Tuya Smart Human Presence Sensor Micromotion Detect Human Motion Detector ZigBee (TS0601 _TZE204_sxm7l9xa)
OK, I will follow yours recommendations. These two sensors are in very WAF sensitive areas
(Bathroom and Kitchen lighting control). Braking these automation will be a disaster.
Just find the right time... : ) For me, these times are when my wife goes to visit her mother, who lives in another town! : )
To avoid any WAF risks, save a copy of version 1.3.7 and use it for these two sensors.
But you will need the latest versions of the 'standard' driver for any other Tuya mmWave sensors that you may decide to try later.
This one (potentially mmWave/PIR Combo with (maybe) battery backup) will be in tomorrow:
https://www.amazon.com/dp/B0CDRBX1CQ?psc=1&ref=ppx_yo2ov_dt_b_product_details
Let me see will it work (I hope). I'll certainly let you know my first impression.
After recommended steps
Summary
v:12182023-08-25 07:21:40.829 PMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00636D02000400000000
dev:12182023-08-25 07:21:40.247 PMdebugKitchen Presence Sensor ignored illuminance event 3 lux - change is less than 5 lux threshold!
dev:12182023-08-25 07:21:40.244 PMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=104 fncmd=3
dev:12182023-08-25 07:21:40.241 PMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00626802000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 62, 68, 02, 00, 04, 00, 00, 00, 03]]
dev:12182023-08-25 07:21:40.237 PMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00626802000400000003
dev:12182023-08-25 07:21:39.691 PMdebugKitchen Presence Sensor ignored motion inactive event after 111s
dev:12182023-08-25 07:21:39.688 PMdebugKitchen Presence Sensor radar presence event DP=0x69 (105) fncmd = 0
dev:12182023-08-25 07:21:39.685 PMdebugKitchen Presence Sensor Tuya cluster: dp_id=4 dp=105 fncmd=0
dev:12182023-08-25 07:21:39.682 PMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00616904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 61, 69, 04, 00, 01, 00]]
dev:12182023-08-25 07:21:39.679 PMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00616904000100
dev:12182023-08-25 07:21:39.623 PMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00606D02000400000000
dev:12182023-08-25 07:21:39.575 PMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=110 fncmd=600
Summary
This text will be hidden
Thank you for the logs - what is included seems fine! Your 'fading time' parameter is set to 60 . so the presence sensor should report inactivity after 60 seconds without motion detected.
The logs are however incomplete, I can expect about 40-50 lines of debug logs to follow the power off/on sequence. You will need to select more than one page of the live logs - while holding the mouse left button down, rotate the mouse wheel - this will scroll down the live logs page, allowing you to select all of the logs.
When you click on the Refresh button, do you see a lot of debug logs? Some devices will report back all their specific parameters on the Refresh command, some will not. You can try copying these logs, that follow the Refresh command.
Actually, what problem are you experiencing at the moment? (with the right SXM7L9XA profile)
Summary
dev:12182023-08-26 05:46:39.881 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B36D02000400000000
dev:12182023-08-26 05:46:38.275 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B26D02000400000000
dev:12182023-08-26 05:46:36.683 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B16D02000400000000
dev:12182023-08-26 05:46:35.093 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B06D02000400000000
dev:12182023-08-26 05:46:33.503 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AF6D02000400000000
dev:12182023-08-26 05:46:31.914 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AE6D02000400000000
dev:12182023-08-26 05:46:30.315 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AD6D02000400000000
dev:12182023-08-26 05:46:28.730 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AC6D02000400000000
dev:12182023-08-26 05:46:27.133 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AB6D02000400000000
dev:12182023-08-26 05:46:25.547 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AA6D02000400000000
dev:12182023-08-26 05:46:23.949 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A96D02000400000000
dev:12182023-08-26 05:46:22.357 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A86D02000400000000
dev:12182023-08-26 05:46:20.770 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A76D02000400000000
dev:12182023-08-26 05:46:19.221 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A66D02000400000000
dev:12182023-08-26 05:46:17.581 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A56D02000400000000
dev:12182023-08-26 05:46:15.998 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A46D02000400000000
dev:12182023-08-26 05:46:14.405 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A36D02000400000000
dev:12182023-08-26 05:46:12.807 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A26D02000400000000
dev:12182023-08-26 05:46:11.226 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A16D02000400000000
dev:12182023-08-26 05:46:09.622 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A06D02000400000000
dev:12182023-08-26 05:46:08.032 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009F6D02000400000000
dev:12182023-08-26 05:46:06.445 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009E6D02000400000000
dev:12182023-08-26 05:46:04.867 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009D6D02000400000000
dev:12182023-08-26 05:46:03.261 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009C6D02000400000000
dev:12182023-08-26 05:46:01.670 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009B6D02000400000000
dev:12182023-08-26 05:46:00.078 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009A6D02000400000000
dev:12182023-08-26 05:45:58.481 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00996D02000400000000
dev:12182023-08-26 05:45:56.888 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00986D02000400000000
dev:12182023-08-26 05:45:55.298 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00976D02000400000000
dev:12182023-08-26 05:45:53.707 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00966D02000400000000
dev:12182023-08-26 05:45:52.114 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00956D02000400000000
dev:12182023-08-26 05:45:50.521 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00946D02000400000000
dev:12182023-08-26 05:45:48.930 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00936D02000400000000
dev:12182023-08-26 05:45:48.341 AMdebugKitchen Presence Sensor ignored illuminance event 5 lux - change is less than 5 lux threshold!
