Sylvania Lightify Smart+ Outlet Plug
Osram 72922, FCC ID: DZO-LDV72922
fingerprint profileId:"C05E",
endpointId:"03",
inClusters:"1000,0000,0003,0004,0005,0006,0B04,FC0F",
outClusters:"0019",
model:"Plug 01",
manufacturer:"OSRAM"
Ledvance 72922-A, FCC ID: 2AKGT-PLUGA
fingerprint profileId:"0104",
endpointId:"01",
inClusters:"0000,0003,0004,0005,0006,0B05,FC01,FC08",
outClusters:"0003,0019",
model:"PLUG",
manufacturer:"LEDVANCE"
[Sylvania Plug-A Ledvance 07, 89B0], LQI:253, age:4, inCost:3, outCost:1
[Sylvania Plug-nonA Osram 07, A410], LQI:213, age:7, inCost:5, outCost:0
I have several of both versions and lately the Osrams seem to be very unreliable, i.e. frequently stop responding to on/off commands.
The above numbers are from the same physical location for both plug versions but about a day apart. (One at a time)
The Osrams typically have a lower LQI and higher inCost and outCost, in fact the outCost is usually sitting at either a 7 or a 0, both of which I understand is pretty bad.
I do have a Lightify Hub so pulled that out and was able to update the firmware on the Osram plugs. (see below)
But it won't identify the Ledvance plug as anything other than a generic "PLUG = device". Since the Osram's functionality hasn't noticeably improved post firmware update probably not really a big deal.
Just wondering if anyone else has been experiencing the same and what sort of tweaks might be helpful.
Also curious if anyone was able to update the Ledvance PLUG firmware using the Lightify hub.
Edit: Just looking at the firmware webpage, if it's a complete list there is nothing for the PLUG, only the Plug01
