,317704,288384,81231
2020-11-28 02:20:14,319152,288384,144726
2020-11-28 02:25:13,318856,288384,150792
2020-11-28 02:30:12,316932,288384,144041
2020-11-28 02:35:11,316100,288384,117488
2020-11-28 02:40:10,316584,288384,131280
2020-11-28 02:45:09,315928,288384,125098
2020-11-28 02:50:08,315756,288384,126220
2020-11-28 02:55:07,315424,288384,76173
2020-11-28 03:00:06,315792,288384,134120
2020-11-28 03:05:05,315368,288384,115325
2020-11-28 03:10:04,315224,288384,114316
2020-11-28 03:15:03,314904,288384,95121
2020-11-28 03:20:02,315856,288384,159432
2020-11-28 03:25:01,315744,288384,163073
2020-11-28 03:30:00,313100,288384,112718
2020-11-28 03:35:00,313732,288384,102362
2020-11-28 03:39:59,315880,288384,151636
2020-11-28 03:44:58,315020,288384,148675
2020-11-28 03:49:57,314832,288384,120529
2020-11-28 03:54:56,314196,288384,93220
2020-11-28 03:59:55,314544,288384,73516
2020-11-28 04:04:54,314352,288384,48174
2020-11-28 04:09:53,313648,288384,54444
2020-11-28 04:14:52,314376,288384,141184
2020-11-28 04:19:51,310272,288384,115390
2020-11-28 04:24:50,310092,288384,90906
2020-11-28 04:29:49,309556,288384,87072
2020-11-28 04:34:48,309368,288384,58060
2020-11-28 04:39:47,313704,288384,111891
2020-11-28 04:44:46,313604,288384,126647
2020-11-28 04:49:45,313808,288384,105913
2020-11-28 04:54:44,313732,288384,76141
2020-11-28 04:59:43,312576,288384,86737
2020-11-28 05:04:42,312164,288384,131318
2020-11-28 05:09:41,311824,288384,74358
2020-11-28 05:14:40,312004,288384,160935
2020-11-28 05:19:39,312000,288384,153516
2020-11-28 05:24:39,303836,288384,120667
2020-11-28 05:29:38,303400,288384,96022
2020-11-28 05:34:37,302884,288384,103790
2020-11-28 05:39:36,304668,288384,125113
2020-11-28 05:44:35,304772,288384,125257
2020-11-28 05:49:34,304104,288384,89760
2020-11-28 05:54:33,303556,288384,158719
2020-11-28 05:59:32,303256,288384,126394
2020-11-28 06:04:31,303484,288384,85910
2020-11-28 06:09:30,303212,288384,73126
2020-11-28 06:14:29,302948,288384,104500
2020-11-28 06:19:28,302696,288384,47781
2020-11-28 06:24:27,302164,288384,28226
2020-11-28 06:29:26,303272,288384,163230
2020-11-28 06:34:25,303048,288384,132736
2020-11-28 06:39:24,303464,288384,151384
2020-11-28 06:44:23,303108,288384,130276
2020-11-28 06:49:22,302440,288384,133017
2020-11-28 06:54:21,302292,288384,126907
2020-11-28 06:59:20,302660,288384,168925
2020-11-28 07:04:19,302436,288384,155866
2020-11-28 07:09:18,302332,288384,141823
2020-11-28 07:14:17,301848,288384,86509
2020-11-28 07:19:16,301244,288384,91360
2020-11-28 07:24:15,301156,288384,51450
2020-11-28 07:29:15,302692,288384,128536
2020-11-28 07:34:14,301536,288384,91357
2020-11-28 07:39:13,301996,288384,104366
2020-11-28 07:44:12,300524,288384,112099
2020-11-28 07:49:11,300156,288384,88670
2020-11-28 07:54:10,299916,288384,66271
2020-11-28 07:59:09,300660,288384,60140
2020-11-28 08:04:08,299628,288384,48170
2020-11-28 08:09:07,299980,288384,114182
2020-11-28 08:14:06,299888,288384,90199
2020-11-28 08:19:05,299416,288384,64445
2020-11-28 08:24:04,298956,288384,102615
2020-11-28 08:29:03,298332,288384,90438
2020-11-28 08:34:02,298060,288384,75566
2020-11-28 08:39:01,299792,288384,78897
2020-11-28 08:44:00,299668,288384,70167
2020-11-28 08:48:59,298824,288384,52030
2020-11-28 08:53:58,300392,288384,138520
2020-11-28 08:58:57,300360,288384,94729
2020-11-28 09:03:56,300276,288384,78209
2020-11-28 09:08:55,299792,288384,65635
2020-11-28 09:13:54,298084,288384,142834
2020-11-28 09:18:53,297864,288384,121192
2020-11-28 09:23:52,298868,288384,100084
2020-11-28 09:28:51,297948,288384,74618
2020-11-28 09:33:50,297668,288384,97528
2020-11-28 09:38:50,298424,288384,114462
2020-11-28 09:43:49,296976,288384,76861
2020-11-28 09:48:48,296088,288384,66372
2020-11-28 09:53:47,296080,288384,80043
2020-11-28 09:58:46,294292,288384,95129
2020-11-28 10:03:45,294408,288384,98297
2020-11-28 10:08:44,293944,288384,107222
2020-11-28 10:13:43,294608,288384,159929
2020-11-28 10:18:42,291380,288384,87565
2020-11-28 10:23:41,291056,288384,66669
2020-11-28 10:28:40,290668,288384,50444
2020-11-28 10:33:39,294488,288384,140945
