Hello,
I have removed 2 LeakSmart sensors (version 1 and 2) from my Wink hub. I then performed a reset on both of them. When I tried to pair them to the HE, nothing happens. I'm using the Zigbee Pairing in HE. I also had the driver loaded and saved from the following page:
Not original content but this driver is fully functional for the LeakSmart Water Sensor. Just enable compatibility mode on the device.
Any other advice?
Thanks!
aaiyar
November 3, 2019, 8:37pm
2
Welcome to Hubitat! I'm sorry you're having trouble pairing the LeakSmart sensors. They should work with the "Generic zigbee moisture sensor" driver.
Pairing issues with this sensor were discussed recently in this thread started by another former Wink user:
Coming from Wink and I have a LeakSmart sensor that looks like I won't be able to use. At least, I'm seeing mixed comments about this. If I'm going to replace this, what's the current drop in solution? I've seen mention of the Aeotec, but $55! Ouch!
nepto
November 25, 2020, 5:27am
3
They pair well with the current firmware drivers, however, they never detect moisture, what is kind of a bummer for a moisture sensors
