I think I would be too. But this isn't normal. Something is sure causing you issues. ![]()
@velvetfoot, for sure man, I’d be fed up too.
Just a thought though ... you’re not doing too much pairing, too quickly eh ?
Since I got a Zwave stick and started Zniffing, I’ve been able to actually SEE how much chatter and communication is going on and it’s way more than I thought. Messages are being sent by Hub and Devices when I figured there was none and I convinced I used to make changes too quickly and screwed things up. Probably both Hub and Devices not getting complete messages etc.
So it caused me to “let things be” for a few hours after pairing 3-4 devices.
It sounds terribly time consuming but I limited pairing Zwave devices to no more than 6-8 per day. Zigbee seems more resilient (IMHO) and I’ve been able to add 12 devices at once.
I broke the installation down into zones and made sure that each zone was communicating and working before adding another.
Garage was first. Simple lighting and door.
Once that was sorted, I did just the light control (switches and sensors) in 2 x gnd floor bedrooms. Etc.
Zwave - you Must pair some repeater devices first and work outwards. then grab a couple of beers and come back to it tomorrow.
Also I’ve found in-wall repeaters like Fibaro do not have great range due to building materials muting the radio signals.
My external Zigbee repeaters have WAY more range.
Sorry there’s no magic wand but slow, steady and methodically worked for me.
All the best
I followed the guidelines.
All devices are at 100kbps, except for the water sensors and a contact at 40.
I added 2 Ring Extenders last week to shore up a couple weak points in my mesh and it took a little over 72 hours for the routes to renegotiate completely.
Thanks for the good wishes.
Might have to try Zniffing.
Perhaps Zigbee would've been better, but at this point I have a house full of zwave switches.
Z-wave is only about 300ms slower than zigbee and the lower frequency generally helps with wall/obstacle penetration. The 10-second delay you speak of sounds more like something going on with your mesh. Can you post a screenshot of your settings, zwave details?
What model of hub do you have? What version of hub firmware are you running? 2.2.4.148? Any errors or busy messages in the logs?
Z-Wave Details
Z-Wave Radio Devices
Node Stats Status Clusters Device Security Route
| Node | Stats | Status | Clusters | Device | Security | Route |
| 0x07 (007) | PER: 0, RTT Avg: ms, LWR RSSI: | |||||
| Neighbors: 37, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | 2nd Flr Lndg | None | 01 -> 07 100kbps |
| 0x11 (017) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 17, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Back Porch | None | 01 -> 11 100kbps |
| 0x24 (036) | PER: 0, RTT Avg: 4ms, LWR RSSI: 20dB | ||
| Neighbors: 64, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Brzwy F Coach | None | 01 -> 24 100kbps |
| 0x7F (127) | PER: 24, RTT Avg: 1ms, LWR RSSI: -3dB | ||
| Neighbors: 37, Route Changes: 1 | OK |
| in: 0x5E, 0x86, 0x72, 0x73, 0x80, 0x71, 0x85, 0x59, 0x84, 0x30, 0x70, out: 0x20 | Brzwy Garage Door | None | 01 -> 26 -> 7F 40kbps |
| 0x85 (133) | PER: 0, RTT Avg: 1ms, LWR RSSI: -5dB | ||
| Neighbors: 43, Route Changes: 1 | OK |
| in: 0x5E, 0x85, 0x59, 0x55, 0x86, 0x72, 0x5A, 0x73, 0x98, 0x9F, 0x71, 0x30, 0x70, 0x6C, 0x7A, out: | Brzwy Motion | None | 01 -> 85 100kbps |
| 0x27 (039) | PER: 0, RTT Avg: 4ms, LWR RSSI: 29dB | ||
| Neighbors: 17, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Brzwy OH | None | 01 -> 23 -> 27 100kbps |