2020-11-28 10:38:38,294668,288384,83865
2020-11-28 10:43:37,294080,288384,95250
2020-11-28 10:48:36,293616,288384,66538
2020-11-28 10:53:35,294248,288384,171720
2020-11-28 10:58:34,293976,288384,101885
2020-11-28 11:03:33,293536,288384,66409
2020-11-28 11:08:32,293740,288384,164425
2020-11-28 11:13:31,293524,288384,119839
2020-11-28 11:18:30,292936,288384,131136
2020-11-28 11:23:29,294096,288384,89436
2020-11-28 11:28:28,293376,288384,88542
2020-11-28 11:33:27,293372,288384,55411
2020-11-28 11:38:27,294032,288384,94367
2020-11-28 11:43:26,293608,288384,63707
2020-11-28 11:48:25,290476,288384,114070
2020-11-28 11:53:24,290236,288384,70043
2020-11-28 11:58:23,293492,288384,50894
2020-11-28 12:03:22,293364,288384,163860
2020-11-28 12:08:21,291148,288384,101987
2020-11-28 12:13:20,290860,288384,95257
2020-11-28 12:18:19,290548,288384,100420
2020-11-28 12:23:18,290368,288384,56474
2020-11-28 12:28:17,292904,288384,157654
2020-11-28 12:33:16,292844,288384,114415
2020-11-28 12:38:15,293436,288384,108768
2020-11-28 12:43:14,293052,288384,87771
2020-11-28 12:48:13,292928,288384,85126
2020-11-28 12:53:12,292400,288384,47322
2020-11-28 12:58:11,293160,288384,131570
2020-11-28 13:03:10,291852,288384,115732
2020-11-28 13:08:09,290892,288384,85054
2020-11-28 13:13:08,290396,288384,91201
2020-11-28 13:18:07,291212,288384,140184
2020-11-28 13:23:06,286908,288384,123069
2020-11-28 13:28:05,286644,288384,115956
2020-11-28 13:33:04,286664,288384,55094
2020-11-28 13:38:03,289408,288384,152063
2020-11-28 13:43:03,289224,288384,95571
2020-11-28 13:48:02,286852,288384,107391
2020-11-28 13:53:01,287392,288384,75450
2020-11-28 13:58:00,289232,288384,135940
2020-11-28 14:02:59,289340,288384,150555
2020-11-28 14:07:58,288644,288384,110845
2020-11-28 14:12:57,288196,288384,65774
2020-11-28 14:17:56,284968,288384,85687
2020-11-28 14:22:55,284616,288384,77260
2020-11-28 14:27:54,284124,288384,45895
2020-11-28 14:32:53,289148,288384,165810
2020-11-28 14:37:52,289136,288384,141937
2020-11-28 14:42:51,288980,288384,154023
2020-11-28 14:47:50,285012,288384,122367
2020-11-28 14:52:49,285892,288384,121507
2020-11-28 14:57:48,289264,288384,96028
2020-11-28 15:02:47,289576,288384,44797
2020-11-28 15:07:46,289036,288384,67485
2020-11-28 15:12:45,289172,288384,142724
2020-11-28 15:17:44,289256,288384,137809
2020-11-28 15:22:43,286448,288384,101807
2020-11-28 15:27:42,286412,288384,83630
2020-11-28 15:32:41,286828,288384,80914
2020-11-28 15:37:41,288632,288384,112380
2020-11-28 15:42:40,288728,288384,130870
2020-11-28 15:47:39,288532,288384,103832
2020-11-28 15:52:38,289136,288384,73003
2020-11-28 15:57:37,288920,288384,148920
2020-11-28 16:02:36,289160,288384,129254
2020-11-28 16:07:35,288728,288384,134202
2020-11-28 16:12:34,287860,288384,85634
2020-11-28 16:17:33,288736,288384,95314
2020-11-28 16:22:32,286548,288384,99035
2020-11-28 16:27:31,286564,288384,103136
2020-11-28 16:32:30,286692,288384,70218
2020-11-28 16:37:29,288432,288384,118784
2020-11-28 16:42:28,288708,288384,141938
2020-11-28 16:47:27,288084,288384,108654
2020-11-28 16:52:26,288148,288384,75539
2020-11-28 16:57:25,288572,288384,130842
2020-11-28 17:02:24,284324,288384,129029
2020-11-28 17:07:23,284364,288384,108027
2020-11-28 17:12:22,284412,288384,101802
2020-11-28 17:17:21,288460,288384,175001
2020-11-28 17:22:20,288436,288384,141323
2020-11-28 17:27:19,288356,288384,151351
2020-11-28 17:32:18,288148,288384,98272
2020-11-28 17:37:18,288668,288384,101102
2020-11-28 17:42:17,287888,288384,127936
You're getting down to half the freeos than what you started with. Again, for whatever that means.
Didn't do anything. I'll fiddle with the log I guess.
I use Ogewon's HTTP momentary switch and just call the switch in RM or whatever.
Use the push custom command
Here's the rule in RM4.
You should get something in your log like this when it's rebooting.
Must be hourly database cleanup job. These numbers are just before garbage collector runs.
The hub tends to get to a steady state after about a day, and yes, memory drop-off right after startup is pretty steep.
Don't overthink it. That my job
