So there is a new update available.
- If you have not seen there is a webCoRE documentation digest
Please note this version only runs with 2.3.1.130 or later of HE firmware (this is the current released version as of today)
Key changes:
a lot of optimizations and improved Groovy compilation (these are what requires the latest HE version)
more dashboard improvements from @ipaterson (currently on staging.webcore.co or if you install local dashboards)
- improvements in refresh and updates
improved logging for pistons when in 'FULL' logging, that timer schedules and cancels have more data on what is being scheduled / cancelled and where in the piston restarts are occurring.
improvements in else if statement processing that Task Cancelation Policy should correctly be matched to the else if (the bug was it was tied to the if)
improvements in condition optimizations to deal with condition true/false statements properly when determining optimizations.
added new file commands for HE hub files (thx to @thebearmay ) for assistance.
adds commands
Write to file
- will create the file if it does no exist
Read from file
- data is put into a system variable $file
Append to file
- will create the file if it does not exist
Write to file
adds a new function exists(filename) which returns true/false if a file exists
files are text files. You can use webCoRE json commands/functions to use other data types
files are managed in HE console -> Settings -> File Manager
Example Piston:
