Oops, I'll learn to read!
That worked fine:
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:30.782 AM[debug](http://192.168.1.170/logs#)getThermostatRunningModeResult:0
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:30.774 AM[debug](http://192.168.1.170/logs#)descMap: [raw:BF91010201081E003000, dni:BF91, endpoint:01, cluster:0201, size:08, attrId:001E, encoding:30, command:0A, value:00, clusterInt:513, attrInt:30]
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:30.454 AM[info](http://192.168.1.170/logs#)Upstairs thermostatMode is off
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:30.449 AM[debug](http://192.168.1.170/logs#)getThermostatModeResult:0
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:30.443 AM[debug](http://192.168.1.170/logs#)descMap: [raw:BF91010201081C003000, dni:BF91, endpoint:01, cluster:0201, size:08, attrId:001C, encoding:30, command:0A, value:00, clusterInt:513, attrInt:28]
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:30.079 AM[trace](http://192.168.1.170/logs#)off()
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:12.794 AM[debug](http://192.168.1.170/logs#)getThermostatRunningModeResult:4
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:12.788 AM[debug](http://192.168.1.170/logs#)descMap: [raw:BF91010201081E003004, dni:BF91, endpoint:01, cluster:0201, size:08, attrId:001E, encoding:30, command:0A, value:04, clusterInt:513, attrInt:30]
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:12.487 AM[info](http://192.168.1.170/logs#)Upstairs thermostatMode is heat
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:12.481 AM[debug](http://192.168.1.170/logs#)getThermostatModeResult:4
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:12.476 AM[debug](http://192.168.1.170/logs#)descMap: [raw:BF91010201081C003004, dni:BF91, endpoint:01, cluster:0201, size:08, attrId:001C, encoding:30, command:0A, value:04, clusterInt:513, attrInt:28]
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:08.241 AM[warn](http://192.168.1.170/logs#)description logging is: true
[dev:879](http://192.168.1.170/logs#)2022-12-01 11:19:08.229 AM[warn](http://192.168.1.170/logs#)debug logging is: true
