Hi @molod ,
Thank you for catching this! The fix for the negative temperatures is available now in the dev. branch version 1.1.1
We are still blessed with good weather here, the outside temperatures very rarely fall below 0 deg Celsius : )
Hi @molod ,
Hi @kkossev, I installed the fix (via HPM), temps still coming back as 650 degrees plus, any steps you'd like me to take to help you to further isolate the issue? Glad you enjoying good weather in Bulgaria.
The fix is not available via HPM yet. You have to manually update the driver...
Locate it in the Drivers Code page, enter edit mode and click on the Import button is the fastest way to update.
running well, you can see blue temp chart is inline with other temp sensors I have and spike to 20 is then I took it in to figure out what's that 650+ degrees, so for now I'd say this 10$ zigbee one is good deal...
So, I have one of these generic TS201 sensors I am trying to hook up. I tried to join it using the Generic Zigbee Temperature and Humidity Sensor driver but got nothing. So I deleted that and loaded the driver from @kkossev, rejoined the device, and it selected the proper driver automatically and got the battery data, but no temp or humidity.
I then tried manually selecting the model, but that gets me the message " Pending 2 configuration(s). Wake up the device!" Is there some special procedure to wake up a device? I tried pulling the batteries and hitting the reset button, but that changed nothing.
My device reports itself a bit differently than others in this thread:
I am still new to Hubitat, so please forgive me if I am asking about things that should be obvious.
i'd say just re-add it and it should be fine (add device -> zigbee -> start pairing)
Hi @CheezWiz ,
The same device has been used by others in HE, so we should be able to make it work. What puzzles me is that it didn't work with the HE inbuilt generic Zigbee drivers, this device should be using the standard Zigbee clusters.
Can you please check first that you are using the latest developments branch version of the Tuya driver? From within the HE Drivers Code page, locate the driver, click on it to enter into edit mode and then click on the Import button, Confirm the Import and after Save you should have the latest version running.
The 'Model Group' for this device should be 'TS0202'. I see now that it will not be automatically selected, so set it as TS0202 manually and click Save.
For your device you should NOT see "Pending configurations(s)...".
As suggested by @molod , the most effective way to make it working is to pair the device again. Do it close to the HE hub.
@molod & @kkossev, thank you for the assist!
Selecting the proper model and then adding it over the current device had it working instantly!
Hi Krassimir, I think I still need to pickup your brain regarding this sensor crossing zero threshold, this is nuts but our temperature is hovering around 0, and this is what happens (follow dark blue line)
dev:13142023-01-16 04:45:00.814 PMinfoThermometer at the entrance outside temperature is 7.45 °C
dev:13142023-01-16 04:45:00.809 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029E902, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:02E9, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:43:00.839 PMinfoThermometer at the entrance outside temperature is 7.82 °C
dev:13142023-01-16 04:43:00.834 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000290E03, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:030E, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:40:56.001 PMinfoThermometer at the entrance outside humidity is 34.5 % RH
dev:13142023-01-16 04:40:55.996 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A000021770D, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:0D77, clusterInt:1029, attrInt:0]
dev:13142023-01-16 04:40:55.823 PMinfoThermometer at the entrance outside temperature is 8.26 °C
dev:13142023-01-16 04:40:55.818 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000293A03, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:033A, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:39:00.879 PMinfoThermometer at the entrance outside temperature is 8.68 °C
dev:13142023-01-16 04:39:00.874 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000296403, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0364, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:37:00.881 PMinfoThermometer at the entrance outside temperature is 9.12 °C
dev:13142023-01-16 04:37:00.876 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000299003, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0390, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:35:00.922 PMinfoThermometer at the entrance outside temperature is 9.62 °C
dev:13142023-01-16 04:35:00.917 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029C203, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:03C2, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:33:00.920 PMinfoThermometer at the entrance outside temperature is 10.21 °C
dev:13142023-01-16 04:33:00.915 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029FD03, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:03FD, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:32:00.901 PMinfoThermometer at the entrance outside temperature is 10.52 °C
dev:13142023-01-16 04:32:00.896 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000291C04, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:041C, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:31:00.928 PMinfoThermometer at the entrance outside temperature is 10.86 °C
dev:13142023-01-16 04:31:00.923 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000293E04, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:043E, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:30:00.892 PMinfoThermometer at the entrance outside temperature is 11.22 °C
