Hi everyone, I'm new HE user, migrating from Smartthings after 3 years. I've bunch of zemismart switches (no neutral), single, two and 3 gang. I'm struggling with adding switches with more than 1 gang.
I've read multiple threads here and tried all suggested drivers:
All I'm getting is all three switches working as one. No child devices appear on the device list.
I'm all new to hubitat so there might be something that I'm doing wrong.
I also have a zemismart device handler for smartthings that works well with hub, I've read on the forum it's fairly straight forward to convert to Hubitat for someone who knows what they doing. It's probably bit too much for me at the moment but I can post it here if someone would like to have a look.
To help you find the right driver for your switches, it is needed to know the exact model and manufacturer. This can be found on the device web UI page, 'Data' section at the bottom. Please copy and paste it here.
Welcome @Gr0sh. Pretty sure @kkossev will be able to get you set up with the right driver, but if for some reason he can’t holler and we can take a look at porting the driver.
Three child devices should be created (you may need to press F5 to refresh the web page) and you should be able to control the three switches individually now.
Please let me know if it works for your device.
Update May 2024 : this driver is now available for installation and update from HPM.
