I'm one of "those users" who made the jump to Node-RED so can recommend that as an alternative for people interested in a more visually based / flow style approach that also helps reduce overhead on the hub itself. ymmv of course..
Having said that the quickest and easiest way to controlling home automation in HE by far is RM and it's lighter weight siblings..
I don't think the driver itself got updated in 2.2.9, but I'm admittedly not sure... There was mention about a fix for some input relays in the release notes, but I don't believe any additional functionality was added to the driver in terms of exposing more parameters.
@mychristopher in case it is helpful, I have captured some screenshots that show how to create a rule that will open the garage door when a virtual switch is turned on. The virtual switch should be accessible from simple rules. You can create a similar rule for closing the garage door when the virtual switch is turned off.
I certainly appreciate you taking the time to mock that up. I've been fighting wanting to learn full on rule engine vs staying with simple rules. My intial thoughts were the less apps and things installed on the Hubitat the more efficient it would be, so I didn't want to install rule engine just for one rule. I'll throw it on there later and toy around. Again, thank you for taking the time to do that.
Good stuff -- I think you'll dig it! Don't be frustrated by the learning curve - I know it can be intimidating at first, but just be patient and ask questions here in the community.
Once I embraced Rule Machine, it opened up so many more doors to do cool things with HE. Heck, you got this powerful lil device, why not use all the advantages it offers?
I too was concerned about stressing out hub efficiency/overhead, but don't sweat that at all -- unless you get into some really crazily complex stuff or horrendously inefficient automations, it's a non-issue.
Hi Christopher, happy to help out in any way I can.
I started out with simple rules. Once I got the hang of Rule Machine, I actually took the time to convert many of my rules to Rule Machine because it was actually simpler to use once I understood it.
Also take a look at button controller for managing responses to buttons.
At this point I am down to 2 "simple rules" -- the rest are either in Rule Machine or Button Controller.
Guys, thanks for the offers. I'm going to give it a shot. So, i've attached an image. Before I activate it, am I on the right track?
I want the kitchen sink light to turn on when there is motion, then turn off 1 minute after the motion stops. However, I only want this to happen between 5 minutes before sunset and 5 mintues after sunrise...
So, here's where I guess we get into something big.
My simple rule is to notify me if someone leaves the fridge open. As you can see, if the sensor is left open for 3 minutes, it does the action. On the Rule Machine, I guess is a little more complicated. Would you mind nudging me towards how to cancel the action if the sensor closes prior to the 3 minutes? Thank you!
Hi Christopher, you fridge sensor rule is headed in the right direction. I think that my original reply to you was as clear as mud, so instead I have created a new post further down this thread that I think will make it clearer. Leaving the old post here in case it provided any value for you.
Marc
When you create (or edit) the 2 delayed actions, you will want to turn on the option that marks it as "cancelable". (See screen shot) My understanding is that if you don't do this, the "Cancel delayed actions" won't achieve the outcome you are looking for.
My approach is to unconditionally issue the "cancel delayed actions" as the first statement in the action. This way, any time this rule is triggered by an event, it will be the only instance of the rule running and you don't have to worry about what the impact might be of other instances that might be waiting in the background on a "delay". In an ideal world this should not be necessary, but I can think of scenarios that could result in 2 "On" events arriving in succession without an "Off" event in between. If you take this approach, you no longer need the "cancel delayed actions" in the else section of your if-then-else.
I believe you need to add an "off Announce-FridgeOpen" statement in the else section of your if-then-else.
Hope this helps!
Marc
Toggling the "Cancelable?" switch circled in red below....
Hi Christopher, here is my feedback on the kitchen motion rule;
You can use a "Predicate condition" (see screenshot below) to limit the rule to only running during the timeframe you want. When a rule has a predicate condition, the rule is only eligible to run if the condition is true.
As per my feedback on your "Fridge door sensor" rule, I would do a "cancel delayed actions
as the very first thing when the rule runs.
I haven't used the timeout on a "wait for event" rule, but if it has the option to mark it as "Cancelable", you should do so.
Thank you. Now I know I'm not the only one. I received mine last night and use the Basic Z-Wave Tools to set parameters 6 and 8 to auto shut off the relay (and parameters 15 and 17 to change the duration to seconds), however, I can't get it to work. The only thing I can guess is it is something in the driver. I'm using firmware version 1.03.
As a temp fix I created a basic rule to turn the relay off after one second, but I prefer it to be performed at the hardware level.
AFAIK, 1.04 is the latest firmware for the Z17 - I'm not sure if that has anything directly to do with the params not sticking, but may be nice to get overall.
I was able to get those parameters to stick via the Basic Z-Wave Tool, but I can't recall the exact step sequence I used... I don't use that tool enough to be fluent, so I end up doing a lot of trial-&-error each time I use it. But I somehow did successfully get that auto-off set up for 1 second.
After all that effort, I ended up using the Zooz Garage Door app to get a nice-looking tile for the dashboard, and that app has a relay auto-off option built into it to (can be enabled or disabled), so if you can't get those params to stick, that's another option to consider.
Though that Zooz Garge Door app is written for the Z16, it works great for the Z17 too.
@hydro311, Thanks! I will look into that. I also sent an email to Zooz.
From looking at the log while using the Basic Z-Wave Tool everything looks good. Same when I request the parameter information from the device. I've tried rebooting the hub and power cycling the device several times. I have created a rule for the relay to auto open after one second, but things like this make me wonder.
Hi all, just wired mine up to 2x garage doors and reed switches. Everything seems to work fine when I manually trigger from the HE Device UI (doors open and close, sensors read correct values) but am struggling to connect this to dashboard UI. From what I've worked out the general strategy is to create a virtual garage door device for each physical door, then use rules to connect the virtual device to the Zen17 I/O.
Which virtual device are people using? The built in "Virtual Garage Door Controller" or something else?
This thread was a big help in getting the ZEN17 setup for a Genie Pro 1024 garage door opener, which has a wall switch with a light button. Much thanks!
Using those apps and driver, I created a new Garage Door device and selected the TILT-ZWAVE2.5-ECO for an open close sensor.
Everything is working well so far! Thanks again for sharing info here. The instructions included with the Zen17 weren't enough for me to figure it out.
Thanks hydro311 and heuser321! I got it all working. My problem was I was coming at it from a garage door POV and working back to Zen17 instead of starting at Zen17 and working towards garage door if that makes sense.