dev:13142023-01-16 04:30:00.888 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000296204, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0462, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:29:10.935 PMinfoThermometer at the entrance outside temperature is 11.62 °C (delayed)
dev:13142023-01-16 04:29:01.905 PMdebugThermometer at the entrance outside DELAYING 9 seconds event : [name:temperature, unit:°C, value:11.6, type:delayed, isStateChange:true, descriptionText:temperature is 11.62 °C]
dev:13142023-01-16 04:29:01.898 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000298A04, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:048A, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:29:00.976 PMinfoThermometer at the entrance outside temperature is 11.62 °C
dev:13142023-01-16 04:29:00.971 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000298A04, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:048A, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:28:00.899 PMinfoThermometer at the entrance outside temperature is 12.01 °C
dev:13142023-01-16 04:28:00.894 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029B104, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:04B1, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:27:00.971 PMinfoThermometer at the entrance outside temperature is 12.42 °C
dev:13142023-01-16 04:27:00.965 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029DA04, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:04DA, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:26:00.914 PMinfoThermometer at the entrance outside temperature is 12.91 °C
dev:13142023-01-16 04:26:00.909 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000290B05, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:050B, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:25:00.968 PMinfoThermometer at the entrance outside temperature is 13.45 °C
dev:13142023-01-16 04:25:00.964 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000294105, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0541, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:24:00.944 PMinfoThermometer at the entrance outside temperature is 14.06 °C
dev:13142023-01-16 04:24:00.939 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000297E05, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:057E, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:23:01.001 PMinfoThermometer at the entrance outside temperature is 14.7 °C
dev:13142023-01-16 04:23:00.996 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029BE05, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:05BE, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:22:00.955 PMinfoThermometer at the entrance outside temperature is 15.39 °C
dev:13142023-01-16 04:22:00.950 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000290306, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0603, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:21:01.019 PMinfoThermometer at the entrance outside temperature is 16.08 °C
dev:13142023-01-16 04:21:01.014 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000294806, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0648, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:20:00.977 PMinfoThermometer at the entrance outside temperature is 16.76 °C
dev:13142023-01-16 04:20:00.973 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000298C06, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:068C, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:19:01.051 PMinfoThermometer at the entrance outside temperature is 17.46 °C
dev:13142023-01-16 04:19:01.044 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029D206, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:06D2, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:18:01.001 PMinfoThermometer at the entrance outside temperature is 18.08 °C
dev:13142023-01-16 04:18:00.996 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000291007, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0710, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:17:01.060 PMinfoThermometer at the entrance outside temperature is 18.66 °C
dev:13142023-01-16 04:17:01.053 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000294A07, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:074A, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:16:01.030 PMinfoThermometer at the entrance outside temperature is 19.16 °C
dev:13142023-01-16 04:16:01.026 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000297C07, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:077C, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:15:01.078 PMinfoThermometer at the entrance outside temperature is 19.67 °C
dev:13142023-01-16 04:15:01.074 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029AF07, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:07AF, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:14:01.032 PMinfoThermometer at the entrance outside temperature is 20.12 °C
dev:13142023-01-16 04:14:01.027 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029DC07, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:07DC, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:13:01.080 PMinfoThermometer at the entrance outside temperature is 20.51 °C
dev:13142023-01-16 04:13:01.075 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000290308, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0803, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:12:01.025 PMinfoThermometer at the entrance outside temperature is 20.85 °C
dev:13142023-01-16 04:12:01.020 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000292508, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0825, clusterInt:1026, attrInt:0]
dev:13142023-01-16 04:10:56.175 PMinfoThermometer at the entrance outside humidity is 31.5 % RH
