From memory.. the basics are: Curl with Authentication that pipes (saves) the cookie/token into a file. Then using your script, add a switch to read from the cookie/token file.
Ok, I got the 2 files and did a Frankenstein
#!/bin/bash
he_login=hubitat_login
he_passwd=hubitat_password
he_ipaddr=hubitat_ip_address
cookiefile=`/bin/mktemp`
curl -k -c $cookiefile -d username=$he_login -d password=$he_passwd https://$he_ipaddr/login
curl -k -sb $cookiefile -X POST https://$he_ipaddr/hub/reboot
#!/bin/bash
# Script to download hubitat backup
cd [DIRECTORY_OF_YOUR_BACKUPS]
ls -1tr | head -n -3 | xargs -d '\n' rm -f --
curl http://[HUBIPHERE]/hub/backup | grep data-fileName | grep download | sed 's/<td class=\"mdl-data-table__cell--non-numeric\"><a class=\"download mdl-button mdl-js-button mdl-button--raised mdl-js-ripple-effect\" href=\"#\" data-fileName=\"/\ /' | sed 's/\">Download<\/a><\/td>/\ /' | sed 's/ //g' | tail -1 | xargs -I @ curl -o @ http://[HUBIPHERE]/hub/backupDB?fileName=@
The Frankenstein:
#!/bin/bash
curl -k -sb $cookiefile -X POST https://$he_ipaddr/hub/backup | grep data-fileName | grep download | sed 's/<td class=\"mdl-data-table__cell--non-numeric\"><a class=\"download mdl-button mdl-js-button mdl-button--raised mdl-js-ripple-effect\" href=\"#\" data-fileName=\"/\ /' | sed 's/\">Download<\/a><\/td>/\ /' | sed 's/ //g' | tail -1 | xargs -I @ curl -o @ http://$he_ipaddr/hub/backupDB?fileName=@
Can anyone check if this is correct? I have no clue on this, actually I'm using crontab -e and I don't see the timing in the scrip, probably I can use something else, but I have no clue.
Thanks @dan.t & @csteele and @aaiyar & @ryan780 for the scrips
I am trying to do the same thing you are. Your Frankenstein doesn't seem to work for me, but I was wondering if you got any feedback as it seems to be on the right track. I just don't have enough background to figure out why it doesn't work (for me).
I read that to use crontab the script must be in one line, there are multiple lines.
I'm exactly at the same position as you, problably I will have to go to a linux forum to check.
Turns out I wasn't patient enough to wait for a reply so I kept experimenting and got it working. Here is my version updated from yours, but working for me:
#!/bin/bash
backupdir='dir'
cookiefilename='cookiefile'
cookiefile=$backupdir$cookiefilename
curl -k -sb $cookiefile https://$he_ipaddr/hub/backup | grep data-fileName | grep download | sed 's/<td class="mdl-data-table__cell--non-numeric"><a class="download mdl-button mdl-js-button mdl-button--raised mdl-js-ripple-effect" href="#" data-fileName="/\ /' | sed 's/">Download</a></td>/\ /' | sed 's/ //g' | tail -1 | xargs -I @ curl -k -sb $cookiefile https://$he_ipaddr/hub//backupDB?fileName=@ -o $backupdir@
Here is the complete (I think) list of changes and the reasons:
- Removed "cd [DIRECTORY_OF_YOUR_BACKUPS]" because I put the directory into the commands themselves.
- Updated "cookiefile=`/bin/mktemp`" because the wrong single-quote was used.
- Added "backupdir='dir'" to avoid having to retype it repeatedly.
- Added "cookiefilename='cookiefile'" so I could combine it with the backupdir to leave cookiefile as is in later commands.
- Removed " -X POST " because this seemed to be returning a 405 error from the Hubitat.
- Replaced "xargs -I @ curl -o @ http://$he_ipaddr/hub/backupDB?fileName=@" with "xargs -I @ curl -k -sb $cookiefile https://$he_ipaddr/hub//backupDB?fileName=@ -o $backupdir@". I did this as the -k was needed to not run into error with the hubitats SSL certificate and is -sb $cookiefile was needed to use the cookie to prove login and finally added the directory to the output rather than depend on the cd that was removed.