dev:12182023-08-26 05:45:48.339 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=104 fncmd=5
dev:12182023-08-26 05:45:48.335 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00926802000400000005, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 92, 68, 02, 00, 04, 00, 00, 00, 05]]
dev:12182023-08-26 05:45:48.333 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00926802000400000005
dev:12182023-08-26 05:45:47.732 AMdebugKitchen Presence Sensor ignored motion inactive event after 131s
dev:12182023-08-26 05:45:47.730 AMdebugKitchen Presence Sensor radar presence event DP=0x69 (105) fncmd = 0
dev:12182023-08-26 05:45:47.729 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=4 dp=105 fncmd=0
dev:12182023-08-26 05:45:47.725 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00916904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 91, 69, 04, 00, 01, 00]]
dev:12182023-08-26 05:45:47.723 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00916904000100
dev:12182023-08-26 05:45:47.673 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00906D02000400000000
dev:12182023-08-26 05:45:47.609 AMinfoKitchen Presence Sensor received YXZBRB58/SXM7L9XA radar fading time : 60 seconds (600)
dev:12182023-08-26 05:45:47.607 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=110 fncmd=600
dev:12182023-08-26 05:45:47.603 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008F6E02000400000258, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 8F, 6E, 02, 00, 04, 00, 00, 02, 58]]
dev:12182023-08-26 05:45:47.601 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008F6E02000400000258
dev:12182023-08-26 05:45:47.548 AMinfoKitchen Presence Sensor received YXZBRB58/SXM7L9XA radar detection delay : 0.2 seconds (2)
dev:12182023-08-26 05:45:47.546 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=111 fncmd=2
dev:12182023-08-26 05:45:47.542 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008E6F02000400000002, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 8E, 6F, 02, 00, 04, 00, 00, 00, 02]]
dev:12182023-08-26 05:45:47.540 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008E6F02000400000002
dev:12182023-08-26 05:45:47.489 AMinfoKitchen Presence Sensor received YXZBRB58/SXM7L9XA Radar Minimum detection distance : 0.25 m
dev:12182023-08-26 05:45:47.488 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=108 fncmd=25
dev:12182023-08-26 05:45:47.484 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008D6C02000400000019, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 8D, 6C, 02, 00, 04, 00, 00, 00, 19]]
dev:12182023-08-26 05:45:47.482 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008D6C02000400000019
dev:12182023-08-26 05:45:47.444 AMinfoKitchen Presence Sensor received YXZBRB58/SXM7L9XA Radar sensitivity : 7
dev:12182023-08-26 05:45:47.442 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=106 fncmd=7
dev:12182023-08-26 05:45:47.439 AMdebugKitchen Presence Sensor parse (_T
Summary
The detector becomes inactive after about 1 min. Activates on entry.
This is the same as before I reinstalled the device.
This is exactly your setting of the ‘Fading time’, as seen from the logs.
Have you tried changing the default preferences?
How do I keep it on while someone is in the room? It goes off when I'm in the room.
What distance you are staying away from the sensor?
Does the sensor become inactive even if you are standing close to it?
I'm about 2 feet away. Yes it turns off the light while in the room.
Okay, I will be looking further what could be wrong.
