It’s actually the other way about. The other one is better.
Hmmm, I thought latest was simply downloading the file. Are saying that part is correct, but the other is the preferred method?
No, I’m saying that my method creates a new backup. The other method downloads the last one (which I think is better).
Ah, then yes, I agree, the download is what I am after, which I always remembered was a pain to get the syntax right. That makes sense now, thanks.
It does look like I was only saving the web page and not the backup, adjusted my script to use @jlv 's version and it is now matching the size of the latest download already captured on the HE hub. Thanks. @jlv - You do appear to be missing a space between the I and the @ symbol in the second example.
If anyone can work their magic (and if it is possible) to capture the time the backup was taken on the hub into the file name stored, rather than the time it was downloaded, that would be awesome.
Simon
This comes close....
I think if you modified your script to pass in the file name instead of "latest", it would download the last backup. The url appears to be:
http://YOUR_HUB_IP/hub/backupDB?fileName=YYYY-MM-DD~FW_VERSION.lzf (eg: http://192.168.1.ZZZ/hub/backupDB?fileName=2021-03-28~2.2.5.131.lzf)
The date in YYYY-MM-DD format would be determined by your backup schedule, Still haven't figured out the time stamp (that's only on the web page, not part of the file name)
EDIT: I think @jlv suggested the same thing!
It looks like this script is also creating a new backup (not getting the latest) as it is using the same url as @aaiyar's script ($url = "$($urlhub)/hub/backupDB?fileName=latest").
I noticed that as well, and (without testing) I suspect the get-date may return the current date at the time the script is being run.
It does but I think it's being used as part of the filename for the downloaded file. I could be wrong though as I don't speak PowerShell script language!
Yes, the thing I was after was being able to not only download the last backup file, but also get the date/time it was produced by the HE hub, not when I downloaded it
The space isn't necessary. xargs allows it's arguments to cuddle.
I've gotten this to work in node-red. Since I don't know curl or shell script, maybe someone who understands both can translate this for people who don't use node-red?
(@aaiyar @jlv @Vettester?)
The flow uses node-red-contrib-moment and node-red-contrib-credentials node apart from the standard nodes. In addition, it uses the Hub Information driver from @thebearmay to get hub name, fw version, local ip etc.
NOTE: This flow downloads the current day's backup and should be scheduled AFTER the time HE does its internal backup. It will save the file into the directory specified with the date and time as part of the file name:
Node-RED flow:
[{"id":"f527fe93.c5a7b","type":"subflow","name":"Hubitat Login","info":"","category":"","in":[{"x":40,"y":120,"wires":[{"id":"a9ea0344.3e1b6"}]}],"out":[{"x":1336,"y":122,"wires":[{"id":"fa6d0c33.1064b","port":0}]}],"env":[],"color":"#DDAA99"},{"id":"fa6d0c33.1064b","type":"function","z":"f527fe93.c5a7b","name":"SetCookies","func":"var cookies = msg.responseCookies;\n//Set session cookies for the response header\nmsg.headers = {\n Cookie : \"HUBSESSION=\" + cookies.HUBSESSION.value};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1190,"y":122,"wires":[[]]},{"id":"70a7ba18.feebfc","type":"http request","z":"f527fe93.c5a7b","name":"Login to Hubitat","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.113/login","tls":"","persist":false,"proxy":"","authType":"","x":974,"y":122,"wires":[["fa6d0c33.1064b"]]},{"id":"119114df.454933","type":"function","z":"f527fe93.c5a7b","name":"SetRequestHeaders","func":"var