Thank you for the report! In the new 1.6.X versions of the Tuya Multi Sensor 4 In 1 driver have more than half of the code lines are changed, so we may expect some hiccups... I will have to fix all the noticed issues one by one, there is no way to go back as the driver code supporting all the different devices grew so much that it was not possible to continue the old copy/paste/modify way anymore.
Just in case, an old version 1.5.3 of the driver dated 2023/09/30 can be downloaded from here.
Driver name is "Tuya Multi Sensor 4 In 1 (ver.1.5.3)" and it can coexist with the current development branch version, but please use it only if something is so much broken that the device is unusable... hope there will be no such cases! : )
I suppose you are referring to TS0225_2AAELWXK_RADAR.
I have, and I am using for testing the other model (TS0225_HL0SS9OA_RADAR), so I will ask for some tests as not everything can be simulated here.
Please update to the new version 1.6.3 that hopefully fixes some of the noticed issues. Can you configure the LED activation on and off now?
You can also use the "SetPar" command to change a singe parameter/preference only.
If you do not enter any parameter names, the list of the valid parameters that can be changed dynamically is listed in the live logs:
dev:41212023-10-16 01:05:22.666warnRadar TS0225 _TZE200_hl0ss9oa setPar: 'parameter' must be one of these : [presenceKeepTime, ledIndicator, radarAlarmMode, radarAlarmVolume, radarAlarmTime, motionFalseDetection, motionDetectionSensitivity, motionMinimumDistance, motionDetectionDistance, smallMotionDetectionSensitivity, smallMotionMinimumDistance, smallMotionDetectionDistance, breatheFalseDetection, staticDetectionSensitivity, staticDetectionDistance]