I have pushed an update with one line pf code change only:
ver. 1.4.5 2023-08-26 kkossev - (dev. branch) reduced debug logs
The logs that you shared until now cover very short time periods. All that is captured is OK, but I don't see the moment when the device first reports inactivity. The new version should produce less log lines, so please try to include longer reporting period - from the time when the motion is detected, till the time when the motion is reported as inactive (lights go off). This will be probably several minutes time interval, but without it I don't see what is going on.
Thanks will do
I've tried it on anther light, kitchen too busy. It looks like it working.
On at 10:13:30 left the room
off at10:14:33....
On 10: 15. don't hold me to the exact times.
Going to move back to the kitchen and see hoe it works.
dev:12182023-08-26 10:15:19.583 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00216D020004000001BA
dev:12182023-08-26 10:15:17.991 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00206D02000400000113
dev:12182023-08-26 10:15:17.403 AMdebugKitchen Presence Sensor ignored illuminance event 6 lux - change is less than 5 lux threshold!
dev:12182023-08-26 10:15:17.400 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=104 fncmd=6
dev:12182023-08-26 10:15:17.398 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001F6802000400000006, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1F, 68, 02, 00, 04, 00, 00, 00, 06]]
dev:12182023-08-26 10:15:17.394 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001F6802000400000006
dev:12182023-08-26 10:15:16.447 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001E6D02000400000033
dev:12182023-08-26 10:15:16.409 AMdebugKitchen Presence Sensor ignored illuminance event 7 lux - change is less than 5 lux threshold!
dev:12182023-08-26 10:15:16.407 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=104 fncmd=7
dev:12182023-08-26 10:15:16.405 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001D6802000400000007, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1D, 68, 02, 00, 04, 00, 00, 00, 07]]
dev:12182023-08-26 10:15:16.401 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001D6802000400000007
dev:12182023-08-26 10:15:15.413 AMinfoKitchen Presence Sensor Illuminance is 10 Lux
dev:12182023-08-26 10:15:15.409 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=104 fncmd=10
dev:12182023-08-26 10:15:15.407 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001C680200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1C, 68, 02, 00, 04, 00, 00, 00, 0A]]
dev:12182023-08-26 10:15:15.403 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001C680200040000000A
dev:12182023-08-26 10:14:58.894 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00116D02000400000032
dev:12182023-08-26 10:14:57.300 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00106D0200040000005F
dev:12182023-08-26 10:14:55.704 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 000F6D020004000000B6
dev:12182023-08-26 10:14:54.111 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 000E6D02000400000071
dev:12182023-08-26 10:14:52.519 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 000D6D02000400000035
dev:12182023-08-26 10:14:50.928 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 000C6D0200040000007B
dev:12182023-08-26 10:14:49.341 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 000B6D02000400000085
dev:12182023-08-26 10:14:47.743 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 000A6D0200040000007E
dev:12182023-08-26 10:14:46.166 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00096D02000400000000
dev:12182023-08-26 10:14:44.772 AMinfoKitchen Presence Sensor Detected motion
dev:12182023-08-26 10:14:44.770 AMdebugKitchen Presence Sensor radar presence event DP=0x69 (105) fncmd = 1
dev:12182023-08-26 10:14:44.768 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=4 dp=105 fncmd=1
dev:12182023-08-26 10:14:44.766 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00086904000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 08, 69, 04, 00, 01, 01]]
dev:12182023-08-26 10:14:44.762 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00086904000101
dev:12182023-08-26 10:14:44.558 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00076D02000400000000
dev:12182023-08-26 10:14:43.168 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00066D02000400000000
dev:12182023-08-26 10:14:41.376 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00056D02000400000000
dev:12182023-08-26 10:14:39.789 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00046D02000400000000
dev:12182023-08-26 10:14:38.398 AMinfoKitchen Presence Sensor Motion reset to inactive after 97s
dev:12182023-08-26 10:14:38.396 AMdebugKitchen Presence Sensor radar presence event DP=0x69 (105) fncmd = 0
dev:12182023-08-26 10:14:38.394 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=4 dp=105 fncmd=0
dev:12182023-08-26 10:14:38.392 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00036904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 03, 69, 04, 00, 01, 00]]
dev:12182023-08-26 10:14:10.741 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00F16D0200040000009D
dev:12182023-08-26 10:14:09.151 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00F06D02000400000047
dev:12182023-08-26 10:14:07.569 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00EF6D020004000000C4
dev:12182023-08-26 10:14:05.956 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00EE6D020004000000F4
dev:12182023-08-26 10:14:04.380 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00ED6D02000400000030
dev:12182023-08-26 10:14:02.778 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00EC6D02000400000035
dev:12182023-08-26 10:14:01.182 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00EB6D02000400000027
dev:12182023-08-26 10:13:59.594 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00EA6D02000400000075
dev:12182023-08-26 10:13:57.996 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E96D02000400000104
dev:12182023-08-26 10:13:56.409 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E86D020004000000B1
