I'm in US.
Cool give me the addy and ill get it in the mail in the next few days.
I'll send you a PM.
Thanks much!
I got couple of those first generation environmental sensors.
@iharyadi is there any way how to turn off repeater function?
It works good as arrival sensor, it just tear mesh multiple times a day.
My understanding is that is basically version of xbee. And with xbee is kind of easy to change firmware.
I am surprised that it worked as arrival sensor. There is not a way to disable the repeater function on this sensor.
Hi, Do you still have these sensor ? Can I please get 1 ?
See post #413
Ahh, I saw that he has postings in almost every forum like Reditt, ST, HA, OHAB, so I thought may be he is still working on those.
Have anyone found another solution ? I would like to use one for car arrival (not phone's presence)
Look on eBay for a discontinued SmartThings arrival sensor.
Xbee3 programmed as end devices work great.
I am not an engineer and it seemed a bit of work. Are there instructions easy enough to follow somewhere?
Already checked, can’t find it anywhere available
First post of this thread, I believe are the steps to set up the Xbee as an end device to use for presence sensing.
only optional thing is going to a dollar store to find a case for it.
But you don't have to have one.
There is also 3d print case files that work great if you have a 3d printer.
Perfect thanks. Love the community support. Will try out.
Thank you. I do have 3d printers at work that I can use but I don’t care about the case at the moment. Lemme read the forums and see if I understand enough to get it working. This does seem like a good solution for automating garage door. How soon can it report the presence once it’s turned on from off state and also when it comes into range from out of range ?
I imagine the speed is dependent to a great extent on your Zibee network...you might need to experiment with a repeater in the garage/near the driveway to "catch" the Xbee signal when you arrive. Obviously it's really nice when the garage door is opening when you're just pulling into your driveway, rather than sitting in front of your garage door waiting for it to open.
300ft indoor range, or 2mile outdoor/line-of-sight range.
transmits as soon as it is powered on.
transmit rate is programabled as you don't want to flood your hub.
I use 2 Xbee3 per vehicle one for arrival which is only powered on when the car is running and it is programmed to transmit every 5 seconds.
The second is always powered on and is set to transmit every 30 seconds just to show the car at home.
To only power on when running or always powered on you might be able to use your cigarette lighter or usb in the car or you have to figure out which fuse to use and get an adapter to tap into the fuse box (very easy to do just plug an adapter in)
Your range will also depend on how fast you are driving
Being lazy, I'm sure this is covered in the Xbee thread. That range is impressive, but how do you keep your automations from opening your garage door when you start up your car at the local grocery store. Seriously, what do you implement to control range so your G-door won't open until you are actually home?