| 0x2A (042) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 53, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Brzwy R Coach | None | 01 -> 2A 100kbps |
| 0x44 (068) | PER: 0, RTT Avg: 1ms, LWR RSSI: 5dB | ||
| Neighbors: 36, Route Changes: 1 | OK |
| in: 0x5E, 0x85, 0x59, 0x55, 0x86, 0x72, 0x5A, 0x73, 0x98, 0x9F, 0x6C, 0x7A, 0x80, 0x84, 0x71, 0x70, 0x31, out: | Brzwy R Motion | None | 01 -> 44 100kbps |
| 0x1C (028) | PER: 0, RTT Avg: 3ms, LWR RSSI: 3dB | ||
| Neighbors: 61, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Bsmt Left | None | 01 -> 1C 100kbps |
| 0x1B (027) | PER: 0, RTT Avg: 5ms, LWR RSSI: 5dB | ||
| Neighbors: 64, Route Changes: 4 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Bsmt Middle | None | 01 -> 1B 40kbps |
| 0x81 (129) | PER: 0, RTT Avg: 1ms, LWR RSSI: | ||
| Neighbors: 39, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Bsmt Middle (no load) | None | 01 -> 81 100kbps |
| 0x23 (035) | PER: 0, RTT Avg: 1ms, LWR RSSI: 4dB | ||
| Neighbors: 59, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Bsmt Right | None | 01 -> 23 100kbps |
| 0x80 (128) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 27, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Bsmt Right (no load) | None | 01 -> 80 100kbps |
| 0x47 (071) | PER: 16, RTT Avg: 26ms, LWR RSSI: | ||
| Neighbors: 37, Route Changes: 2 | OK |
| in: 0x5E, 0x86, 0x72, 0x73, 0x80, 0x71, 0x85, 0x59, 0x84, 0x30, 0x70, out: 0x20 | Bsmt Top Door | None | 01 -> 47 100kbps |
| 0x46 (070) | PER: 0, RTT Avg: 5ms, LWR RSSI: | ||
| Neighbors: 38, Route Changes: 1 | OK |
| in: 0x5E, 0x26, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x22, 0x7A, out: | DR Chandelier | None | 01 -> 46 100kbps |
| 0x06 (006) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 39, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Entrance | None | 01 -> 06 100kbps |
| 0x7D (125) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 42, Route Changes: 0 | OK |
| in: 0x5E, 0x26, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x22, 0x7A, out: | Fireplace | None | 01 -> 7D 100kbps |
| 0x09 (009) | PER: 0, RTT Avg: 2ms, LWR RSSI: 6dB | ||
| Neighbors: 62, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Front Porch | None | 01 -> 09 100kbps |
| 0x26 (038) | PER: 0, RTT Avg: 11ms, LWR RSSI: 26dB | ||
| Neighbors: 21, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Garage | None | 01 -> 23 -> 38 -> 26 100kbps |
| 0x7B (123) | PER: 0, RTT Avg: 1ms, LWR RSSI: -8dB | ||
| Neighbors: 28, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Garage Coach | None | 01 -> 7B 100kbps |
| 0x2B (043) | PER: 0, RTT Avg: 1ms, LWR RSSI: | ||
| Neighbors: 46, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x8E, 0x59, 0x55, 0x86, 0x72, 0x5A, 0x73, 0x70, 0x60, 0x9F, 0x6C, 0x7A, out: | Garage Door Relays | None | 01 -> 2B 100kbps |
| 0x4B (075) | PER: 24, RTT Avg: 2100ms, LWR RSSI: 1dB | ||
| Neighbors: 35, Route Changes: 5 | OK |
| in: 0x5E, 0x86, 0x72, 0x73, 0x80, 0x71, 0x85, 0x59, 0x84, 0x30, 0x70, out: 0x20 | Garage Door Tilt-Left | None | 01 -> 09 -> 4B 40kbps |
| 0x4C (076) | PER: 8, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 33, Route Changes: 0 | FAILED |
| in: 0x5E, 0x86, 0x72, 0x73, 0x80, 0x71, 0x85, 0x59, 0x84, 0x30, 0x70, out: 0x20 | Garage Door Tilt-Middle | None | |
| 0x4D (077) | PER: 24, RTT Avg: 1ms, LWR RSSI: 5dB | ||
| Neighbors: 33, Route Changes: 1 | OK |
| in: 0x5E, 0x86, 0x72, 0x73, 0x80, 0x71, 0x85, 0x59, 0x84, 0x30, 0x70, out: 0x20 | Garage Door Tilt-Right | None | 01 -> 2E -> 4D 40kbps |
| 0x45 (069) | PER: 0, RTT Avg: 2ms, LWR RSSI: 44dB | ||
