This review is outdated. Since this review was posted Zooz came out with an improved unit. I've not tested the new one.
This is a mini "review" of the above mentioned sensor or perhaps better stated as my short lived experience with this device.
I purchased the ZSE29 sensor to detect deer in the area of our Arborvitae. Apparently deer find them quite tasty.
I figured an "outdoor sensor" could be mounted er.. outdoors. Not so, read on....
The sensor looks like they took an outdoor motion sensor "head" normally found mounted to an outdoor light fixture, and mounted it on a base similar to many web cams. The instructions say:
"Mounting: Find a sheltered area within Z-Wave range to install the sensor. It should be a clean flat surface without direct sunshine or rain exposure (a little drizzle is fine)"
The sensor body has screwdriver operated "lux" and "on time" adjustments. These are nearly identical to several motion sensor exterior lights (no Z-Wave) I have on the back of my home.
The base bottom plate (to access the batteries) is not sealed in any way. Plastic on plastic, with a small groove.
UPDATE: On closer look, there is an elastomer gasket on the bottom plate where it contacts the housing. You can "feel" the resilience when screwing the bottom plate on.
Paring with HE: Easy, no issues at all.
Operation:
Responds to motion quickly, with fractions of a second between moving my hand in front of the sensor and the HE device page reporting "Active". For this test the sensor was 3 meters from the hub.
On activation, a red LED behind the lens illuminates the upper left corner of the lens for a few seconds.
I wanted to turn off the LED, I assumed this would be a Z-Wave accessible parameter... again not so. To find the correct parameter I wrote an email to Zooz. Their response was:
This is a very basic motion sensor, and there are no advanced parameters to adjust from the Hubitat interface itself. Only the motion timer and lux sensor can be adjusted physically from the device itself. Are you experiencing any issues with the device in particular?
In summary:
Largest drawback is the lack of true "outdoor' capability. Note, the Zooz website shows this item mounted to the side of a house with no visible protection from sun or rain. Although not stated in the advertising, I had the expectation of more control through Z-Wave accessible parameters.
I feel "mislead" by the lack of advertised outdoor capability. Perhaps if the LED could be disabled I might use.
UPDATE2: I heard back from Zooz tech support and they explained the LED can / will be shutoff by moving the retrigger time and Lux level off the minimum.
With this new information I will be keeping this sensor.
