Are you using staging, or dashboard?
Have you tried these steps?
What options are there to select for that device?
ie the down arrow next to Do... Nothing selected?
Forgot to mention that I tried every server: my local one, the cloud server, and staging. Same behavior on each. I had never registered my browser with either of the cloud servers, so in both of those cases, it was logged out before I started.
All the options are there as expected. It just gets the initial selection wrong.
This seems to be a first-time thing. If I change it to exactly what it was before and click save, the editor works properly the next time I open it.
If you see it again, let @ipaterson and myself know.
I didn't mean that it happened only once. I meant it happens the first time I try to edit an existing line of code in a piston.
If I open the editor (which shows "Nothing selected"), change it to what was supposed to be selected, and click Save, from then on, editing that same line of code works properly.
Tagging @ipaterson
I’ll try that out today if it can be installed as a virtual device, thanks for reporting.
I don't think it can, but you can write a stub custom driver that has a custom command. It happens with any custom command.
You did do the logout step requested above?
After you logout, go into webcore -> Settings -> Select devices, and done your way out
Then register/login again.
I had never before logged in to staging. There was nothing to log out from.
I have a fix for editing custom commands in pistons created before the recent smart app updates on https://staging.webcore.co in case anyone else is affected. Going to do more testing before releasing that change though.
I have the integration installed and it appears to be working. I check the logs and I keep getting this message. Any ideas on what needs to change?
app:10512023-02-11 11:09:28.952 AMerrorEnvisalink Integration: Connection Driver: Telnet is restarting...
app:10512023-02-11 11:09:28.946 AMerrorEnvisalink Integration: Connection Driver: telnetStatus- error: receive error: Stream is closed
app:10512023-02-11 11:09:18.902 AMerrorEnvisalink Integration: Connection Driver: Telnet is restarting...
app:10512023-02-11 11:09:18.896 AMerrorEnvisalink Integration: Connection Driver: telnetStatus- error: receive error: Stream is closed
app:10512023-02-11 11:09:08.844 AMerrorEnvisalink Integration: Connection Driver: Telnet is restarting...
app:10512023-02-11 11:09:08.838 AMerrorEnvisalink Integration: Connection Driver: telnetStatus- error: receive error: Stream is closed
app:10512023-02-11 11:08:58.784 AMerrorEnvisalink Integration: Connection Driver: Telnet is restarting...
app:10512023-02-11 11:08:58.777 AMerrorEnvisalink Integration: Connection Driver: telnetStatus- error: receive error: Stream is closed
I don't think this is related to webcore, but some about that app/integration and its configuration.
I get this all the time, It's in the Envisalink code.
I commented one line out but can't find the other.
Hello
2 things:
I am not able to open dashboard in Webcore - nothing is happening when I click it. It worked yestreday. Possibly it is caused because of the update of the hub today?
Is it possible to check "Last Activity At" of the device in Webcore? How?
checkout
I'm having this problem too. Clicking on the Open Dashboard only gets the button to detent and return when mouse is unclicked.
I've reboot the hub, etc... Nothing.
I can goto register browser & follow the instructions (goto the website) & enter the token code that's valid for 3 min....I can then get into my dash board.
Did WebCore change their security settings?
This is a bug, and fix is out for user install. For system install, it should get into next firmware update.
With the latest update, is anyone having an issue setting variables? I seem to be missing drop down menus when I attempt it.
are you using staging? - please go to dashboard.webcore.co
I am running the local dash. I'll try to logout and clear things.
What exactly do you mean setting variables? I was able to manually set a local variable from the web interface. Ran a test on the piston and it responded accordingly. I am using staging as well
