Just use the reset button only
I've never seen that screen
So I have a green light on now and have done nothing else.
So if this was set up before, you can now restore from onboard backups (or cloud backups if you have a hub protect subscription) or if this is a new hub, go ahead and start setting things up
I show a welcome to hubitat get started menu
Was the hub setup before with any devices or rules?
Brand new out of the box. Updating firmware now
Welp, there ya go... You're good. Start setting stuff up... I recommend reading the following post since you're new. It will help avoid some gotchas.
Thank you I appreciate the heads up.
Do I need to worry about eliminating some of the information on this thread.
The only thing I see is the IP which is just an internal LAN IP which is useless to anyone else.
I dont think you shared anything sensitive.
I appreciate all your help. I've been excited to get this thing up and running. Looks like it's doing it's final reboot..
Be sure to look at that post I linked above
No, that's just your internal IP.... I showed you mine, fair that you showed me yours
Respect for the patience and helpfullness, and wellcome to a new user