| Neighbors: 31, Route Changes: 2 | OK |
| in: 0x5E, 0x85, 0x59, 0x55, 0x86, 0x72, 0x5A, 0x73, 0x98, 0x9F, 0x6C, 0x7A, 0x80, 0x84, 0x71, 0x70, 0x31, out: | Garage Motion-Outside | None | 01 -> 24 -> 45 40kbps |
| 0x4A (074) | PER: 7, RTT Avg: 1ms, LWR RSSI: 0dB | ||
| in: 0x5E, 0x86, 0x72, 0x73, 0x80, 0x71, 0x85, 0x59, 0x84, 0x30, 0x70, out: 0x20 | GBath Door | None | 01 -> 4A 100kbps |
| 0x37 (055) | PER: 0, RTT Avg: 1ms, LWR RSSI: | ||
| Neighbors: 58, Route Changes: 1 | OK |
| in: 0x5E, 0x72, 0x5A, 0x73, 0x27, 0x25, 0x2B, 0x2C, 0x70, 0x86, 0x71, 0x60, 0x8E, 0x85, 0x59, 0x7A, 0x56, out: | GBath Fan | None | 01 -> 37 100kbps |
| 0x36 (054) | PER: 0, RTT Avg: 19ms, LWR RSSI: | ||
| Neighbors: 53, Route Changes: 2 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | GBath OH | None | 01 -> 0C -> 36 9.6kbps |
| 0x38 (056) | PER: 0, RTT Avg: 1ms, LWR RSSI: | ||
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | GBath Vanity | None | 01 -> 38 100kbps |
| 0x3D (061) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 38, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | GBed Closet | None | 01 -> 3D 100kbps |
| 0x3C (060) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 62, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | GBed OH | None | 01 -> 3C 100kbps |
| 0x3B (059) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | GBed Outlets | None | 01 -> 0C -> 3B 100kbps |
| 0x18 (024) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 64, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Kit Island | None | 01 -> 18 100kbps |
| 0x10 (016) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Kit OH | None | 01 -> 10 100kbps |
| 0x16 (022) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 61, Route Changes: 0 | OK |
| in: 0x5E, 0x26, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x22, 0x7A, out: | Kit Recessed | None | 01 -> 16 100kbps |
| 0x1A (026) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Kit Sink | None | 01 -> 1A 100kbps |
| 0x7E (126) | PER: 0, RTT Avg: 1ms, LWR RSSI: | ||
| Neighbors: 44, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | LR Outlets | None | 01 -> 7E 100kbps |
| 0x49 (073) | PER: 26, RTT Avg: 8ms, LWR RSSI: | ||
| Neighbors: 35, Route Changes: 1 | OK |
| in: 0x5E, 0x86, 0x72, 0x73, 0x80, 0x71, 0x85, 0x59, 0x84, 0x30, 0x70, out: 0x20 | MBath Door | None | 01 -> 49 100kbps |
| 0x33 (051) | PER: 0, RTT Avg: 1ms, LWR RSSI: 18dB | ||
| Neighbors: 27, Route Changes: 1 | OK |
| in: 0x5E, 0x72, 0x5A, 0x73, 0x27, 0x25, 0x2B, 0x2C, 0x70, 0x86, 0x71, 0x60, 0x8E, 0x85, 0x59, 0x7A, 0x56, out: | MBath Fan | None | 01 -> 33 100kbps |
| 0x32 (050) | PER: 0, RTT Avg: 4ms, LWR RSSI: 9dB | ||
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | MBath OH | None | 01 -> 32 100kbps |
| 0x31 (049) | PER: 0, RTT Avg: 2ms, LWR RSSI: 14dB | ||
| Neighbors: 57, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | MBath Vanity | None | 01 -> 31 100kbps |
| 0x30 (048) | PER: 0, RTT Avg: 1ms, LWR RSSI: 17dB | ||
| Neighbors: 63, Route Changes: 1 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | MBed Closet | None | 01 -> 30 100kbps |
| 0x84 (132) | PER: 0, RTT Avg: 1ms, LWR RSSI: 20dB | ||
| Neighbors: 42, Route Changes: 1 | OK |
| in: 0x5E, 0x85, 0x59, 0x55, 0x86, 0x72, 0x5A, 0x73, 0x98, 0x9F, 0x71, 0x30, 0x70, 0x6C, 0x7A, out: | MBed Closet Motion | None | 01 -> 84 100kbps |
| 0x2F (047) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 58, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | MBed OH | None | 01 -> 2F 100kbps |
| 0x2E (046) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 54, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | MBed Outlets | None | 01 -> 2E 100kbps |
