Need some help here, please
When I hit this link (fictive example) in my browser some snapshots are taken in my Synology surveillance station (--> the link is working)
I don't think you can use https, just http, but I could be wrong.
What is it you are trying to accomplish? If it is to show the cameras on your dashboard get out the post below. I don't have my Surveillance Station running yet or I could provide more details.
I want to send a trigger to my synology to save some snapshots, It works when I paste the link in my browser , I get {"success":true} and the action rule in my Synology is running (the snapshots are saved).
I have no issues to show the streams on my dashbord, this is working fine
Hello there,
Many thanks for the description. I have tried all as described but for some reason, i cannot trigger the cams in SS via Hubitat. I have a setup via Homebridge. Same URL and the triggering works, but it fails via Hubitat. Do i need to enable something somewhere else in the hub to get this functionality. I really went through all the steps, but without luck. Really hope you can point me in the right direction. Thanks so much in advance?
I really appreciate your quick reply. Just in general the whole atmosphere and willing to help go about of the community is amazing. I just started with Hubitat 6 months ago. Came from ST and i LOOOOVE Hubitat.
I did see steo 3 and i really did ALL as described. As mentioned the same link works in Homebridge. In Hubitat however, it doesn’t. I’m on http, removed the ? and did use the http port as used by my Synology NAS. I simply don’t get it. I’ll keep on trying, because i’d really like to keep Homebridge out of the equation.
Cheers and thanks!
You sir, are amazing!!!! That did the trick and i would never ever have been able to figure that out myself. IT WORKS NOW and you really, really made my day. Thank you so much🙏