dev:13142023-01-16 04:10:56.166 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A000021520C, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:0C52, clusterInt:1029, attrInt:0]
dev:13142023-01-16 04:10:56.110 PMinfoThermometer at the entrance outside temperature is 21.16 °C
dev:13142023-01-16 04:10:56.096 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000294408, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0844, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:50:01.064 PMinfoThermometer at the entrance outside temperature is 21.64 °C
dev:13142023-01-16 03:50:01.059 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000297408, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0874, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:49:01.127 PMinfoThermometer at the entrance outside temperature is 21.96 °C
dev:13142023-01-16 03:49:01.113 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000299408, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0894, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:40:56.264 PMinfoThermometer at the entrance outside humidity is 35.8 % RH
dev:13142023-01-16 03:40:56.259 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A000021FB0D, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:0DFB, clusterInt:1029, attrInt:0]
dev:13142023-01-16 03:40:56.184 PMinfoThermometer at the entrance outside temperature is 22.59 °C
dev:13142023-01-16 03:40:56.180 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029D308, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:08D3, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:37:01.139 PMinfoThermometer at the entrance outside temperature is 22.32 °C
dev:13142023-01-16 03:37:01.135 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029B808, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:08B8, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:35:01.141 PMinfoThermometer at the entrance outside temperature is 21.99 °C
dev:13142023-01-16 03:35:01.135 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000299708, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0897, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:32:01.131 PMinfoThermometer at the entrance outside temperature is 21.57 °C
dev:13142023-01-16 03:32:01.125 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000296D08, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:086D, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:30:01.078 PMinfoThermometer at the entrance outside temperature is 20.99 °C
dev:13142023-01-16 03:30:01.073 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000293308, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0833, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:29:01.122 PMinfoThermometer at the entrance outside temperature is 20.66 °C
dev:13142023-01-16 03:29:01.118 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000291208, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0812, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:28:01.065 PMinfoThermometer at the entrance outside temperature is 20.35 °C
dev:13142023-01-16 03:28:01.061 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029F307, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:07F3, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:27:01.105 PMinfoThermometer at the entrance outside temperature is 19.95 °C
dev:13142023-01-16 03:27:01.100 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029CB07, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:07CB, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:26:02.176 PMinfoThermometer at the entrance outside humidity is 40.9 % RH
dev:13142023-01-16 03:26:02.171 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A000021FE0F, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:0FFE, clusterInt:1029, attrInt:0]
dev:13142023-01-16 03:26:01.050 PMinfoThermometer at the entrance outside temperature is 19.55 °C
dev:13142023-01-16 03:26:01.046 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029A307, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:07A3, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:25:01.089 PMinfoThermometer at the entrance outside temperature is 19.16 °C
dev:13142023-01-16 03:25:01.084 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000297C07, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:077C, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:24:01.025 PMinfoThermometer at the entrance outside temperature is 18.73 °C
dev:13142023-01-16 03:24:01.021 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000295107, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0751, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:23:01.070 PMinfoThermometer at the entrance outside temperature is 18.29 °C
dev:13142023-01-16 03:23:01.065 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000292507, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0725, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:22:01.033 PMinfoThermometer at the entrance outside temperature is 17.83 °C
dev:13142023-01-16 03:22:01.026 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029F706, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:06F7, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:21:01.069 PMinfoThermometer at the entrance outside temperature is 17.35 °C
dev:13142023-01-16 03:21:01.063 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029C706, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:06C7, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:20:00.993 PMinfoThermometer at the entrance outside temperature is 16.88 °C
dev:13142023-01-16 03:20:00.989 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000299806, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0698, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:19:01.051 PMinfoThermometer at the entrance outside temperature is 16.39 °C