dev:12182023-08-26 10:13:54.815 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E76D02000400000093
dev:12182023-08-26 10:13:53.222 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E66D0200040000009B
dev:12182023-08-26 10:13:53.144 AMinfoKitchen Presence Sensor Tuya check-in (application version is 4A)
dev:12182023-08-26 10:13:53.141 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:335B010000180100204AE2FF2038E4FF2000, dni:335B, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:4A, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:12182023-08-26 10:13:53.136 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = read attr - raw: 335B010000180100204AE2FF2038E4FF2000, dni: 335B, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 4AE2FF2038E4FF2000
dev:12182023-08-26 10:13:51.632 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E56D0200040000004A
dev:12182023-08-26 10:13:50.052 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E46D020004000000A9
dev:12182023-08-26 10:13:48.446 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E36D020004000000A4
dev:12182023-08-26 10:13:46.854 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E26D020004000000D6
dev:12182023-08-26 10:13:45.264 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E16D02000400000099
dev:12182023-08-26 10:13:43.685 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00E06D020004000000CB
dev:12182023-08-26 10:13:42.079 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00DF6D02000400000144
dev:12182023-08-26 10:13:40.487 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00DE6D02000400000148
dev:12182023-08-26 10:13:38.901 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00DD6D020004000000EB
dev:12182023-08-26 10:13:37.304 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00DC6D0200040000009F
dev:12182023-08-26 10:13:35.716 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00DB6D0200040000009E
dev:12182023-08-26 10:13:34.120 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00DA6D02000400000068
dev:12182023-08-26 10:13:32.541 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D96D02000400000097
dev:12182023-08-26 10:13:30.937 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D86D0200040000008F
dev:12182023-08-26 10:13:29.345 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D76D02000400000068
dev:12182023-08-26 10:13:27.753 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D66D02000400000047
dev:12182023-08-26 10:13:26.160 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D56D02000400000040
dev:12182023-08-26 10:13:24.574 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D46D0200040000009D
dev:12182023-08-26 10:13:22.976 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D36D020004000000DB
dev:12182023-08-26 10:13:21.385 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D26D020004000000CF
dev:12182023-08-26 10:13:19.794 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D16D020004000000A0
dev:12182023-08-26 10:13:18.205 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00D06D02000400000043
dev:12182023-08-26 10:13:16.608 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00CF6D02000400000055
dev:12182023-08-26 10:13:15.217 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00CE6D02000400000050
dev:12182023-08-26 10:13:13.427 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00CD6D02000400000055
dev:12182023-08-26 10:13:10.243 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00CC6D0200040000004C
dev:12182023-08-26 10:13:08.660 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00CB6D0200040000004B
dev:12182023-08-26 10:13:07.058 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00CA6D02000400000048
dev:12182023-08-26 10:13:05.465 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C96D02000400000075
dev:12182023-08-26 10:13:03.875 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C86D02000400000110
dev:12182023-08-26 10:13:02.284 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C76D02000400000000
dev:12182023-08-26 10:13:00.913 AMinfoKitchen Presence Sensor Detected motion
dev:12182023-08-26 10:13:00.911 AMdebugKitchen Presence Sensor radar presence event DP=0x69 (105) fncmd = 1
dev:12182023-08-26 10:13:00.909 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=4 dp=105 fncmd=1
dev:12182023-08-26 10:13:00.907 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C66904000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C6, 69, 04, 00, 01, 01]]
dev:12182023-08-26 10:13:00.903 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C66904000101
dev:12182023-08-26 10:12:59.696 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C56D02000400000000
dev:12182023-08-26 10:12:58.102 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C46D02000400000000
dev:12182023-08-26 10:12:56.516 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C36D02000400000000
dev:12182023-08-26 10:12:54.930 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C26D02000400000000
dev:12182023-08-26 10:12:53.536 AMinfoKitchen Presence Sensor Motion reset to inactive after 124s
dev:12182023-08-26 10:12:53.534 AMdebugKitchen Presence Sensor radar presence event DP=0x69 (105) fncmd = 0
dev:12182023-08-26 10:12:53.532 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=4 dp=105 fncmd=0
dev:12182023-08-26 10:12:53.530 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C16904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C1, 69, 04, 00, 01, 00]]
dev:12182023-08-26 10:12:53.526 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C16904000100
dev:12182023-08-26 10:12:52.339 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00C06D020004000001D8
dev:12182023-08-26 10:12:49.150 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00BF6D020004000001DC
dev:12182023-08-26 10:12:47.567 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00BE6D020004000001C0
dev:12182023-08-26 10:12:41.190 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00BD6D020004000001B5
dev:12182023-08-26 10:12:39.613 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00BC6D020004000001BE
dev:12182023-08-26 10:12:38.013 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00BB6D020004000001CA