| 0x3A (058) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 59, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Office OH | None | 01 -> 3A 100kbps |
| 0x39 (057) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Office Outlets | None | 01 -> 39 100kbps |
| 0x0D (013) | PER: 0, RTT Avg: 1ms, LWR RSSI: | ||
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Pantry | None | 01 -> 0D 40kbps |
| 0x48 (072) | PER: 8, RTT Avg: 1ms, LWR RSSI: | ||
| in: 0x5E, 0x86, 0x72, 0x73, 0x80, 0x71, 0x85, 0x59, 0x84, 0x30, 0x70, out: 0x20 | Pantry Door | None | |
| 0x0C (012) | PER: 0, RTT Avg: 2ms, LWR RSSI: 15dB | ||
| in: 0x5E, 0x72, 0x5A, 0x73, 0x27, 0x25, 0x2B, 0x2C, 0x70, 0x86, 0x71, 0x60, 0x8E, 0x85, 0x59, 0x7A, 0x56, out: | Pantry Hall | None | 01 -> 0C 100kbps |
| 0x0E (014) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Pwdr Rm OH | None | 01 -> 0E 100kbps |
| 0x0F (015) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x5E, 0x72, 0x5A, 0x73, 0x27, 0x25, 0x2B, 0x2C, 0x70, 0x86, 0x71, 0x60, 0x8E, 0x85, 0x59, 0x7A, 0x56, out: | Pwdr Rm Vnty | None | 01 -> 0F 100kbps |
| 0x13 (019) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 18, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x59, 0x86, 0x72, 0x55, 0x5A, 0x73, 0x5B, 0x9F, 0x6C, 0x70, 0x2C, 0x2B, 0x22, 0x7A, out: | Rear Floods | None | 01 -> 13 100kbps |
| 0x7C (124) | PER: 0, RTT Avg: 1ms, LWR RSSI: | ||
| in: 0x86, 0x72, 0x85, 0x84, 0x80, 0x70, 0x9C, 0x20, 0x71, out: | Water: Powder Rm Washer | None | 01 -> 7C 40kbps |
| 0x69 (105) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 38, Route Changes: 0 | FAILED |
| in: 0x86, 0x72, 0x85, 0x84, 0x80, 0x70, 0x9C, 0x20, 0x71, out: | Water: Dishwasher | None | |
| 0x75 (117) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x86, 0x72, 0x85, 0x84, 0x80, 0x70, 0x9C, 0x20, 0x71, out: | Water: GBath Toilet | None | 01 -> 75 40kbps |
| 0x72 (114) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x86, 0x72, 0x85, 0x84, 0x80, 0x70, 0x9C, 0x20, 0x71, out: | Water: GBath Vanity | None | 01 -> 72 40kbps |
| 0x6F (111) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x86, 0x72, 0x85, 0x84, 0x80, 0x70, 0x9C, 0x20, 0x71, out: | Water: Kitchen Sink | None | 01 -> 6F 40kbps |
| 0x76 (118) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x86, 0x72, 0x85, 0x84, 0x80, 0x70, 0x9C, 0x20, 0x71, out: | Water: MBath Toilet | None | 01 -> 81 -> 0C -> 76 40kbps |
| 0x78 (120) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x86, 0x72, 0x85, 0x84, 0x80, 0x70, 0x9C, 0x20, 0x71, out: | Water: MBath Vanity | None | 01 -> 78 40kbps |
| 0x4F (079) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x86, 0x72, 0x85, 0x84, 0x80, 0x70, 0x9C, 0x20, 0x71, out: | Water: Powder Rm Toilet/Sink | None | 01 -> 4F 40kbps |
| 0x68 (104) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| in: 0x86, 0x72, 0x85, 0x84, 0x80, 0x70, 0x9C, 0x20, 0x71, out: | Water: Refrigerator | None | 01 -> 68 40kbps |
| 0x2C (044) | PER: 0, RTT Avg: ms, LWR RSSI: | ||
| Neighbors: 55, Route Changes: 0 | OK |
| in: 0x5E, 0x25, 0x85, 0x8E, 0x59, 0x55, 0x86, 0x72, 0x5A, 0x73, 0x70, 0x60, 0x9F, 0x6C, 0x7A, out: | WaterCop Relays | None | 01 -> 2C 100kbps |
| 0x74 (116) | PER: 6, RTT Avg: 1ms, LWR RSSI: 24dB | ||
in: 0x5E, 0x86, 0x72, 0x73, 0x80, 0x71, 0x85, 0x59, 0x84, 0x30, 0x70, out: 0x20 Wood Insert High Temp None 01 -> 74 100kbps
Can you use this option to hide your long Z-Wave table post...makes it easier for others to scroll through the thread. Highlight the content and choose the Hide Details option.