dev:13142023-01-16 03:19:01.045 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000296706, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0667, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:18:00.996 PMinfoThermometer at the entrance outside temperature is 15.92 °C
dev:13142023-01-16 03:18:00.991 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000293806, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0638, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:17:01.047 PMinfoThermometer at the entrance outside temperature is 15.47 °C
dev:13142023-01-16 03:17:01.040 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000290B06, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:060B, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:16:00.991 PMinfoThermometer at the entrance outside temperature is 15.01 °C
dev:13142023-01-16 03:16:00.986 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029DD05, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:05DD, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:15:01.041 PMinfoThermometer at the entrance outside temperature is 14.57 °C
dev:13142023-01-16 03:15:01.033 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029B105, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:05B1, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:14:00.978 PMinfoThermometer at the entrance outside temperature is 14.06 °C
dev:13142023-01-16 03:14:00.973 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000297E05, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:057E, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:13:00.996 PMinfoThermometer at the entrance outside temperature is 13.55 °C
dev:13142023-01-16 03:13:00.992 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000294B05, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:054B, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:12:00.942 PMinfoThermometer at the entrance outside temperature is 13.06 °C
dev:13142023-01-16 03:12:00.937 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000291A05, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:051A, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:10:56.249 PMinfoThermometer at the entrance outside humidity is 47.1 % RH
dev:13142023-01-16 03:10:56.245 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A0000216712, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:1267, clusterInt:1029, attrInt:0]
dev:13142023-01-16 03:10:56.062 PMinfoThermometer at the entrance outside temperature is 12.42 °C
dev:13142023-01-16 03:10:56.057 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029DA04, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:04DA, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:10:00.921 PMinfoThermometer at the entrance outside temperature is 11.88 °C
dev:13142023-01-16 03:10:00.916 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029A404, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:04A4, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:09:00.929 PMinfoThermometer at the entrance outside temperature is 11.31 °C
dev:13142023-01-16 03:09:00.924 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000296B04, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:046B, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:08:00.928 PMinfoThermometer at the entrance outside temperature is 10.77 °C
dev:13142023-01-16 03:08:00.923 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000293504, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0435, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:07:00.974 PMinfoThermometer at the entrance outside temperature is 10.24 °C
dev:13142023-01-16 03:07:00.969 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000290004, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0400, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:06:00.920 PMinfoThermometer at the entrance outside temperature is 9.75 °C
dev:13142023-01-16 03:06:00.916 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029CF03, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:03CF, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:05:00.973 PMinfoThermometer at the entrance outside temperature is 9.35 °C
dev:13142023-01-16 03:05:00.969 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029A703, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:03A7, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:04:00.978 PMinfoThermometer at the entrance outside temperature is 9.04 °C
dev:13142023-01-16 03:04:00.973 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000298803, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0388, clusterInt:1026, attrInt:0]
dev:13142023-01-16 03:02:00.986 PMinfoThermometer at the entrance outside temperature is 8.68 °C
dev:13142023-01-16 03:02:00.981 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000296403, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0364, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:59:01.052 PMinfoThermometer at the entrance outside temperature is 8.33 °C
dev:13142023-01-16 02:59:01.047 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000294103, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0341, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:56:01.015 PMinfoThermometer at the entrance outside temperature is 8.0 °C
dev:13142023-01-16 02:56:01.010 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000292003, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0320, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:53:01.025 PMinfoThermometer at the entrance outside temperature is 7.67 °C
dev:13142023-01-16 02:53:01.020 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029FF02, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:02FF, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:49:01.033 PMinfoThermometer at the entrance outside temperature is 7.35 °C
