Hi!!!
Sorry for my total lack of competence, but I am trying to make this power strip work, and with many attempts and recommendations from you I am not getting it.
I will try to describe below my step by step, and see if you can help me identify what I'm doing wrong.
First step is to add the device to HE: Devices > Add Devices > Find by device type > Switches > Generic/Other > Generic Zigbee Multi-Endpoints Switch > +Add > + Start Zigbee pair > press the power button on the strip until it blinks blue and the message Found a Zigbee device, initializing appears...
I add a device name > Next
Choose a room > Next
View Device details
I then have the following screen.
I then change the Type that has "Device" as drive, to the "Tuya Zigbee Metering Plug" drive > Save Device
The following screen appears.
Then I pressed the Initialize button. The following information is updated on the screen.
As instructed above, I now switch from the "Tuya..." drive to the "Device" drive > Save Device.
Below is the new screen, and according to the instruction I press the "Delete All Current Sates" button
I am now looking to change the drive that is currently "Device" to "Generic Zigbee Multi-Endpoint Switch" again > Save Device
The screen below resulted, and no child device was created in the process.
No device child was created.
In an attempt to do something different, after all the above procedure, without deleting the device already created, I repeat Add Device > Find by device type > Switches > Generic/Other > Generic Zigbee Multi-Endpoints Switch > +Add > + Start Zigbee pair > and at this point it created the children.
When I enter the device, I see the screen below, but I can't make any commands, it won't turn on or off. Two things caught my attention.
The main device has the Device Network ID below FB02 , and see that the child (screen above has the number 1883-01 to 1883-05.
Another issue is that it doesn't allow me to change the Drive type, I saw in an example above that the son used the same drive as the father, but in my case it is as Generic Component Switch, I don't know if this would interfere.
In short, I can't make any headway with several different attempts. Sorry @kkossev for the long post, but I went through as much detail as possible to see if I can get any help.
Thanks.
