I’m having issues with this sensor not reporting “contact” states at all.
It does report
Acceleration
Battery Level
Temperature
ThreeAxis
I was using it with ST without issue. Pairing with hubitat happened without a problem and it was identified and the driver has auto selected {smartsense multisensor v4).
Any idea what I can do to resolve this? I have 7 of them doing the same thing.
Can you try switching them to the smartsense multisensor (not the v4, one just above it) and see if it reports contact state?
Mine work fine using that one, we will look into why the v4 driver doesn’t report contact. I have several on my garage doors but they work in garage door mode (3 axis).
Are you referring to the really old original first gen ST Multi Sensors? The ones with the 2 x AAAA batteries? If so, how did you get it to pair at all? Mine are never discovered. I can add and remove them from my ST hub all day long, but Hubitat never discovers them.
Just changing the driver did nothing, HOWEVER, once I was using the non “v4” driver, hitting refresh a couple of times caused the “contact” state to become “live”. I then was able to return it to the “v4” driver and the “contact” state remained intact. I also opened and closed the contact a couple of times after the refresh before it started working.
I’m assuming this is some of kind of bug in driver, but maybe it has something to do the the latest update too?
Yes, that's the one with the AAAA batteries. To reset. Press and hold the white button until you see the LED then let go. Put the hub in pair mode and press the white button once.
Thanks for the quick reply. I've tried that numerous times, using that exact same procedure, with no luck. Maybe the new .698 hub firmware made a difference? I'll give it a try tomorrow. Again, thank you!
@Navat604 - I couldn’t wait until tomorrow… I gave it another try tonight and was able to finally get it paired. I had to change the Driver from “Smartsense Presence” to a “Smartsence Multi” and now the “Contact Sensor” portion is working.
I think the big difference this time was that I found an errant “Device” in my list of devices called “Device”. It must have been from a previous failed attempt to pair the sensor. I deleted that, and then it paired almost immediately.
Knowing you had done it meant I knew it could be done. Now we just have to get it reporting temperature and movement…
@Navat604 and @ogiewon did you successfully get the v1 AAAA multisensor working on Hubitat with acceleration reporting? I plan to more devices over this weekend and I have one of these on my garage door that would also need to come over. If so what driver are you using?
@ritchierich - unfortunately, no. I really am not a very good Zigbee/Z-Wave Driver expert. I am hoping someone with more driver writing skills will eventually come through with a solution.
Have you tried the new built-in driver for the
STSS-MULT-001 in the new hub 701 firmware?
You'll need to update to 701 and then if your device is already discovered as something else, go into the device settings and switch the driver to the new built-in driver.
@ritchierich - So, I took @rayzurbock's advice and tried the 701 firmware's 'SmartSense Multi v1' driver and it works! All features are now reporting successfully!
@mike.maxwell - the only issue I see with the 'SmartSense Multi v1' driver is that the 'temperature' attribute seems to disappear as shown below. It is present in the first picture, but goes missing in the second picture.
Temperature Attribute appears on Device Page immediately after a device update....
Tried for almost an hour this morning and I can no longer be able to discover the device in Hubitat. I have 4 of of this old aaaa sensors. I deleted the one that was paired before I upgraded to 701.
they need to be completely reset.
Delete the device in the deice list if it already exists…
then hold the internal button down on the device until the led goes off
enter device discovery on the hub
tap the device button once, it should then pair
the number of children a repeater will route for is determined by the repeater, not the platform.
Are you trying to pair this through a repeater, or near the hub?
