Im getting an error on my sonos integration and i dont know why. All of the players are working and the bridge. I have done discovery again and all three show there with no issues. I had the ip address on the router set as pinned as well.... i thought....
Not sure if this helps, but I was getting a lot of these also... I did some searching and couldn't find any real solution... I did find something else though...
I deleted my devices and removed the app. I then followed the instructions here to add the Sonos devices manually... That way I had more control over the device as it wasn't a child to the app...
I haven't had any issues since doing it this way...
Thanks for the help. Do I even need the Sonos App running if I’m not adding/trying to discover new devices? I get needing to turn it on if the ip changes but otherwise isn’t unnecessary? All it does is discovery and creation of the devices I thought?
Yeah, I removed it completely and just added the speakers manually... Again, I'm not sure what caused those logs in my case, but with the devices manually added, I haven't seen them again...
