Finally something cheaper than down south. Saw it at canadiantire but I didn't buy any.
$34.93 in Alberta
$43 for the bulb
The plugs are also on sale on Amazon for anyone in USA.
I saw that on sale for a while now but this is $14.99 CAD. That like 4 USD pennies ![]()
Are the plugs type A ?
Depends on the store. Canadian Tire stores are franchised, so prices will vary. One store near me has the plugs for $24.98 and another near me has them for $31.44
They are not type A. I checked a couple cause I know you guys will ask ![]()
Grab the lot. Sell them to everyone with Xiaomi devices dropping off.
I bought a non A version from Canadian Tire and Plugged, how do I know it repeated signal for xiaomi? Will it join my current Zigbee network automatically as a router in 24-36 hours?
You don't really know if it's repeating a certain device unless you follow this post about xbee everything. Everything Xbee
As far as this Sylvania plug. It's a repeater and your Hub will work out the mesh after you leave the hub off for more than 15 minutes. Once power up the hub your system will start healing the mesh. Whether your xiaomi devices using the plug for repeating is depending on what kind of mesh you have.
The non-A version of that plug has been shown with a network map by @gavincampbell to work as a repeater for Xiaomi devices. As @Navat604 pointed you to, more information is available in the Everything Xbee post.
Thank you all for the info. Actually I have read Everything Xbee post already and am trying to order Xbee 3 to enhance my zigbee network and show a network map with XCTU software. I have downloaded XCTU software already but it needs a xbee device been connected to show the network map.
If you read that post, it says sylvania plug can route around 6 devices, while Xbee 3 could route 12-20 devices. Seems have to have xbee 3 to visualize my current zigbee network. Currently, I can see signal for my Xiaomi devices is around -60 dbm ~ -90 dbm . not sure with xbee3 /sylvania added in, how could improve...
a bit of a read but read through Xiaomi devices - are they pairing / staying connected for you?
Using this plug, I can see signal getting worse from zigbee logs, down from -71 ~ -75 dbm to -90 dbm..
Any idea how come?
I think looking at the dbm level is a little deceptive. I don't think it's measuring from the device to the Repeater but rather from the device to the hub. @patrick?
No, it's device to nearest repeater.
-90 dbm means very weak signal for zigbee.. Device may disconnected.. What's your guys suggestion, unplug the repeater ? Curious to know if xciu software shows singal on the mesh network map realtime..
Do you have Zigbee bulbs paired to the hub in the mix? They can be problematic. Not good repeaters. Sengled donβt repeat, so they would be fine.
@SmartHomePrimer I only have hue bulbs but all connected with Hue bridge, talking with HE by Hue Bridge Integration Apps. I have switched off the plug to see how signal value will be changed in the Zigbee logs.. Interesting thing is that device is not dropped so far even the worst signal strength is -92 dbm..
