I got all of my back yard devices moved over yesterday. 3 of the 4 switches included to HE fairly easily (took 2-3 tries). The 4th one I couldn't get HE to discover, ended up waiting a couple hours and doing 2 z-wave repairs, then it finally included.
At this point, all of my mains powered z-wave devices are on HE, except one that's in the attic that I haven't gone climbing for yet. I followed the method recommended above where I did a general exclusion using a minimote that had already been taken off of ST, which excluded them from ST but left the device intact, allowing me to include the devices to HE, add them to Other Hub to create the virtual device in ST, then go back and replace the original physical device with the new virtual device in all my ST automations. It went a lot quicker that way.
All that's left as far as physical devices are 5 z-wave battery devices and 14 zigbee battery devices. I have moved a couple of my simple webCoRE pistons over to Rule Machine as well.
And of course, now that I woke up early to keep going with the migration process, ST appears to be down. Can't wait til I can shut down my SmartThings hub for good!
37 Devices moved over tonight! I started small, but things were going well...so I kept going. Mostly started with Lights and some motion sensors driving those lights. Got T-Stats moved. More lights.
I'm going to have some hard things like my BlueIris integration and Google Home...but leaving that for last.
Yep, I have 10 cameras that report motion to ST and I use to trigger all sorts of things. Mostly turning on lights. I have reverse also where contact sensors on doors trigger PTZ cameras to swing to that door. I currently use webcore to trigger my BlueIris modes when I want them to change.
My biggest piston takes input parameters from a python program on my BI server that runs the images through a web API that looks for people and cars. Reports that info via arguments into WebCore and then I use the logic in there to notify me...that will be the last endeavor for sure.
I wonder if Hubitat's new Maker API might make this integration simpler? Just an idea. I haven't used it yet, but it seems like something worth looking into.
Simpler...probably not. More direct...very possibly...I was thinking that would be the route I'd end up at in the end with virtual motion detectors and a direct request from BI server to HE.
Good to hear! I'm down to only 3 physical devices left to move over. Would have finished migrating devices today but these 3 are zigbee devices that I can't get to pair with HE yet. Going to try changing the zigbee channel. Got Life360 set up for my wife and I today, MyQ Lite up and runnning, and my 3 TP-Link outlets. I've created 32 Rule Machine apps too, to replace about 10 webCoRE pistons lol...it takes some creativity to match some of the functionality of webCoRE.
Still need to figure out what to do about Harmony, Honeywell Thermostat, and Google Home TTS capabilities, and get Pushover working.
One thing that's been a life saver for helping with more complicated Rule Machine automations is the virtual switches with the auto-off capability. I love that.
For now, this is the best Harmony Hub integration solution that I have found. It has been incredibly reliable. Just don't remove your SmartThings-Harmony integration, as the keys from that one are 'borrowed' by this one. They need to stay valid!
I created a simple Device Driver to work with the Google Home Assistant Relay nodejs server running on a Raspberry Pi. It uses 'Broadcast" messages to all of your Google Home devices.
And I wrote the original Pushover Driver for Hubitat, which has now been added to the Hubitat Firmware as a native integration. Here's some useful information about setting it up. No need to use the driver from this thread. Just use the built-in one.
Pushover is 5 mins work, with most of that spent signing up for an acct on their site. The end result is a pair of Keys: Your User Key, API Token/Key that get pasted into the Pushover Virtual Device. That's it, you're done.
OK, done except for using that device in some Rules.
Thanks for the links. Will try to tackle Harmony and your TTS tomorrow.
Got Honeywell TCC working through a couple of virtual switches and IFTTT.
Set up Pushover, I love the different priority notifications. Got two devices added, one high priority that will ring through DND on my phone, and one standard priority that will not. This is what I always wanted from ST! I got tired of getting woken up by "hub offline" notifications.
Just be aware that my current Google Assistant Relay Driver is only compatible with v1 of the assistant-relay nodejs server. I haven't had time to work on the changes to support the new v2.
I also have a MS Word Document that I made for myself with all of the detailed instructions to get it up and running. PM me your email address if you'd like a copy.
Made a ton more progress today. Only things left on ST are three webCoRE automations for slowly fading some dimmers over a 30 minute period. I don't think I'm going to be able to recreate these in RM...gotta think about them for a bit.
Other than that, I'll keep ST up just for Harmony keys, Google Home integration, and app control until the HE capabilities are there.
I was able to recreate the piston above in RM, so all my device automations are now on HE
I ended up removing Harmony from HE, I don't want to maintain and sync it in two places and I don't have a good way to get instant status updates in HE, where I do in ST. The only thing I need to know for my HE automations is if either of my two hubs has an activity running, so I created a virtual switch that gets turned on by ST whenever an activity is on, and used that to run my automations in HE.
Harmony instant updates, Google Home, and one IFTTT webhook that uses webCoRE as an intermediary are the only things stopping me from shutting off my ST hub now.
Harmony can control ST devices. So after the Connect app created the virtual switches in ST, I authorized Harmony to control them, then added each activity switch to it's activity in Harmony. Then when the activity is started with the remote it turns it's own switch on in ST. Same with when the activity ends, it turns it's own switch back off.
Lol....I just searched the ST forum for Instant Updates and guess who I found in the post I was referencing above...Cookie Monster aka @destructure00. I thought your name was familiar.
So just my luck, I think I read your ST post right around the time the Harmony servers were giving trouble. Had I checked back a few weeks later , I would have seen that they resolved the 2xcommand issue. Thanks for bringing it over to HE.
@halfrican.ak, you might want to look at this option for instant updates well.
