webCoRE for Hubitat Updates
I turned on WC Settings | Logging | Full but all I get is:
app:122023-03-06 13:00:29.389debugDashboard: Received test a piston
I don't recall other logging beside that one and the Piston level logging?
I tried my phone number instead of a var but no go. If I send a regular email it works so I kow it's not a provider change.
So here is what I'm doing that worked:
Screenshot 2023-03-06 at 4.18.10 PM
So perhaps remove the extra quotes?
Ha, figured it out.
Sendemail doesn't like having a blank message. I was just using the Subject as the message.
I guess I have something in the message protion everywhere else.
Thanks for fiddling with me. :slight_smile:
with the send email, is there anyway to grab a file from the habitats file manager and send it in the email as an attachment?
I have cameras that will take a picture and store it to the hub file manager (Someone made this not me), I would like that if I am not home and there is motion inside my home that I get an email with a screen shot that was taken so I can view the image.
If this is not possible, can you look into adding this feature?
webCoRE does have a readFile command.
That said, I think to send as email you get into converting this to a MIME attachment, which is where things can get challenging. Likely we would need someone that understands this and likely they are going to ask for some additional webCoRE functions to help with the conversion....
So some collaboration would be needed....
Fair enough. Dont waste time on it then unless many ask for it. I am sure you have better things to work on then. Thanks anyways. :heart:
I'm noticing that since 2.3.5 have some piston that fail to run. Reboot and recreate cache and it will work until the next reboot. I have noticed a few times. I have seen this with RM rules only so far and WebCoRE. This rule hasn't changed in years. It's one of my old reliable rules that never fails. This rule does control, and hub meshed device, but I don't have any issue manually controlling it. Very strange. I want to see if anyone else notices this.
Would be interesting to see more logs of the piston when it is having trouble
  • ie is it receiving events?
  • is it issuing commands
Low or medium logging on a piston may give insights.
@nh.schottfam Thank you for your response. I need to dig further.
I don't see the request sent to the device. However, the hubs were rebooted around midnight. However, the device on the c7 (hub mesh) shows offline. However, that was hours after the reboot.
3/9/2023, 7:48:16 AM +401ms
+4ms ╔Received event [Kate Sarcone].presence = not present with a delay of 56ms, canQueue: true, calledMyself: false
+8ms ║RunTime initialize > 7 LockT > 0ms > r9T > 3ms > pistonT > 0ms (first state access 0 m:4 4 3)
+11ms ║Runtime (8803 bytes) initialized in 3ms (v0.3.114.20230222_HE)
+34ms ║╔Execution stage started
+86ms ║║Comparison changes_to = false (event device/attr eXcluded)
+87ms ║║Comparison changes_to = false (event device/attr eXcluded)
+90ms ║║Comparison (enum) not present changes_to (string) present = false (1ms)
+91ms ║║Comparison changes_to = false (event device/attr eXcluded)
+98ms ║║Condition #2 evaluated false (32ms)
+112ms ║║Condition group #1 evaluated false (condition did not change) (39ms)
+148ms ║║Comparison changes_to = false (event device/attr eXcluded)
+156ms ║║Comparison changes_to = false (event device/attr eXcluded)
+167ms ║║Comparison (enum) not present changes_to (string) not present = true (0ms)
+181ms ║║Condition #9 evaluated true (45ms)
+190ms ║║Comparison (enum) closed is (string) closed = true (6ms)
+192ms ║║Condition #10 evaluated true (9ms)
+233ms ║║Comparison (long) 38071674 is_greater_than_or_equal_to (integer) 300000 = true (2ms)
+235ms ║║Condition #11 evaluated true (42ms)
+245ms ║║Comparison (enum) unlocked is (string) unlocked = true (1ms)
+246ms ║║Condition #12 evaluated true (11ms)
+248ms ║║Condition group #8 evaluated true (condition did not change) (134ms)
+274ms ║║Executed device command [OFFLINE - Front Door Lock].lock() (22ms)
+280ms ║║Executed virtual command [OFFLINE - Front Door Lock].waitRandom [500, 1000] (1ms)
+283ms ║║Requesting wake up at Thu, Mar 9 2023 @ 7:48:17 AM EST (in 719ms) for 13 (st:15)
+335ms ║╚Execution stage complete. (301ms)
+437ms ║Setting up scheduled job for Thu, Mar 9 2023 @ 7:48:17 AM EST (in 631ms)
+440ms ╚Event processed successfully (436ms)
I don't see this issue the RM. I'm not sure where to look.
