Thanx to @bertabcd1234, @aaiyar, and @jlv I created a minimal solution for my problem on the base of @bptworld's great code:
You can set the monitored level (when to fire an event).
Optionally you can also set (via ID or name) a list of monitored devices and apps.
BTW: The event contains the JSON string of the log line.
Hint: In Rule Machine use "Custom Attribute" as Trigger and choose "event" and "changed".
Maybe this driver is helpful also for others...
// Idea by: Bryan (bptworld) - https://community.hubitat.com/u/bptworld
// Based on: https://community.hubitat.com/t/release-error-monitor/91317
metadata
definition(name:'jsErrorMonitor', namespace:'de.schwider', author:'Jost Schwider', description:'Just Simple Error Monitor')
capability 'Actuator'
attribute 'event', 'string'
preferences()
input 'monitorLevel', 'enum', title:'Monitor this Log Level:<br><small>(Don\'t try <b>info</b> or even <b>debug</b>!)</small>', options:['debug', 'info', 'warn', 'error'], defaultValue:'error', required:true
input 'monitorDevices', 'string', title:'Monitor this Devices/Apps:<br><small>(Comma-separated Names or IDs; Empty=All)</small>', defaultValue:'', required:false
input 'logType', 'enum', title:'Logging:', options:['Debug', 'Info', 'Off'], defaultValue:'Info', required:true
void installed()
logInfo 'Installing...'
initialize ()
void updated() {
logInfo 'Updating...'
initialize ()
void initialize()
logDebug 'Connecting...'
interfaces.webSocket.connect 'ws://localhost:8080/logsocket'
void uninstalled()
logInfo 'Uninstalling...'
interfaces.webSocket.close ()
// Web Socket: //
void webSocketStatus(String socketStatus)
logDebug socketStatus
void parse(String desc)
Map logEvent = new groovy.json.JsonSlurper().parseText(desc)
// logEvent#Fields: name, msg, id, time, type, level
if (logEvent.id == device.id) return // Don't monitor the monitor itself! ;)
if (logEvent.level != monitorLevel) return
if (monitorDevices)
String[] devices = monitorDevices.split(',')*.trim()
logDebug "$logEvent.id/$logEvent.name in $devices?"
if (logEvent.id.toString() in devices || logEvent.name in devices) {} else return
logInfo desc
sendEvent name:'event', value:desc
// Logging: //
void logInfo(String info)
if (logType in ['Info', 'Debug']) log.info info
void logDebug(String debug)
if (logType == 'Debug') log.debug debug