dev:12182023-08-26 10:12:36.429 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00BA6D020004000000F3
dev:12182023-08-26 10:12:34.824 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B96D020004000000CF
dev:12182023-08-26 10:12:33.231 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B86D020004000000A8
dev:12182023-08-26 10:12:31.651 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B76D020004000000D1
dev:12182023-08-26 10:12:30.059 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B66D020004000000BC
dev:12182023-08-26 10:12:28.468 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B56D020004000000F4
dev:12182023-08-26 10:12:26.875 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B46D020004000000CC
dev:12182023-08-26 10:12:25.285 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B36D02000400000136
dev:12182023-08-26 10:12:23.693 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B26D0200040000013A
dev:12182023-08-26 10:12:22.100 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B16D0200040000008C
dev:12182023-08-26 10:12:20.509 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00B06D020004000000CB
dev:12182023-08-26 10:12:18.921 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AF6D020004000000AF
dev:12182023-08-26 10:12:17.317 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AE6D020004000000A0
dev:12182023-08-26 10:12:14.128 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AD6D02000400000040
dev:12182023-08-26 10:12:12.539 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AC6D0200040000002E
dev:12182023-08-26 10:12:10.960 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AB6D020004000000AA
dev:12182023-08-26 10:12:09.354 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00AA6D02000400000123
dev:12182023-08-26 10:12:07.761 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A96D020004000000A8
dev:12182023-08-26 10:12:06.169 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A86D02000400000033
dev:12182023-08-26 10:12:04.578 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A76D0200040000007D
dev:12182023-08-26 10:12:02.986 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A66D020004000000C5
dev:12182023-08-26 10:12:01.399 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A56D0200040000002B
dev:12182023-08-26 10:11:59.807 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A46D0200040000003C
dev:12182023-08-26 10:11:58.241 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A36D02000400000069
dev:12182023-08-26 10:11:56.618 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A26D020004000000D2
dev:12182023-08-26 10:11:55.026 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A16D020004000000AE
dev:12182023-08-26 10:11:53.435 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00A06D0200040000002E
dev:12182023-08-26 10:11:51.842 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009F6D020004000000F5
dev:12182023-08-26 10:11:50.254 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009E6D0200040000007D
dev:12182023-08-26 10:11:48.663 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009D6D02000400000099
dev:12182023-08-26 10:11:47.064 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009C6D02000400000071
dev:12182023-08-26 10:11:45.471 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009B6D020004000000C6
dev:12182023-08-26 10:11:43.894 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 009A6D02000400000033
dev:12182023-08-26 10:11:42.288 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00996D02000400000043
dev:12182023-08-26 10:11:40.696 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00986D020004000000BD
dev:12182023-08-26 10:11:39.105 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00976D020004000000B8
dev:12182023-08-26 10:11:37.512 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00966D020004000000B6
dev:12182023-08-26 10:11:35.920 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00956D02000400000054
dev:12182023-08-26 10:11:34.328 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00946D020004000000F6
dev:12182023-08-26 10:11:32.735 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00936D020004000000A8
dev:12182023-08-26 10:11:31.143 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00926D0200040000008A
dev:12182023-08-26 10:11:29.555 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00916D02000400000052
dev:12182023-08-26 10:11:27.964 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00906D02000400000062
dev:12182023-08-26 10:11:26.375 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008F6D02000400000056
dev:12182023-08-26 10:11:24.775 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008E6D0200040000006D
dev:12182023-08-26 10:11:21.590 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008D6D0200040000007B
dev:12182023-08-26 10:11:20.003 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008C6D0200040000007F
dev:12182023-08-26 10:11:18.423 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008B6D02000400000096
dev:12182023-08-26 10:11:16.824 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 008A6D02000400000050
dev:12182023-08-26 10:11:15.224 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00896D0200040000003C
dev:12182023-08-26 10:11:13.635 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00886D0200040000006C
dev:12182023-08-26 10:11:12.042 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00876D02000400000069
dev:12182023-08-26 10:11:10.445 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00866D02000400000036
dev:12182023-08-26 10:11:08.868 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00856D0200040000002E
dev:12182023-08-26 10:11:07.262 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00846D02000400000054
dev:12182023-08-26 10:11:05.870 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00836D02000400000046
dev:12182023-08-26 10:11:04.078 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00826D0200040000003F
dev:12182023-08-26 10:11:02.492 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00816D0200040000003B
