I LOVE that you have that vision. That's exactly what my vision has been, and I feel like I'm well on my way to achieving that.
I have 4 modes
Quiet time
home
Night
Away
I strive to make it so that I never have to ask or press a button in an every day situation. I can't say it never happens, but it is few and far between. I hope you find this interesting.
Night, quiet time, and home is dictated by phones docked on two modified Qi chargers. I'll link the project at the bottom. This is how the day works
Both phones docked on chargers triggers night mode. Everything turns off. Indirect lighting above my cabinets dims and becomes a night light. I'll talk about the significance of that lighting later.
In the morning one person gets up and undocks phone, quiet time starts. Keeps the bedroom lights muted to not wake the sleeping spouse (me) while loving husband prepares to leave for work. Kitchen and dining room can lights and cabinet lights only interact on motion. They are bright enough to see what you're doing. We use this setup mostly because you only need lots of lights when you're actually doing something in the kitchen. Like baking. Second phone undocks, mode changes to home. All lights interact normally except for the kitchen and dining. Just cabinets and cans unless we're moving around in there for more than 10 minutes. Then the room lights will turn on. That usually happens more in the evening and not in the morning. the big lights will turn on in home mode if activity exceeds 10 minutes. It's worked well for us. Between 5pm and 7pm, the kitchen/dining lights all interact as that would normally be dinner hour and clean up. I could probably eliminate that rule because our activity keeps the lights on without having to have a full on rule to do that for me. We also have several motion sensors in the room to achieve this. Even one by the stove and pointed down at the counters and tables. My cabinet lights brighten up to 100% when you enter the room and dim back down where activity stops. This is enough light to see when you need a drink of water or something simple. Half of the lights turn off in night mode and will only brighten up to 50% on activity.
Our basement lights trigger with a motion sensor at the bottom of the steps before entering the room. The light will remain on if I am in my office as I have motion sensors facing my computer keyboard and work bench. As long as those lights are on, then the living room lights will be on. If the tv is turned on in the room, the lights will dim to 50% and remain on until the tv is off, my den is quiet and activity has stopped in that room.
Upper living room lights turn on with motion, off when inactive, but will not turn on if the tv is on up there. There is a lamp by our door that dims and brightens according to the lighting scheme. Lots of restrictions.
Garage lights turn on when a door opens or a lock code is entered or activity is detected. Off when all doors are closed and locked and activity is stopped. Locks auto lock after two minutes. All of my other rooms are simple lighting. On with activity and off when quiet. Closet door opens and turns on the closet light and off when it closes. Same with pantry. If I let the dogs out and open the patio door, the back light turns on and remains on until i close the door the second time when they come in. Works really well.
Away works on presence and home also triggers when one of us arrives home. Quiet time happens when one phone is docked in the bedroom. Night is two phones docked.
When I started this journey, my husband laid down the edict that he would NOT do anything special to get lights to turn on. I've adhered to that and set things up to follow our habits.
here is the link to our Qi chargers. I hope you find some inspiration in this post.
[EDIT]
I do use some multisensors also to restrict lights turning on when not needed. I also set the fan speed according to temperature in the bedroom at night. Works like a charm.
[ANOTHER EDIT]
Outside lights, cabinet lights and a table lamp turn on 60 minutes before sunset and off 60 minutes after sunrise. The table lamp will turn off in night mode and back on if mode changes to quiet time or home if it's before sunrise. The cabinet lights will do the same if mode changes and it's before sunrise.
I setup @ogiewon’s bed presence solution. This sets the mode based on when we are both in bed and day when one of us gets up in the morning. My wife recently told me this is her favorite automation I have done in recent months.
Yes good thanks. I ended up with a temperature difference based system for the hob detection. With a sensor fixed to the extractor hood, to give a difference to room ambient. It took a bit of finessing to get the values to work well, and I now look at both the temperature delta and rate of change to determine if we've left a gas ring on. I ended up with these rules: If the delta is over 7 Deg C then a ring is definitely on. If it's below 4 Deg C it's off as even the smallest ring gets it above that, and if it's between the 2 and falling by more than 0.2 Deg C compared to the previous delta it's also off. I had to add that last proviso or it gave a false positive for quite a while after everything had been turned off.
For the oven, I added another sensor to my Iotawatt on the oven circuit and that even detects just an oven lamp being on.
I feel like I'm still in the early days of my automation, and it's progressing in finding the routines we have as a family that I can help out.
I have 4 modes;
Home
Away (no-one's home, but we are in town doing errands or something)
Sleep (everyone is in bed or close to being in bed)
Vacation (Security lock-down and simulations like we are home).
I have home always start at a specific time in the morning, unless we are Away or on Vacation.
Lights turn on and off based on sunrise sun-set and in the mornings as a way to get the kids out of bed and have some extra light even post-sun-set. I'm with Cobra in the aspect that I do eventually want to use LUX to help augment how long lights should stay on or if they should turn on earlier
Motion sensor for lights, time based when they trigger. Future Lux for how bright
Garage Door stuff - I automatically switch off the garage door power when we are on vacation, and any other mode turns it back on. I'm considering if "sleep" should turn in on/off. I'm just been worried if that could cause harm to my chamberlain doing that so often every night or not.
I use Alexa Guard to randomize my lights while on vacation to simulate being home. I need to figure out how to do this for my Sonos as well to have Music playing. I also want to trigger music playing if there is motion or an 'alarm' in any of my away or vacation modes. The challenge I'm running into is with playlists for Sonos (haven't looked into it enough).
Those are most of my 'automations' today which gear towards Lights, and security.
The rest are mostly about sensors (water leaks, temp, smart locks, etc.)
The switches are nice for guests. For example, the bathroom lights are triggered by motion and contact sensors. If somebody turns off the switch when they leave it will override the motion sensor for a short while. This way they don’t have to change their behavior when visiting but everything is still automated.
There are a few out there. I've gone the Alexa Guard route, which serves my purpose, and what is really missing for me is the Sonos piece.
I'm tempted to switch over to this app [ [RELEASE] At Home Simulator ] by the incredible @bptworld , and then do my own Sonos Rules if I can figure them out (or better, write an app if i can muster it, I'm rusty at coding).
A TRUE Smart home would probably lock us out and never let us back in. We mess the thing up, break things and generally upset it. With us gone, a true smart home would happily go about it's business unconcerned about what WE wanted it to do.
