I have a series of 9 various zooz light switches (72's, 77's, 32's) that control various lights outside. I have a Rule Machine rule so that 15 min before Sunset it turns each light on at a specific dim setting. The rule runs again at 5 min before sunset and then again as sunset itself.
I have the rule run 3 times because I've found that when running just once, there was, at a higher level of frequency, on or more lights wouldn't turn on. Doing this tripple run nipped that a lot. I do still every once and a while get a light that wont turn on. When one doesn't turn on, I can manually go into the hubitat app, and after about 5-6 on off cycles, the light "usually" will eventually turn on. Every once and a while, I can't get it to work, but, randomly starts working properly the next day with no other intervention.
The kicker is it isn't always the same lights when it does this. I feel like I have a pretty strong zwave mesh with all my switches installed non 800LR so that they can act as nodes for each other.
I'm going to guess there isn't much to be done and this is just a case that some of the switches get "stuck" sleeping and take multiple attempts to wake up to "hear" chatter on the network.
Any suggestions what I could do to make these fool proof and work "100%" of the time?