I would check your hub mesh devices are setup properly, and webCoRE piston is using the proper devices.
I don't see anything so far that shows webCoRE itself misbehaving.
I have done that. On reboot it "takes time" Default 2 minutes to synchronize up. That has been set up for quite some time too. Some devices may show offline until the next sync. Dashboard will show offline for two minutes and then it is OK. RM Rules work everything seems to work just the Webcore is affected. Maybe it is the C5 and Processing. I'm just seeing strange behavior since moving the firmware of the C5. Example, I check Wi-Fi and Geo fencing for presence and combined them together. This just failed where typically this has been solid. Maybe I'm looking at the wrong place. I'm getting an error the comes and goes with a Webcore variable that it cannot be read but I don't see any issue with positon and it is still working. Thanks for your help.
You need to show some logs of this. I have C5s, reboot them all the time.
The example you show, webcore sent the command and the device is what is showing the offline. WebCoRE is sending the command and you can turn on device logging to see what it is or is not doing...ie webCoRE does not change the device internals
This thread has lost its purpose. It has turned into an unwieldy disorganised support thread.
Can we get a new read-only thread that contains important updates and release notes for Webcore Hubitat?
…. Which is what this thread was originally for.
Well the first post is regularly updated to show changes and fixes related to Webcore, with archived notes of what was fixed in previous builds. Were you looking for anything else regarding updates, or were you possibly unaware this was there? It has been edited 237 times, so I feel @nh.schottfam has done a great job keeping us informed.
The more recent posts are mostly others speaking up when they have a problem with a certain Webcore related function, or something is not operating the way they are expecting it to within Webcore.
Fortunately, I feel this thread is pretty on topic, and I have seen other threads on the forum which get wildly off topic, or drift away from the original issue posted about. And when it does get highly user issue specific, the moderators tend to take it into a PM based fix, rather than just spamming the thread here.
The March 5th 2023 update was the first update in 2.5 months. And it was made after I wrote my post about this thread losing its purpose.
One update in 2.5 months can’t be considered “regular” particularly when there’s been releases every week or two this year.
As for:
“The more recent posts are mostly others speaking up when they have a problem with a certain Webcore related function, or something is not operating the way they are expecting it to within Webcore.
Do you really believe it is the best solution for a multitude of support problems to be mixed into a disorganised mega-thread whose topic was intended for update announcements? There is an entire category in the Hubitat forums dedicated to Webcore. In forums like this different issues are usually addressed in individual topics of their own. That’s just how things are usually done. Disorganised Mega-threads like this aren’t helpful.
Just some constructive feedback. That’s not really the issue I care about anyway.
But I do care about release notes being available. I’m a software engineer myself. Releases should not happen without release notes. It’s the duty of the software engineer to provide these. People need to be able to make an informed choice about whether or not to take the update.
I always take the “if it ain’t broken don’t fix it” route so I always look for release notes before I make a decision. Personally I think dedicated read-only threads work best such as the approach taken by the Hubitat engineering team:
New update posted today, see note 1 for details.
Should be in next HE firmware release.
@nh.schottfam
can you please explain a little bit more about the " * updates for DST calculations on every schedules"? What does that mean?
Currently I have pistons to stop and resume every single pistone twice a year to fix the DST issue in time. Is this still necessary?
Thanks for some explaining words.
Someone pointed out an example of an every statement that had not calculated DST changes right, that is what was fixed.
If you upgraded and are concerned, you can pause/resume pistons that do this after the upgrade.
There is nothing wrong with what you may be doing now, (I understand why this was needed), I have been trying to stamp out any last issues.
New release is pushed out. Note 1 has details.
It is also available in latest HE firmware for built in.
Seems to be stuck on this...
Edit
Took ages, but worked
