Sunrise & Sunset Hours is broken
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
I'm using a C5 hub. I live in the GMT+9 area, but the sunrise and sunset times are very different. Is there any solution?
Chances are that your location on that same page, Setting > Hub Details, is not set correctly. Verify that the Latitude and Longitude fields are set correctly for your area, along with the Time Zone setting (though that one looks correct from your screenshot). All three are used to calculate and display sun times.
Thanks alot!!
I know from experience that getting the location correct matters. :joy:
https://community.hubitat.com/t/whats-the-funniest-most-unexpected-or-downright-crazy-thing-that-has-happened-as-a-result-of-your-home-automation/96385
