As I was mentioning in my earlier post, I've now completed migration of my water sensors and EcoNet valve to HE. It's paired as a 'Z-Wave Generic Valve'. Everything is working great. I also had a plumber come in on Monday to add plumbing for a second valve I just purchased. It opens a second valve to a drain once the first one is closed to shut off water supply. This coordination works great to quickly bleed pressure and further reduce potential damage. The second valve is on a 3/4-Inch line, but reduced to a 1/2-Inch drain line. We've got a house full of copper pipes that are nearly 60 years old. The intent was to reduce a sudden drop in pressure to be a little easier on connections. It was very straight forward to create a simple automation in RM.
Gas sensors are something else I'm interested in looking into (as others have mentioned).
It is a line powered device, so there is a reasonably good chance it is a repeater. When I looked at their website, it didn't say either way. Almost all line powered Z-Wave and Zigbee devices are repeaters.
From Logs when I got info from the Device driver:
fingerprint mfr:"0157", prod:"0003", deviceId:"0002", inClusters:"0x5E,0x25,0x85,0x59,0x86,0x72,0x77,0x5A,0x73"
It works perfectly fine with the Generic Z-Wave Valve driver to open and close the valve. I just got it today and noticed others on this post also posted above that this device works for them too but Hubitat was missing the fingerprint.
This is on my C7 hub above.
They actually do advertise it works with Hubitat on their site too which I thought was funny even though the fingerprint was probably never added.
I’ve had one of these for a year and a half. If you can get over the anti-WiFi zealotry, it works great with Hubitat. Importantly, it will do its job whether it has Internet access or not. Or if Hubitat is offline. You want local processing? The Flo is configured by a cloud-based app, but then runs completely independently.
This is NOT one that works with HE directly... but I am working with them to try to make it possible:
GE Smart Whole House Water Filter (GXWH70M)
It seems pretty decent so far, the design is sturdy and you can manually control whether it is filtering, bypassed, or stopped. The filter has a motor in it that can be controlled to set those same things as well as a flow meter
I have one of these as well. Let us know if you get it working with Hubitat. I have a leak smart valve already but it would be nice to have this one on Hubitat also. I purchased this model filter after my AO Smith ones kept bursting. This was before I found out my water pressure was 125 and needed to replace the regulator.
I would recommend you look closely at your needs around one first. Right now it has NO direct Hubitat integration and it works by communicating with the cloud. That means if the network is down it will be useless (although the ability to manually change it also allows it to be handled in cases of a power failure).
Not to disparage it. I like the design (not sure about replacement filter costs yet) and am still working on it. I just want everyone to be aware that it does not directly work with Hubitat and may NEVER do so (but I am staying in contact with GE to get it as a feature request).
They are generally cheap if you don't need the lead filtering. Those are around $50-$55USD and the ones that I get (yellow top/bottom) are around $24-$26USD.
Anyone ever tried one of the Leaksmart appliance kits?
They're not zigbee-enabled like the Leaksmart valve @aaiyar mentioned above, but I'm wondering if I can at least figure out a way to tap into the valve open/closed status to get that info pulled into HE.
Yeah that’s what I was thinking. I have a few old ecolink z-wave contact sensors with external inputs that should do the trick, if it’s not too hard to wire one in parallel.
I did a fair bit of searching lately (I have a friend that was also looking into controllable valves) and I have not seen any that would work with that handle in that amount of space. Pretty much every solution would require replacing that valve... but at the same time the space is very limited for many of them also.
I stumbled on at least on device that controls "normal" controllable valves, so that would all fit in that space, but they were very expensive. Those controllable valves are pretty pricey to begin with and then the controller was ~$400.
Appears you have room above and below the valve. You could find a larger box, replace the valve, and install the bigger box. My main shutoff is in a terrible spot in the wall of a coat closet with custom trim built around it. I ended up putting an additional Watercop shutoff valve in the crawl space before this main valve right after my PRV.
