Hi all, I also have a similar situation my device is a Xiaomi aquaria curtain motor theres a Smartthings code however i can't seem to get it to work on hubitat, sadly the generic Zigbee shade does not support all the functions, eg when manually opened, curtains state won't reflect in hubitat, in ST however this is perfectly reflected, code below, I get this error ---
Value too long for column "ENDPOINT_ID VARCHAR(2)": "'0x01' (4)"; SQL statement: INSERT INTO FINGERPRINT(DEVICE_TYPE_ID, PROFILE_ID, ENDPOINT_ID, IN_CLUSTERS, OUT_CLUSTERS, MANUFACTURER, MODEL, DEVICE_JOIN_NAME, DEVICE_ID, MFR, PROD, CONTROLLER_TYPE) VALUES(?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) [22001-197] HELP ?
metadata {
definition(name: "Xiaomi Curtain SJ", namespace: "ShinJjang", author: "ShinJjang", ocfDeviceType: "oic.d.blind") {
capability "Window Shade"
capability "Switch Level"
capability "Actuator"
capability "Health Check"
capability "Switch"
capability "Sensor"
capability "Refresh"
// attribute "Window Shade", "enum", ["open", "close", "stop"]
fingerprint endpointId: "0x01", profileId: "0104", deviceId: "0202", inClusters: "0000, 0004, 0003, 0005, 000A, 0102, 000D, 0013, 0006, 0001, 0406", outClusters: "0019, 000A, 000D, 0102, 0013, 0006, 0001, 0406"
command "levelOpenClose"
command "shadeAction"
command "stop"
preferences {
input name: "mode", type: "bool", title: "Xiaomi Curtain Direction Set", description: "Reverse Mode ON", required: true,
displayDuringSetup: true
tiles(scale: 2) {
multiAttributeTile(name: "windowShade", type: "generic", width: 6, height: 4) {
tileAttribute("device.windowShade", key: "PRIMARY_CONTROL") {
attributeState("closed", label: 'closed', action: "windowShade.open", icon: "st.doors.garage.garage-closed", backgroundColor: "#A8A8C6", nextState: "opening")
attributeState("open", label: 'open', action: "windowShade.close", icon: "st.doors.garage.garage-open", backgroundColor: "#F7D73E", nextState: "closing")
attributeState("closing", label: '${name}', action: "windowShade.open", icon: "st.contact.contact.closed", backgroundColor: "#B9C6A8")
attributeState("opening", label: '${name}', action: "windowShade.close", icon: "st.contact.contact.open", backgroundColor: "#D4CF14")
attributeState("partially open", label: 'partially\nopen', action: "windowShade.close", icon: "st.doors.garage.garage-closing", backgroundColor: "#D4ACEE", nextState: "closing")
tileAttribute("device.level", key: "SLIDER_CONTROL") {
attributeState("level", action: "setLevel")
standardTile("open", "open", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state("open", label: 'open', action: "windowShade.open", icon: "st.contact.contact.open")
standardTile("close", "close", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state("close", label: 'close', action: "windowShade.close", icon: "st.contact.contact.closed")
standardTile("stop", "stop", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state("stop", label: 'stop', action: "windowShade.stop", icon: "st.illuminance.illuminance.dark")
standardTile("refresh", "command.refresh", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label: " ", action: "refresh.refresh", icon: "https://www.shareicon.net/data/128x128/2016/06/27/623885_home_256x256.png"
standardTile("home", "device.level", width: 2, height: 2, decoration: "flat") {
state "default", label: "home", action:"presetPosition", icon:"st.Home.home2"
main(["windowShade"])
details(["windowShade", "open", "stop", "close", "refresh"])
// Parse incoming device messages to generate events
def parseMap = zigbee.parseDescriptionAsMap(description)
log.debug "parseMap11:${parseMap}"
def event = zigbee.getEvent(description)
try {
if (parseMap.raw.startsWith("0104")) {
log.debug "Xiaomi Curtain"
log.debug "Unhandled Event - description:${description}, parseMap:${parseMap}, event:${event}"
} else if (parseMap.raw.endsWith("0007")) {
log.debug "running…"
} else if (parseMap.endpoint.endsWith("01")) {
if (parseMap["cluster"] == "000D" && parseMap["attrId"] == "0055") {
long theValue = Long.parseLong(parseMap["value"], 16)
float floatValue = Float.intBitsToFloat(theValue.intValue());
def windowShadeStatus = ""
int curtainLevel = floatValue.intValue()
if(mode == true) {
if (theValue > 0x42c70000) {
log.debug "Just Closed"
windowShadeStatus = "closed"
curtainLevel = 0
} else if (theValue > 0) {
log.debug curtainLevel + '% Partially Open'
windowShadeStatus = "partially open"
curtainLevel = 100 - floatValue.intValue()
} else {
log.debug "Just Fully Open"
windowShadeStatus = "open"
curtainLevel = 100
} else {
curtainLevel = 100
} else {
curtainLevel = 0
def eventStack = []
eventStack.push(createEvent(name:"windowShade", value: windowShadeStatus as String))
eventStack.push(createEvent(name:"level", value: curtainLevel))
eventStack.push(createEvent(name:"switch", value: (windowShadeStatus == "closed" ? "off" : "on")))
return eventStack
} else {
} catch (Exception e) {
log.warn e
def close() {
setLevel(0)
def open() {
setLevel(100)
def off() {
log.debug "off()"
close()
def on() {
log.debug "on()"
open()
def stop() {
log.debug "stop()"
delayBetween([
zigbee.command(0x0102, 0x02),
zigbee.readAttribute(0x000d, 0x0055)
], 500)
// runIn(1, refresh)
def setLevel(level) {
if (level == null) {level = 0}
level = level as int
if(mode == true){
if(level == 100) {
log.debug "Set Close"
zigbee.command(0x0006, 0x00)
} else if(level < 1) {
log.debug "Set Open"
zigbee.command(0x0006, 0x01)
} else {
log.debug "Set Level: ${level}%"
def f = 100 - level
String hex = Integer.toHexString(Float.floatToIntBits(f)).toUpperCase()
zigbee.writeAttribute(0x000d, 0x0055, 0x39, hex)
} else{
if (level == 100){
} else if(level > 0) {
String hex = Integer.toHexString(Float.floatToIntBits(level)).toUpperCase()
} else {
def shadeAction(level) {
if(mode == true){
if(level == 100) {
} else {
def f = 100 - level
} else{
if (level == 100){
} else {
def refresh() {
log.debug "refresh()"
// "st rattr 0x${device.deviceNetworkId} ${1} 0x000d 0x0055"