dev:13142023-01-16 02:49:01.028 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029DF02, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:02DF, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:45:01.057 PMinfoThermometer at the entrance outside temperature is 7.01 °C
dev:13142023-01-16 02:45:01.052 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029BD02, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:02BD, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:40:56.266 PMinfoThermometer at the entrance outside humidity is 49.6 % RH
dev:13142023-01-16 02:40:56.257 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A0000215D13, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:135D, clusterInt:1029, attrInt:0]
dev:13142023-01-16 02:40:56.183 PMinfoThermometer at the entrance outside temperature is 6.69 °C
dev:13142023-01-16 02:40:56.178 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000299D02, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:029D, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:38:01.102 PMinfoThermometer at the entrance outside temperature is 6.44 °C
dev:13142023-01-16 02:38:01.089 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000298402, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0284, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:29:01.121 PMinfoThermometer at the entrance outside temperature is 6.11 °C
dev:13142023-01-16 02:29:01.116 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000296302, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0263, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:23:01.127 PMinfoThermometer at the entrance outside temperature is 5.78 °C
dev:13142023-01-16 02:23:01.122 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000294202, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0242, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:18:01.157 PMinfoThermometer at the entrance outside temperature is 5.42 °C
dev:13142023-01-16 02:18:01.143 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000291E02, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:021E, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:10:57.406 PMinfoThermometer at the entrance outside humidity is 51.5 % RH
dev:13142023-01-16 02:10:57.397 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A0000211D14, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:141D, clusterInt:1029, attrInt:0]
dev:13142023-01-16 02:10:56.308 PMinfoThermometer at the entrance outside temperature is 5.08 °C
dev:13142023-01-16 02:10:56.303 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029FC01, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:01FC, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:07:32.594 PMdebugThermometer at the entrance outside Battery Percentage rawValue = 200 -> 100%
dev:13142023-01-16 02:07:32.586 PMdebugThermometer at the entrance outside parse() descMap = [raw:981501000110210020C82000201E, dni:9815, endpoint:01, cluster:0001, size:10, attrId:0021, encoding:20, command:0A, value:C8, clusterInt:1, attrInt:33, additionalAttrs:[[value:1E, encoding:20, attrId:0020, consumedBytes:4, attrInt:32]]]
dev:13142023-01-16 02:07:01.176 PMinfoThermometer at the entrance outside temperature is 4.87 °C
dev:13142023-01-16 02:07:01.170 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029E701, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:01E7, clusterInt:1026, attrInt:0]
dev:13142023-01-16 02:02:01.246 PMinfoThermometer at the entrance outside temperature is 4.51 °C
dev:13142023-01-16 02:02:01.232 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029C301, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:01C3, clusterInt:1026, attrInt:0]
dev:13142023-01-16 01:55:01.274 PMinfoThermometer at the entrance outside temperature is 4.15 °C
dev:13142023-01-16 01:55:01.267 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000299F01, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:019F, clusterInt:1026, attrInt:0]
dev:13142023-01-16 01:47:01.353 PMinfoThermometer at the entrance outside temperature is 3.83 °C
dev:13142023-01-16 01:47:01.340 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000297F01, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:017F, clusterInt:1026, attrInt:0]
dev:13142023-01-16 01:40:56.607 PMinfoThermometer at the entrance outside humidity is 52.3 % RH
dev:13142023-01-16 01:40:56.598 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A0000217014, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:1470, clusterInt:1029, attrInt:0]
dev:13142023-01-16 01:40:56.526 PMinfoThermometer at the entrance outside temperature is 3.5 °C
dev:13142023-01-16 01:40:56.521 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000295E01, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:015E, clusterInt:1026, attrInt:0]
dev:13142023-01-16 01:36:01.411 PMinfoThermometer at the entrance outside temperature is 3.19 °C
dev:13142023-01-16 01:36:01.397 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000293F01, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:013F, clusterInt:1026, attrInt:0]
dev:13142023-01-16 01:21:01.534 PMinfoThermometer at the entrance outside temperature is 2.86 °C
dev:13142023-01-16 01:21:01.520 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000291E01, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:011E, clusterInt:1026, attrInt:0]
dev:13142023-01-16 01:10:56.862 PMinfoThermometer at the entrance outside humidity is 51.8 % RH
dev:13142023-01-16 01:10:56.852 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A0000213A14, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:143A, clusterInt:1029, attrInt:0]
dev:13142023-01-16 01:10:56.774 PMinfoThermometer at the entrance outside temperature is 2.55 °C
