Ok, hopefully that explains it. Out of interest, is it the same on the devices using the other driver? i.e. not mine?
from Total Comfort API C...
Ok, that's what needs to change. Just tweaked my driver and tested it, double quotes around the modes is what is needed. Simple fix in the end, and makes sense to align to what I believe is a JSON standard. I'll release the fix shortly. You may want to point the dev of the Total Comfort driver to this topic or pass on the info.
Version 1.0.24 of the Unified driver is released
confirmed. Did have to save prefs....Thanks for the quick fix mate.
2.3.3.123 (just released) has dashboard tile logic that's more tolerant of mode and fan mode enum values.
One problem, three solutions (two community drivers fixed and one tile fixed)....
In two days...
Can't complain about that! Thanks all!
@gopher.ny in .123 it looks like dashboards work fine from the web interface without double-wrapping the mode/fanmode enums. However they still do not work from a dashboard within the Android app, using 1.6.9b133
Please try now.
Update: It is working now after I cleared the cached files of MS Edge.
I have 2 Honeywell T6 Pro Z-Wave, both tiles stopped working since last update
I just updated to latest which said fixed the Thermostat title, but it's still not working.
I was using the custom "Advanced Honeywell T6 Pro Thermostat" driver but I also changed to use the built-in "Honeywell T6 Pro Z-Wave Thermomsat" driver with the latest firmware, still not working.
These are what shown for the device, all modes shown without quote
- supportedThermostatFanModes : [auto, on]
- supportedThermostatModes : [off, heat, cool, emergency heat]
Have you tried the Generic Z-Wave Thermostat Driver? I haven't tested it w/tiles but it works very well gennerally w/a T6 Pro I have set up with it.
Works again!
I tried clearing the cache. The tile will let me change the temperature setting, but the Mode buttons don't work. Mine broke around the same time yours did. Are your mode buttons working?
