I tried using zigbeeOff as a trigger to reboot the hub. I then disabled zigbee radio for a little while, and nothing happened. Am I doing something wrong, or doesn't it work? Thanks.
I asked the same question over here…
Following. I have the exact same issue. My Zigbee radio goes offline every few days ever since the new code for the C8 came out (even though I am on the C7)... this is starting to drive me nuts, and we can't fix it with a rule apparently...
Not a bunch of responses.
Where you been? It started working on 2.3.5.140.
My Reboot on Zigbee Radio Offline Rule Just Worked!
A well earned vacation ![]()
I've got this same issue, and trying to set up the same thing. Don't know how to test what exactly the "zigbeeOff" event does - is it looking for the radio to be TURNED off (manually flipping the switch and saving settings) or for a "crashed/offline" state?
Better still would be if ZigBee would stop going offline for no discernible reason every week or so.
You can use zigbeeOff as a trigger for notifying you.
You can simulate this by doing a zigbee radio reboot.
It'll report back on in 7 seconds or so, but you could still use the zigbeeOff as a trigger.
There have been problems with zigbee radio reboots and people want to know when it happens.
There is no zigbee radio crash location event like there is for Z-Wave.
Perfect, that's exactly what I built. Good to know that a simulated reboot is a viable test trigger. I would still prefer if the radio wouldn't crash for no reason
It doesn’t crash for no reason. The typical reason is excess system load due to a misbehaving app/device.
