I'm gonna say no. It's not like it's all contact sensors...even motion is affected.
However, one closet does have a motion detector directly associated with a switch for a light. I also have a couple of directly associated switches in the basement for 3-way purpose. They are reliable.
I'd like to make some of those Ecolink sensors directly associated as well, but haven't found a way.
Do you have a basic time based automation, or any automations you run on a schedule? Just curious really, I think if we could isolate a case that works it might point us to why the others don't. Personally, I've experienced specific rules (Motion lighting with some of the built in conditionjs) that I could never get to to work, but I have other automations that work first time, every time.
So try to automate a simple light switch (zwave or zigbee) or plug to come on and go off on a set (periodic) schedule, and see what happens.
I have a floor lamp plugged into a switched outlet that comes on at sundown. I haven't noticed screwing up except around the daylight saving time switch, as I recall. As I've said, these rules work: you just have to wait for them....sometimes.
I found three links: enable, disable, and report. It didn't seem like it provided anything useful. I might have not let it run long enough or I had the wrong links:
You can either browse your devices, or go to (your hub's IP)/device/edit/175 or /device/edit/147
You also may want to let this run for a while and see if anything slows or shows changes over time. I wouldn't let it run continuously, but I don't think letting it go for maybe an hour will hurt.