dev:12182023-08-26 10:11:00.894 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00806D0200040000009D
dev:12182023-08-26 10:10:59.302 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 007F6D02000400000056
dev:12182023-08-26 10:10:57.729 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 007E6D0200040000006A
dev:12182023-08-26 10:10:57.693 AMinfoKitchen Presence Sensor Tuya check-in (application version is 4A)
dev:12182023-08-26 10:10:57.691 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:335B010000180100204AE2FF2038E4FF2000, dni:335B, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:4A, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:12182023-08-26 10:10:57.685 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = read attr - raw: 335B010000180100204AE2FF2038E4FF2000, dni: 335B, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 4AE2FF2038E4FF2000
dev:12182023-08-26 10:10:56.118 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 007D6D02000400000073
dev:12182023-08-26 10:10:54.536 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 007C6D0200040000006B
dev:12182023-08-26 10:10:52.939 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 007B6D0200040000008C
dev:12182023-08-26 10:10:52.024 AMdebugKitchen Presence Sensor deviceHealthCheck - online (notPresentCounter=1)
dev:12182023-08-26 10:10:51.356 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 007A6D02000400000000
dev:12182023-08-26 10:10:49.992 AMinfoKitchen Presence Sensor Detected motion
dev:12182023-08-26 10:10:49.989 AMdebugKitchen Presence Sensor radar presence event DP=0x69 (105) fncmd = 1
dev:12182023-08-26 10:10:49.987 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=4 dp=105 fncmd=1
dev:12182023-08-26 10:10:49.985 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00796904000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 79, 69, 04, 00, 01, 01]]
dev:12182023-08-26 10:10:49.951 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00796904000101
dev:12182023-08-26 10:10:48.557 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00786D02000400000000
dev:12182023-08-26 10:10:46.966 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00776D02000400000000
dev:12182023-08-26 10:10:45.373 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00766D02000400000000
dev:12182023-08-26 10:10:43.790 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00756D02000400000000
dev:12182023-08-26 10:10:42.187 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00746D02000400000000
dev:12182023-08-26 10:10:40.818 AMinfoKitchen Presence Sensor Motion reset to inactive after 133s
dev:12182023-08-26 10:10:40.816 AMdebugKitchen Presence Sensor radar presence event DP=0x69 (105) fncmd = 0
dev:12182023-08-26 10:10:40.814 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=4 dp=105 fncmd=0
dev:12182023-08-26 10:10:40.812 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00736904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 73, 69, 04, 00, 01, 00]]
dev:12182023-08-26 10:10:40.808 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00736904000100
dev:12182023-08-26 10:10:39.407 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00726D0200040000007B
dev:12182023-08-26 10:10:37.811 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00716D02000400000062
dev:12182023-08-26 10:10:36.219 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00706D020004000000A2
dev:12182023-08-26 10:10:34.637 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 006F6D0200040000002E
dev:12182023-08-26 10:10:33.040 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 006E6D0200040000006D
dev:12182023-08-26 10:10:31.443 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 006D6D02000400000037
dev:12182023-08-26 10:10:29.851 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 006C6D0200040000005E
dev:12182023-08-26 10:10:28.259 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 006B6D0200040000005F
dev:12182023-08-26 10:10:26.681 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 006A6D02000400000065
dev:12182023-08-26 10:10:25.078 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00696D02000400000064
dev:12182023-08-26 10:10:23.485 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00686D02000400000061
dev:12182023-08-26 10:10:21.906 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00676D02000400000044
dev:12182023-08-26 10:10:20.300 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00666D0200040000007A
dev:12182023-08-26 10:10:18.713 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00656D02000400000067
dev:12182023-08-26 10:10:17.350 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00646D02000400000048
dev:12182023-08-26 10:10:17.339 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00646D02000400000048
dev:12182023-08-26 10:10:15.524 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00636D0200040000002B
dev:12182023-08-26 10:10:13.932 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00626D02000400000048
dev:12182023-08-26 10:10:12.348 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00616D02000400000042
dev:12182023-08-26 10:10:10.795 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00606D020004000000A0
dev:12182023-08-26 10:10:09.760 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 005F6D02000400000051
dev:12182023-08-26 10:10:07.565 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 005E6D0200040000005B
dev:12182023-08-26 10:10:05.977 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 005D6D0200040000005D
dev:12182023-08-26 10:10:04.381 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 005C6D02000400000057
dev:12182023-08-26 10:10:02.789 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 005B6D0200040000008E
dev:12182023-08-26 10:10:01.199 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 005A6D02000400000071
dev:12182023-08-26 10:09:59.605 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00596D02000400000066
dev:12182023-08-26 10:09:58.013 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00586D0200040000005E
dev:12182023-08-26 10:09:56.832 AMdebugKitchen Presence Sensor ignored illuminance event 3 lux - change is less than 5 lux threshold!
