Tuya module not working
Hi there, I've paired this Tuya Module (I'm told it's Tuya) and HE has selected the Zemismart driver. Unfortunately the driver doesn't work with this device. Has anyone got one of these modules and can you advise which driver I should be using. @kkossev are you familiar with this model at all? Thanks in advance
These are some of the logs when I turn on/off, configure and initialise etc
Hi Stue,
The Zemismart driver is the right one for this device,
Are you sure that the device has stayed connected to your HE hub after the initial pairing?
What happens if you click on the 'Ping()' button - do you see a numeric RTT value or 'Timout!' ?
Hi Kkossev,
It would seem that the device has gone offline. I tried several pairing attempts and each time it did pair but then was immediately non responsive. What are your thoughts here? Could this be a hardware defect or do I have other options to try. Appreciated in advance :+1:
Use the Double Luck Voodoo to pair the device to your C-8 hub.
Interesting post. I'll try this tomorrow evening and feedback. Thanks for your suggestion here. Very helpful indeed and appreciated :+1:
@kkossev you never cease to amaze me. Double Luck Voodoo has worked. You're incredible! :slight_smile: Thank you yet again!