dev:13142023-01-16 01:10:56.769 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029FF00, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:00FF, clusterInt:1026, attrInt:0]
dev:13142023-01-16 01:10:01.553 PMinfoThermometer at the entrance outside temperature is 2.51 °C
dev:13142023-01-16 01:10:01.548 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029FB00, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:00FB, clusterInt:1026, attrInt:0]
dev:13142023-01-16 01:03:01.654 PMinfoThermometer at the entrance outside temperature is 2.16 °C
dev:13142023-01-16 01:03:01.640 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029D800, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:00D8, clusterInt:1026, attrInt:0]
dev:13142023-01-16 12:40:57.198 PMinfoThermometer at the entrance outside humidity is 51.8 % RH
dev:13142023-01-16 12:40:57.189 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A0000214014, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:1440, clusterInt:1029, attrInt:0]
dev:13142023-01-16 12:40:57.134 PMinfoThermometer at the entrance outside temperature is 1.84 °C
dev:13142023-01-16 12:40:57.121 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029B800, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:00B8, clusterInt:1026, attrInt:0]
dev:13142023-01-16 12:27:02.000 PMinfoThermometer at the entrance outside temperature is 1.63 °C
dev:13142023-01-16 12:27:01.987 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029A300, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:00A3, clusterInt:1026, attrInt:0]
dev:13142023-01-16 12:10:57.427 PMinfoThermometer at the entrance outside humidity is 51.9 % RH
dev:13142023-01-16 12:10:57.418 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A0000214914, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:1449, clusterInt:1029, attrInt:0]
dev:13142023-01-16 12:10:57.358 PMinfoThermometer at the entrance outside temperature is 1.3 °C
dev:13142023-01-16 12:10:57.345 PMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000298200, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0082, clusterInt:1026, attrInt:0]
dev:13142023-01-16 11:40:57.721 AMinfoThermometer at the entrance outside humidity is 52.2 % RH
dev:13142023-01-16 11:40:57.712 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A0000216514, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:1465, clusterInt:1029, attrInt:0]
dev:13142023-01-16 11:40:57.662 AMinfoThermometer at the entrance outside temperature is 0.99 °C
dev:13142023-01-16 11:40:57.649 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000296300, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0063, clusterInt:1026, attrInt:0]
dev:13142023-01-16 11:21:02.505 AMinfoThermometer at the entrance outside temperature is 0.75 °C
dev:13142023-01-16 11:21:02.499 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000294B00, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:004B, clusterInt:1026, attrInt:0]
dev:13142023-01-16 11:16:02.539 AMinfoThermometer at the entrance outside temperature is 0.42 °C
dev:13142023-01-16 11:16:02.526 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000292A00, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:002A, clusterInt:1026, attrInt:0]
dev:13142023-01-16 11:10:57.972 AMinfoThermometer at the entrance outside humidity is 53.4 % RH
dev:13142023-01-16 11:10:57.963 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A000021DF14, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:14DF, clusterInt:1029, attrInt:0]
dev:13142023-01-16 11:10:57.916 AMinfoThermometer at the entrance outside temperature is 0.08 °C
dev:13142023-01-16 11:10:57.904 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000290800, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0008, clusterInt:1026, attrInt:0]
dev:13142023-01-16 11:02:02.647 AMinfoThermometer at the entrance outside temperature is 0.0 °C
dev:13142023-01-16 11:02:02.634 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A0000290000, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:0000, clusterInt:1026, attrInt:0]
dev:13142023-01-16 10:40:58.276 AMinfoThermometer at the entrance outside humidity is 53.0 % RH
dev:13142023-01-16 10:40:58.267 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104050A000021B014, dni:9815, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:14B0, clusterInt:1029, attrInt:0]
dev:13142023-01-16 10:40:58.180 AMinfoThermometer at the entrance outside temperature is -0.31 °C
dev:13142023-01-16 10:40:58.175 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029E1FF, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:FFE1, clusterInt:1026, attrInt:0]
dev:13142023-01-16 10:40:02.895 AMinfoThermometer at the entrance outside temperature is -0.31 °C
dev:13142023-01-16 10:40:02.881 AMdebugThermometer at the entrance outside parse() descMap = [raw:98150104020A000029E1FF, dni:9815, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:FFE1, clusterInt:1026, attrInt:0]
Hi @molod ,
Filtering the logs for 'temperature' keyword ( I use Notepad++ app) doesn't show any false readings when the temp crosses the zero degrees point:
Line 373: dev:13142023-01-16 01:10:56.774 PMinfoThermometer at the entrance outside temperature is 2.55 °C
Line 377: dev:13142023-01-16 01:10:01.553 PMinfoThermometer at the entrance outside temperature is 2.51 °C
Line 381: dev:13142023-01-16 01:03:01.654 PMinfoThermometer at the entrance outside temperature is 2.16 °C
Line 389: dev:13142023-01-16 12:40:57.134 PMinfoThermometer at the entrance outside temperature is 1.84 °C
Line 393: dev:13142023-01-16 12:27:02.000 PMinfoThermometer at the entrance outside temperature is 1.63 °C
Line 401: dev:13142023-01-16 12:10:57.358 PMinfoThermometer at the entrance outside temperature is 1.3 °C
Line 409: dev:13142023-01-16 11:40:57.662 AMinfoThermometer at the entrance outside temperature is 0.99 °C