Net-net, here is a version of my new version with actual (but made up details):
#!/bin/bash
he_login=foo
he_passwd=bar
he_ipaddr=192.168.0.2
backupdir='/mnt/backup'
cookiefilename='cookiefile.txt'
Finally, I am trying to decide if I want the backup to have the name that was on the HE (actual date data gathered) or if I want the time date I backed it up to my computer. To do the latter, I can change the last line of the script to:
curl -k -sb $cookiefile https://$he_ipaddr/hub/backup | grep data-fileName | grep download | sed 's/<td class="mdl-data-table__cell--non-numeric"><a class="download mdl-button mdl-js-button mdl-button--raised mdl-js-ripple-effect" href="#" data-fileName="/\ /' | sed 's/">Download</a></td>/\ /' | sed 's/ //g' | tail -1 | xargs -I @ curl -k -sb $cookiefile https://$he_ipaddr/hub//backupDB?fileName=@ -o $backupdir/MainHubitat_$(date +%Y-%m-%d-%H%M).lzf
Wow, great!
Stupid question, where you place this script? Using crontab? I'm in the very novice training.
Thanks!
Unfortunately your next question is beyond my knowledge. I am just planning to run this manually whenever I want to. The reason I want to do it via script is that I have 4 different HE in 2 different locations. Thus my plan is to expand the script to cover all 4, then run it before I go into each of them to make changes like updating firmware or updating key drivers etc.
Good Luck in finding a way to use crontab or other methods to trigger the script on the schedule that works for you.
Another stupid question, I'm getting this error
sed: -e expression #1, char 19: unknown option to `s'
Do you know why?
I have a simple one, replace your last command with the following:
curl -k -sb $cookiefile https://$he_ipaddr/hub/backup | grep download | awk -F"=" '{ print $5}' | awk -F'"' '{print $2}' | sed '/^$/d' | tail -1 | xargs -I @ curl -k -sb $cookiefile https://$he_ipaddr/hub//backupDB?fileName=@ -o $backupdir/MainHubitat_$(date +%Y-%m-%d-%H%M).lzf
Many thanks!, this worked and now I have the backup in my computer, finally!
This no longer works... I think hubitat "upgrades" have been made to attempt to monetize by forcing people to subscribe.
Can anyone verify that this doesn't work anymore.
Hubitat recently added optional subscription services, one of which includes the ability to save hub backups to the cloud.
This thread has been discussing local, LAN backups (previously the only kind of backup that existed).
It’s entirely possible something changed that makes some user scripts to retrieve backups from the hub over the LAN no longer work as written. I don’t actually use one at the moment, so im not sure.
But I don’t see why one would jump to the conclusion that they are surreptitiously trying to disable previously functional features in an effort to “force” users to sign up for new, optional, cloud-based services.
All while they’ve publicly stated repeatedly that they have no intention of removing access to features that previously existed, just adding on and improving new features for those users that want to pay for them.
Nonsense. Local backup still works. And will continue to work. Here are my backups from this morning:
-rw-r--r-- 1 root root 417952 Mar 27 04:45 HubitatM-20210327-0445.lzf
-rw-r--r-- 1 root root 564960 Mar 27 04:45 HubitatS-20210327-0445.lzf
I can verify that it continues to work as it always has!
Is not working for me either....
FWIW, this is the script that I have used for the last two years:
he_login="replace_with_your_login"
he_passwd="replace_with_your_password"
he_ipaddr="your.hubitat.ip.address"
backupdir=/mnt/backups/hubitat
backupfile=$backupdir/$(date +%Y%m%d-%H%M).lzf
find $backupdir/*.lzf -mtime +5 -exec rm {} \;
curl -k -sb $cookiefile https://$he_ipaddr/hub/backupDB?fileName=latest -o $backupfile
rm $cookiefile
Thank you so much for posting your script - that works for me whereas the above did not.
Sean
So no one has been forced to subscribe to the cloud backup service after all?