dev:12182023-08-26 10:09:56.830 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=104 fncmd=3
dev:12182023-08-26 10:09:56.827 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00576802000400000003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 57, 68, 02, 00, 04, 00, 00, 00, 03]]
dev:12182023-08-26 10:09:56.823 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00576802000400000003
dev:12182023-08-26 10:09:56.421 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00566D0200040000006B
dev:12182023-08-26 10:09:54.829 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00556D02000400000060
dev:12182023-08-26 10:09:53.237 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00546D020004000000A8
dev:12182023-08-26 10:09:51.658 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00536D0200040000006C
dev:12182023-08-26 10:09:50.057 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00526D0200040000005C
dev:12182023-08-26 10:09:48.465 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00516D0200040000005A
dev:12182023-08-26 10:09:46.869 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00506D0200040000005D
dev:12182023-08-26 10:09:45.285 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 004F6D020004000000C2
dev:12182023-08-26 10:09:43.702 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 004E6D020004000000F7
dev:12182023-08-26 10:09:42.104 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 004D6D02000400000128
dev:12182023-08-26 10:09:40.501 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 004C6D020004000000E1
dev:12182023-08-26 10:09:38.909 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 004B6D02000400000099
dev:12182023-08-26 10:09:37.326 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 004A6D02000400000092
dev:12182023-08-26 10:09:35.725 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00496D0200040000009E
dev:12182023-08-26 10:09:34.148 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00486D02000400000040
dev:12182023-08-26 10:09:32.542 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00476D02000400000035
dev:12182023-08-26 10:09:30.951 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00466D02000400000096
dev:12182023-08-26 10:09:29.358 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00456D02000400000092
dev:12182023-08-26 10:09:27.775 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00446D0200040000006A
dev:12182023-08-26 10:09:26.174 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00436D0200040000008E
dev:12182023-08-26 10:09:24.581 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00426D02000400000064
dev:12182023-08-26 10:09:22.989 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00416D02000400000069
dev:12182023-08-26 10:09:21.397 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00406D02000400000047
dev:12182023-08-26 10:09:19.812 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 003F6D02000400000052
dev:12182023-08-26 10:09:18.215 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 003E6D02000400000064
dev:12182023-08-26 10:09:16.633 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 003D6D02000400000069
dev:12182023-08-26 10:09:15.035 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 003C6D02000400000044
dev:12182023-08-26 10:09:13.439 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 003B6D02000400000037
dev:12182023-08-26 10:09:11.847 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 003A6D02000400000050
dev:12182023-08-26 10:09:10.259 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00396D02000400000047
dev:12182023-08-26 10:09:08.663 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00386D02000400000043
dev:12182023-08-26 10:09:07.075 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00376D02000400000046
dev:12182023-08-26 10:09:05.479 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00366D02000400000049
dev:12182023-08-26 10:09:03.886 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00356D02000400000044
dev:12182023-08-26 10:09:02.509 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00346D0200040000004F
dev:12182023-08-26 10:09:00.704 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00336D02000400000055
dev:12182023-08-26 10:08:59.111 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00326D0200040000003F
dev:12182023-08-26 10:08:57.518 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00316D02000400000052
dev:12182023-08-26 10:08:55.926 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00306D0200040000004F
dev:12182023-08-26 10:08:54.333 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 002F6D02000400000055
dev:12182023-08-26 10:08:52.741 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 002E6D0200040000004B
dev:12182023-08-26 10:08:51.149 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 002D6D02000400000052
dev:12182023-08-26 10:08:49.557 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 002C6D02000400000054