Line 413: dev:13142023-01-16 11:21:02.505 AMinfoThermometer at the entrance outside temperature is 0.75 °C
Line 417: dev:13142023-01-16 11:16:02.539 AMinfoThermometer at the entrance outside temperature is 0.42 °C
Line 425: dev:13142023-01-16 11:10:57.916 AMinfoThermometer at the entrance outside temperature is 0.08 °C
Line 429: dev:13142023-01-16 11:02:02.647 AMinfoThermometer at the entrance outside temperature is 0.0 °C
Line 437: dev:13142023-01-16 10:40:58.180 AMinfoThermometer at the entrance outside temperature is -0.31 °C
Line 441: dev:13142023-01-16 10:40:02.895 AMinfoThermometer at the entrance outside temperature is -0.31 °C
Can you look at the device 'Events' page around 11 AM, are there any events shown there that may not be seen in the live logs?
Line 2: dev:13142023-01-16 05:04:00.696 PMinfoThermometer at the entrance outside temperature is 5.3 °C
Line 3: dev:13142023-01-16 04:45:00.814 PMinfoThermometer at the entrance outside temperature is 7.45 °C
Line 7: dev:13142023-01-16 04:43:00.839 PMinfoThermometer at the entrance outside temperature is 7.82 °C
Line 15: dev:13142023-01-16 04:40:55.823 PMinfoThermometer at the entrance outside temperature is 8.26 °C
Line 19: dev:13142023-01-16 04:39:00.879 PMinfoThermometer at the entrance outside temperature is 8.68 °C
Line 23: dev:13142023-01-16 04:37:00.881 PMinfoThermometer at the entrance outside temperature is 9.12 °C
Line 27: dev:13142023-01-16 04:35:00.922 PMinfoThermometer at the entrance outside temperature is 9.62 °C
Line 31: dev:13142023-01-16 04:33:00.920 PMinfoThermometer at the entrance outside temperature is 10.21 °C
Line 35: dev:13142023-01-16 04:32:00.901 PMinfoThermometer at the entrance outside temperature is 10.52 °C
Line 39: dev:13142023-01-16 04:31:00.928 PMinfoThermometer at the entrance outside temperature is 10.86 °C
Line 43: dev:13142023-01-16 04:30:00.892 PMinfoThermometer at the entrance outside temperature is 11.22 °C
Line 47: dev:13142023-01-16 04:29:10.935 PMinfoThermometer at the entrance outside temperature is 11.62 °C (delayed)
Line 49: dev:13142023-01-16 04:29:01.905 PMdebugThermometer at the entrance outside DELAYING 9 seconds event : [name:temperature, unit:°C, value:11.6, type:delayed, isStateChange:true, descriptionText:temperature is 11.62 °C]
Line 53: dev:13142023-01-16 04:29:00.976 PMinfoThermometer at the entrance outside temperature is 11.62 °C
Line 57: dev:13142023-01-16 04:28:00.899 PMinfoThermometer at the entrance outside temperature is 12.01 °C
Line 61: dev:13142023-01-16 04:27:00.971 PMinfoThermometer at the entrance outside temperature is 12.42 °C
Line 65: dev:13142023-01-16 04:26:00.914 PMinfoThermometer at the entrance outside temperature is 12.91 °C
Line 69: dev:13142023-01-16 04:25:00.968 PMinfoThermometer at the entrance outside temperature is 13.45 °C
Line 73: dev:13142023-01-16 04:24:00.944 PMinfoThermometer at the entrance outside temperature is 14.06 °C
Line 77: dev:13142023-01-16 04:23:01.001 PMinfoThermometer at the entrance outside temperature is 14.7 °C
Line 81: dev:13142023-01-16 04:22:00.955 PMinfoThermometer at the entrance outside temperature is 15.39 °C
Line 85: dev:13142023-01-16 04:21:01.019 PMinfoThermometer at the entrance outside temperature is 16.08 °C
Line 89: dev:13142023-01-16 04:20:00.977 PMinfoThermometer at the entrance outside temperature is 16.76 °C
Line 93: dev:13142023-01-16 04:19:01.051 PMinfoThermometer at the entrance outside temperature is 17.46 °C
Line 97: dev:13142023-01-16 04:18:01.001 PMinfoThermometer at the entrance outside temperature is 18.08 °C
Line 101: dev:13142023-01-16 04:17:01.060 PMinfoThermometer at the entrance outside temperature is 18.66 °C
Line 105: dev:13142023-01-16 04:16:01.030 PMinfoThermometer at the entrance outside temperature is 19.16 °C
Line 109: dev:13142023-01-16 04:15:01.078 PMinfoThermometer at the entrance outside temperature is 19.67 °C
Line 113: dev:13142023-01-16 04:14:01.032 PMinfoThermometer at the entrance outside temperature is 20.12 °C
Line 117: dev:13142023-01-16 04:13:01.080 PMinfoThermometer at the entrance outside temperature is 20.51 °C
Line 121: dev:13142023-01-16 04:12:01.025 PMinfoThermometer at the entrance outside temperature is 20.85 °C
Line 129: dev:13142023-01-16 04:10:56.110 PMinfoThermometer at the entrance outside temperature is 21.16 °C
Line 133: dev:13142023-01-16 03:50:01.064 PMinfoThermometer at the entrance outside temperature is 21.64 °C
Line 137: dev:13142023-01-16 03:49:01.127 PMinfoThermometer at the entrance outside temperature is 21.96 °C
Line 145: dev:13142023-01-16 03:40:56.184 PMinfoThermometer at the entrance outside temperature is 22.59 °C
Line 149: dev:13142023-01-16 03:37:01.139 PMinfoThermometer at the entrance outside temperature is 22.32 °C
Line 153: dev:13142023-01-16 03:35:01.141 PMinfoThermometer at the entrance outside temperature is 21.99 °C
Line 157: dev:13142023-01-16 03:32:01.131 PMinfoThermometer at the entrance outside temperature is 21.57 °C
Line 161: dev:13142023-01-16 03:30:01.078 PMinfoThermometer at the entrance outside temperature is 20.99 °C
Line 165: dev:13142023-01-16 03:29:01.122 PMinfoThermometer at the entrance outside temperature is 20.66 °C
Line 169: dev:13142023-01-16 03:28:01.065 PMinfoThermometer at the entrance outside temperature is 20.35 °C
Line 173: dev:13142023-01-16 03:27:01.105 PMinfoThermometer at the entrance outside temperature is 19.95 °C
Line 181: dev:13142023-01-16 03:26:01.050 PMinfoThermometer at the entrance outside temperature is 19.55 °C
Line 185: dev:13142023-01-16 03:25:01.089 PMinfoThermometer at the entrance outside temperature is 19.16 °C
Line 189: dev:13142023-01-16 03:24:01.025 PMinfoThermometer at the entrance outside temperature is 18.73 °C
Line 193: dev:13142023-01-16 03:23:01.070 PMinfoThermometer at the entrance outside temperature is 18.29 °C
Line 197: dev:13142023-01-16 03:22:01.033 PMinfoThermometer at the entrance outside temperature is 17.83 °C
