We finally have a smart outlet that is slim!
Sounds like the name of some alien from a space-horror flick...if not, it should have been. :wink:
Howdy, it doesnt like the Generic HE outlet driver at all - here are the details:
• endpointld: 01
• application: 50
• inClusters: 0003,0004,0005,0006,0702,0B04,E000,E001,0000
• manufacturer: _TZ3000_zfijnotz
• model: TS011F
• outClusters: 0019,000A
• powerCluster: none
• softwareBuild:
It doesnt seem to like your driver from below either:
As this is a new device, its fingerprint is not present in any driver yet, so it will default to the ’Device’ when paired for a first time.
It exposes the standard ZCL clusters, what exactly is not working if you click on the ‘Configure’ button after changing to Generic HE outlet driver?
It won't turn on/off - it's sitting there blinking like it's in pair mode:
State Variables
rxCounter : 0
energyPollingSupported : true
lastResetDate : 2024-11-07 15:27:48.446
lastEnergyRaw : 0.0
isDigital : false
rejoinCounter : 0
lastSwitchState : unknown
txCounter : 25
isRefreshRequest : true
notPresentCounter : 5
lastEnergyCost : 0.0
lastHourlyEnergy : 0.0
switchPollingSupported : true
powerPollingSupported : true
lastResetEnergy : 0.0
voltagePollingSupported : true
driverVersion : 1.9.7 2024/07/05 7:56 AM
switchDebouncing : false
currentPollingSupported : true
model : TS011F
destinationEP : 01
Use the Double Luck voodoo to pair it again (do not delete it).
This one works fine with the Generic HE zigbee outlet driver and is small enough to fit 2 in a std double GPO.
Zigbee Smart Socket AU Plug Adapter
  • endpointId: 01
  • application: 70
  • firmwareMT: 100B-0205-10013607
  • inClusters: 0000,0003,0004,0005,0006,000A,E000,0702,0B04,1000,1888
  • manufacturer: _TZ3000_cehuw1lw
  • model: TS011F
  • outClusters: 0019
  • softwareBuild: 1.0.5
Yep, the Generic HE Zigbee outlet driver should work with Tuya TS011F outlets and switch modules, providing the pairing was successful.
It's like it wont stay connected - it just keep blinking but does work for a short time:
eventually it stops blinking, but also stops responding.
At $7 a unit, I'm scared to look where they cut the corners! :scream:
This is the well-known Zigbee 3.0 devices pairing via Zigbee 3.0 routers problem.
Use the voodoo on C-8 hubs, or pair the problematic device immediately after rebooting if you have a C-7 hub.
I have a C8 Pro - what is the voodoo?
Arrrgh, none of that works, it just wont stay paired. :grimacing:
Did you follow the voodoo steps precisely? How close are you pairing the outlet to your hub?
I just tried again after rebuilding the zigbee network twice, and it worked! Huzzah!
Even the generic driver works. Thank you!
That's why I called the voodoo 'Double Luck' :rofl:
Not wrong! Very apt!
This part seems to be the key to success - my second Outlet paired first go and worked immediately.
There are also other methods available, but my voodoo is free! :slight_smile:
Same plugs sold for an arm and a leg on ebay.