this sounds similiar to the issues others are seeing with automations with contact/motion and lights very delayed turning on. See the other threads.
It mostly happens when it's been lying idle, like overnight, typically. Today it was fast in the morning, then real slow later after being away 3 hours.
It's a C7 on 2.2.4.148.
No errors in text logging. I usually don't have debug logging on. I'd have to turn it on for all devices, apps.
Pretty much all my lighting rules trigger off motion or contact and I haven't seen any delays. I've been doing safe shutdowns with a power disconnect after each update though and the updates have been coming like once a day or so. Maybe the issue needs more than a day to show up?
Nothing like waking up in the morning and waiting 16 seconds for the bathroom lights to turn on.
Bear in mind, operation from the dashboard is nice and snappy. The rules are what's slow.
I'm no genius, but I wonder if I'm on to something.
First: C7, 2.2.4.148
The system is running slow this morning, so I thought I'd try something.
I tried removing Apps.
First one was Notifications: No effect.
Second was Rule Machine: No effect.
Third was Dashboards: BIG EFFECT-Everything was fast
Only things left in Apps were Simple Automation and Zooz Garage Door Opener.
Not sure how to proceed next.
Previously, I noticed in App settings that Dashboard had HSM enabled, or something like that. I've never touched HSM.
I think I'll try adding the Dashboard app back in, with a blank slate and see what happens.
Now that the mesh is fast again, there won't be any immediate cause and effect - would have to wait til next morning, in all likelihood, or some period of inactivity.
Here's hoping restore from backup works, lol.
I take it back.
Still slow upstairs.
edit: And weird behavior downstairs as well.
Pantry light wasn't coming on upon opening of door.
Opened basement door, pantry light came on (as well as fast reaction from basement).
Now pantry light fast acting.
edit: Just floundering.
OK, one question. When you "Add Dashboard" do you click the checkbox that says "toggle All on/off" in the device selection box for the dashboard?
If you do. Don't. Each dashboard should have visible to it only the devices you intend to use in it.
You may be already aware of that, but just in case, I thought it worth mentioning.
S.
How very serendipitous.
I just restored, (thankfully, it seems to have worked), and things are slower again.
It did occur to me, 'why are all those other dashboards using this device?'
So, this is going to be my next step!
I upgraded from 2.2.4.145 to 2.2.4.148 yesterday and had my hub lock up twice, the first was after about 4 hours and the second was overnight so probably about that but am not sure. Each required a hard power reset to recover. There are no errors in the logs from apps or anything else just prior - things just seem to stop.
The same config is rock solid on 145 so I’m running that again for now. As another datapoint, while I have a couple of dashboards set up I don’t use “all devices” on them and I rarely access the dashboards (mostly use homekit or voice assistant for control when I need it).
Yup - some relases back that was the default setting, happily they changed that in a late 2.2.3 release or early in 2.2.4.
Didn't seem to help, but again, it's hard to tell.
It's like it goes to sleep and takes a while to wake up.