dev:12182023-08-26 10:08:47.991 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 002B6D02000400000068
dev:12182023-08-26 10:08:46.377 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 002A6D02000400000079
dev:12182023-08-26 10:08:44.785 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00296D0200040000004E
dev:12182023-08-26 10:08:43.189 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00286D0200040000003B
dev:12182023-08-26 10:08:41.610 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00276D02000400000047
dev:12182023-08-26 10:08:40.005 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00266D0200040000005C
dev:12182023-08-26 10:08:38.413 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00256D02000400000066
dev:12182023-08-26 10:08:36.826 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00246D0200040000002E
dev:12182023-08-26 10:08:35.238 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00236D02000400000033
dev:12182023-08-26 10:08:33.637 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00226D02000400000034
dev:12182023-08-26 10:08:32.045 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00216D0200040000003F
dev:12182023-08-26 10:08:30.453 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 00206D02000400000047
dev:12182023-08-26 10:08:28.879 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001F6D02000400000025
dev:12182023-08-26 10:08:27.488 AMinfoKitchen Presence Sensor Detected motion
dev:12182023-08-26 10:08:27.486 AMdebugKitchen Presence Sensor radar presence event DP=0x69 (105) fncmd = 1
dev:12182023-08-26 10:08:27.484 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=4 dp=105 fncmd=1
dev:12182023-08-26 10:08:27.482 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001E6904000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1E, 69, 04, 00, 01, 01]]
dev:12182023-08-26 10:08:27.479 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001E6904000101
dev:12182023-08-26 10:08:26.778 AMdebugKitchen Presence Sensor Tuya descMap?.command = 11 descMap.data = [00, 15, 41]
dev:12182023-08-26 10:08:26.775 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 11 01 001541, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 15, 41]]
dev:12182023-08-26 10:08:26.772 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 11 01 001541
dev:12182023-08-26 10:08:26.285 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001D6D02000400000000
dev:12182023-08-26 10:08:25.702 AMdebugKitchen Presence Sensor ignored illuminance event 2 lux - change is less than 5 lux threshold!
dev:12182023-08-26 10:08:25.700 AMdebugKitchen Presence Sensor Tuya cluster: dp_id=2 dp=104 fncmd=2
dev:12182023-08-26 10:08:25.698 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001C6802000400000002, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:335B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1C, 68, 02, 00, 04, 00, 00, 00, 02]]
dev:12182023-08-26 10:08:25.694 AMdebugKitchen Presence Sensor parse (_TZE204_sxm7l9xa, 1.4.4 2023/08/18 10:43 PM) description = catchall: 0104 EF00 01 01 0040 00 335B 01 00 0000 02 01 001C6802000400000002
Summary
This text will be hidden
I had to delete some of the code to allow me to reply
That's because you did not update the driver to the latest, less debug intensive version and it produced a lot of debug text lines.
The logs weren't included successfully in the Summary section as well, but the most important is whether the sensor is working as expected or not.
This are the filtered motion active/inactive events ( present / not present)
	Line  33: dev:12182023-08-26 10:14:44.772 AMinfoKitchen Presence Sensor Detected motion
	Line  42: dev:12182023-08-26 10:14:38.398 AMinfoKitchen Presence Sensor Motion reset to inactive after 97s
	Line  93: dev:12182023-08-26 10:13:00.913 AMinfoKitchen Presence Sensor Detected motion
	Line 102: dev:12182023-08-26 10:12:53.536 AMinfoKitchen Presence Sensor Motion reset to inactive after 124s
	Line 182: dev:12182023-08-26 10:10:49.992 AMinfoKitchen Presence Sensor Detected motion
	Line 192: dev:12182023-08-26 10:10:40.818 AMinfoKitchen Presence Sensor Motion reset to inactive after 133s
	Line 285: dev:12182023-08-26 10:08:27.488 AMinfoKitchen Presence Sensor Detected motion
Were you in front of the sensor all the time between 10:08:27 and 10:14:44 time period?
The sensor has lost the presence detection 3 times for these 6 minutes ... ?
I see from the debug logs, that the sensor reported "distance to the detected object 0 ", i.e. nothing detected at the time when it switched to 'motion inactive'. This will happen if you have moved away of the radar detection range at that time.
Yes I was on front of the detector. That's about right 3 times. Now it's back in the kitchen for testing. My wife is working and the light is staying on. Before it kept shutting off and turning on. I'll let you know when the room is empty and the light goes out.