cookies = msg.responseCookies;\nmsg.headers = {\n Cookie : \"HUBSESSION=\" + cookies.HUBSESSION.value,\n 'content-type':'application/x-www-form-urlencoded'};\n\n//Hubitat login username and password for form data\nvar data = 'username='+msg.username+'&password='+msg.password+'&submit=Login';\nmsg.payload = data;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":733,"y":122,"wires":[["70a7ba18.feebfc"]]},{"id":"d9c504c8.4ccdd8","type":"http request","z":"f527fe93.c5a7b","name":"Get Cookie","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.113/login","tls":"","persist":false,"proxy":"","authType":"","x":506,"y":122,"wires":[["119114df.454933"]]},{"id":"a9ea0344.3e1b6","type":"credentials","z":"f527fe93.c5a7b","name":"Set Username/Password","props":[{"value":"username","type":"msg"},{"value":"password","type":"msg"}],"x":252,"y":120,"wires":[["d9c504c8.4ccdd8"]]},{"id":"ad0bff2f.aa66a","type":"inject","z":"10bc02b3.e89565","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":168.66665649414062,"y":2007.666748046875,"wires":[["3ae3fdc3.527ba2"]]},{"id":"3ae3fdc3.527ba2","type":"moment","z":"10bc02b3.e89565","name":"","topic":"","input":"","inputType":"msg","inTz":"America/Chicago","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-MM-DD","locale":"en_US","output":"backupDate","outputType":"msg","outTz":"America/Chicago","x":368.6666564941406,"y":2007.666748046875,"wires":[["7489d38.29bd52c"]]},{"id":"7489d38.29bd52c","type":"subflow:f527fe93.c5a7b","z":"10bc02b3.e89565","name":"","x":603.3333129882812,"y":2006.3334350585938,"wires":[["13a8a275.0f20f6"]]},{"id":"13a8a275.0f20f6","type":"http request","z":"10bc02b3.e89565","name":"Go to HE backup URL","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.113/hub/backup","tls":"","persist":false,"proxy":"","authType":"","x":837.6666564941406,"y":2008.6666870117188,"wires":[["6fb7e653.ea0658"]]},{"id":"6fb7e653.ea0658","type":"html","z":"10bc02b3.e89565","name":"Get Table Data","property":"payload","outproperty":"payload","tag":"td","ret":"html","as":"single","x":1076.3332977294922,"y":2007.33349609375,"wires":[["9645197c.870578"]]},{"id":"9645197c.870578","type":"function","z":"10bc02b3.e89565","name":"Get backup time","func":"\nvar m = msg.payload;\n\n//Get length of attributes array\nvar l = m.length;\n\n//Loop through array to check if html element is backup date/time\nfor (x=0;x<l;x++){\n var str = msg.payload[x]\n if(str.substring(0,10)==msg.backupDate){\n var backupTime = str.substring(11,22)\n var hour = backupTime.substring(0,2)\n var min = backupTime.substring(3,5)\n var sec = backupTime.substring (6,8)\n var pm = backupTime.substring(9,11)\n backupTime = hour+\"_\"+min+\"_\"+sec+\"_\"+pm\n }\n}\n\n//Delete unneeded message elements\nmsg.payload = null;\nmsg.backupTime = backupTime;\nmsg.backupDateTime = str;\n\n//Copy and send the message\n//msg.payload = m; \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":221.33334350585938,"y":2094.33349609375,"wires":[["ebf576e9.ec12e"]]},{"id":"ebf576e9.ec12e","type":"hubitat device","z":"10bc02b3.e89565","deviceLabel":"Hub Details","name":"","server":"144b18bb.8f6aa7","deviceId":"546","attribute":"","sendEvent":false,"x":431.333251953125,"y":2093.333740234375,"wires":[["72c34444.9d0acc"]]},{"id":"72c34444.9d0acc","type":"change","z":"10bc02b3.e89565","name":"Creating url and filename","rules":[{"t":"set","p":"hubName","pt":"msg","to":"\t\t$replace(\t payload.locationName.currentValue,\t \" \",\t \"_\"\t)\t","tot":"jsonata"},{"t":"set","p":"firmwareVersion","pt":"msg","to":"payload.firmwareVersionString.currentValue","tot":"msg"},{"t":"set","p":"localIP","pt":"msg","to":"payload.localIP.currentValue","tot":"msg"},{"t":"set","p":"filePath","pt":"msg","to":"/Users/rakeshgupta/Documents/Hubitat_Backup/","tot":"str"},{"t":"set","p":"fileSuffix","pt":"msg","to":".lzf","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":665.3333435058594,"y":2093.33349609375,"wires":[["8588cc24.b0b2e8"]]},{"id":"8588cc24.b0b2e8","type":"function","z":"10bc02b3.e89565","name":"Set URL","func":"//Set URL to download backup\nmsg.url = \"http://\"+msg.localIP+\"/hub/backupDB?fileName=\"+msg.backupDate+\"~\"+msg.firmwareVersion+\".lzf\";\n\n//Set filename for saving download\nvar filename =msg.hubName+\"_\"+msg.backupDate+\"_\"+msg.backupTime+\"~\"+msg.firmwareVersion+msg.fileSuffix;\nmsg.filename = msg.filePath+filename\n\n//Set session cookies for the response header\nvar cookies = msg.responseCookies;\nmsg.headers = {\n Cookie : \"HUBSESSION=\" + cookies.HUBSESSION.value};\n \nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":892.3333435058594,"y":2093.33349609375,"wires":[["6939d56c.444e44"]]},{"id":"6939d56c.444e44","type":"http request","z":"10bc02b3.e89565","name":"Download Backup","method":"GET","ret":"bin","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":1090.3333435058594,"y":2094.666748046875,"wires":[["b032f04f.4775e"]]},{"id":"b032f04f.4775e","type":"file","z":"10bc02b3.e89565","name":"Save Backup File","filename":"","appendNewline":true,"createDir":false,"overwriteFile":"true","encoding":"none","x":1310.3333435058594,"y":2093.666748046875,"wires":[[]]},{"id":"144b18bb.8f6aa7","type":"hubitat config","name":"Hubitat - DV","usetls":false,"host":"192.168.1.113","port":"80","appId":"321","nodeRedServer":"http://192.168.1.86:1880","webhookPath":"/hubitat/webhook","autoRefresh":true,"useWebsocket":false,"colorEnabled":false,"color":"#74a7fe"}]
The following data needs to be updated before the flow will work:
- Hubitat Login: username/password in the credentials node. If you don't have HE security, you will need to adjust the flow.
- File path (directory) where you want to save the backup:
Hope this helps someone - it was a fun little challenge!
Sorry to bother you guys but simple question. I have a windows machine and script that I need to get backup dl automated is where?
You could try the powershell script from an earlier post
Nice! Worked fine for me.
So me being stupid.. I need to add hub ip and destination location to this section of the script right? I'm probably missing commas or..
param
[Parameter(Mandatory=$true)]
[string]$192.168.86.86,
[string]$C:\Temp,
[string]$BackupNamePrefix = "hubitat_backup_",
[switch]$WhatIf
You don't need to modify the script at all. Just pass your hub's IP and backup destination as parameters. I chose to put the script into the same directory as my backup destination to keep it simple. I then scheduled a task to run "Powershell" periodically with arguments and startup directory.
.\Hubitat-Configuration-Backup.ps1 -HubHostname 192.168.1.20 -BackupDestination .\
Like @HAL9000 mentioned you don't need to change the script. You just need to add your hub's IP address and destination to the argument in task scheduler.
Here's what I use for the argument:
.\Hubitat-Configuration-Backup.ps1 -HubHostname 192.168.86.25 -BackupDestination c:\hubitat\backups
I created a directory for the script and a sub-directory for the backups. The reason for the sub-directory is I have another scheduled task that cleans out the files that are older than 30 days.
Here's the argument I'm using for deleting the old files.
/p "C:\hubitat\backup /s /d -30 /c "cmd /c del /q @file"