Line 201: dev:13142023-01-16 03:21:01.069 PMinfoThermometer at the entrance outside temperature is 17.35 °C
Line 205: dev:13142023-01-16 03:20:00.993 PMinfoThermometer at the entrance outside temperature is 16.88 °C
Line 209: dev:13142023-01-16 03:19:01.051 PMinfoThermometer at the entrance outside temperature is 16.39 °C
Line 213: dev:13142023-01-16 03:18:00.996 PMinfoThermometer at the entrance outside temperature is 15.92 °C
Line 217: dev:13142023-01-16 03:17:01.047 PMinfoThermometer at the entrance outside temperature is 15.47 °C
Line 221: dev:13142023-01-16 03:16:00.991 PMinfoThermometer at the entrance outside temperature is 15.01 °C
Line 225: dev:13142023-01-16 03:15:01.041 PMinfoThermometer at the entrance outside temperature is 14.57 °C
Line 229: dev:13142023-01-16 03:14:00.978 PMinfoThermometer at the entrance outside temperature is 14.06 °C
Line 233: dev:13142023-01-16 03:13:00.996 PMinfoThermometer at the entrance outside temperature is 13.55 °C
Line 237: dev:13142023-01-16 03:12:00.942 PMinfoThermometer at the entrance outside temperature is 13.06 °C
Line 245: dev:13142023-01-16 03:10:56.062 PMinfoThermometer at the entrance outside temperature is 12.42 °C
Line 249: dev:13142023-01-16 03:10:00.921 PMinfoThermometer at the entrance outside temperature is 11.88 °C
Line 253: dev:13142023-01-16 03:09:00.929 PMinfoThermometer at the entrance outside temperature is 11.31 °C
Line 257: dev:13142023-01-16 03:08:00.928 PMinfoThermometer at the entrance outside temperature is 10.77 °C
Line 261: dev:13142023-01-16 03:07:00.974 PMinfoThermometer at the entrance outside temperature is 10.24 °C
Line 265: dev:13142023-01-16 03:06:00.920 PMinfoThermometer at the entrance outside temperature is 9.75 °C
Line 269: dev:13142023-01-16 03:05:00.973 PMinfoThermometer at the entrance outside temperature is 9.35 °C
Line 273: dev:13142023-01-16 03:04:00.978 PMinfoThermometer at the entrance outside temperature is 9.04 °C
Line 277: dev:13142023-01-16 03:02:00.986 PMinfoThermometer at the entrance outside temperature is 8.68 °C
Line 281: dev:13142023-01-16 02:59:01.052 PMinfoThermometer at the entrance outside temperature is 8.33 °C
Line 285: dev:13142023-01-16 02:56:01.015 PMinfoThermometer at the entrance outside temperature is 8.0 °C
Line 289: dev:13142023-01-16 02:53:01.025 PMinfoThermometer at the entrance outside temperature is 7.67 °C
Line 293: dev:13142023-01-16 02:49:01.033 PMinfoThermometer at the entrance outside temperature is 7.35 °C
Line 297: dev:13142023-01-16 02:45:01.057 PMinfoThermometer at the entrance outside temperature is 7.01 °C
Line 305: dev:13142023-01-16 02:40:56.183 PMinfoThermometer at the entrance outside temperature is 6.69 °C
Line 309: dev:13142023-01-16 02:38:01.102 PMinfoThermometer at the entrance outside temperature is 6.44 °C
Line 313: dev:13142023-01-16 02:29:01.121 PMinfoThermometer at the entrance outside temperature is 6.11 °C
Line 317: dev:13142023-01-16 02:23:01.127 PMinfoThermometer at the entrance outside temperature is 5.78 °C
Line 321: dev:13142023-01-16 02:18:01.157 PMinfoThermometer at the entrance outside temperature is 5.42 °C
Line 329: dev:13142023-01-16 02:10:56.308 PMinfoThermometer at the entrance outside temperature is 5.08 °C
Line 337: dev:13142023-01-16 02:07:01.176 PMinfoThermometer at the entrance outside temperature is 4.87 °C
Line 341: dev:13142023-01-16 02:02:01.246 PMinfoThermometer at the entrance outside temperature is 4.51 °C
Line 345: dev:13142023-01-16 01:55:01.274 PMinfoThermometer at the entrance outside temperature is 4.15 °C
Line 349: dev:13142023-01-16 01:47:01.353 PMinfoThermometer at the entrance outside temperature is 3.83 °C
Line 357: dev:13142023-01-16 01:40:56.526 PMinfoThermometer at the entrance outside temperature is 3.5 °C
Line 361: dev:13142023-01-16 01:36:01.411 PMinfoThermometer at the entrance outside temperature is 3.19 °C
Line 365: dev:13142023-01-16 01:21:01.534 PMinfoThermometer at the entrance outside temperature is 2.86 °C
Search " 20." (6 hits in 1 file of 1 searched)
It looks like the outside temperature actually peaks to 22.59 deg. C at 3:49 PM ....
The winter sun shining directly into the sensor?
Hi @kkossev this crossed my mind (sun heating it up), I would say it unlikely but can't completely rule it out, so I placed an aqara thermometer next to it, let's see what happens...
not sure its ok to ask it here or better to open another topic. I was foolishly bought a TUYA TH0601 instead of 201 and its not working. any ways to get custom driver? or any driver supporting it maybe ?
Please post the manufacturer ID from the device web page Data section.
wow it was SUPER quick
thank you ! pls find the details below.
while the TS0201 : * manufacturer: _TZ2000_a476raq2 - and thats working , this above one is not.
wow! awesome! let me try.
I purchased 8 of the below from Aliexpress because I want to track the temp & humidity around my house. The first one I tried I found this blog and @kkossev driver got me up and running. The second unit I tried I didn't get any data from the sensors, and the 3rd and 4th I'm only getting battery back(%100). Really strange, not sure if this is a manufacturing problem. I did try initialize, but that dosen't seem to help. HE is running the latest version. I have done all the work today, including latest driver. I also deleted the 1st device (becuase I wasn't getting battery) and re-added and it's still working correctly. Please advise if anyone has troubleshooting suggestions.
Hi @bavawter ,
For some Tuya devices, it is obligatory that the Tuya specific driver is selected automatically during the Zigbee pairing process to HE. Always pair the battery-powered sensors close to HE hub, then you can move the device to its final destination.
What happens when you pair this sensor to HE? Is the "Tuya Temperature Humidity Illuminance ....." driver selected automatically?
