I have now added the latest version of the driver to HPM.
For these of us who have already installed it manually, please try to use the HPM "MatchUp" function first.
If 'Match Up' does not work for some reason (it happens sometimes in my environment), you may end up with two drivers named '"Zigbee Button Dimmer".
First, find the devices that are using this driver by filtering for 'Zigbee Button Dimmer'
Then, for each device, manually change the devices that use the old driver to the new one installed via HPM and then delete the old one.
Finally, delete the old driver : ( it has an older 'Last Modified' time stamp) :
