Getting setup. The times seem to be off when using the sunset and sunrise time picks. When I open the rule with ! and look at the times at the bottom is says EDT, but the time appears to be in GMT as it’s 4-5 hours off.
Go into location and double-check that your Lat/Long and Time Zone is correct
It is, it appears the unit sees the correct time, but it looks like it says EDT ( my time zone ) but the actual time is not my local time
Go to settings and click "Update Time from Browser Time"
Did that, as shown,
Lat and long of house is corrects as is the time zone.
I specify “off at sunrise” and it’s showing the event as scheduled for 02:05 (EDT) but it appears that the line should say 02:05 (GMT) or better yet 06:05 (EDT) which would be the correct sunrise times in GMT and EDT.
The sunset times are listed correctly.
Should look something like this is your Location settings
and you should see the correct local time just above the "Update Time from Browser Time" button when you click it in the Settings.
If all these are correct and there still isn't the right time showing in your rule, reboot the hub. If still not correct, you should contact support@hubitat.com and @bobbyD will get it sorted out for you.
I believe the 2:05am jobs are run every day to schedule your Sunrise and Sunset event triggers. Since sunrise and sunset change daily, the new trigger times have to be calculated every day.
@bravenel can probably clarify the best.
Yes, this is correct. However, I am in the process of getting rid of these 2:05 am scheduling tasks, and replacing them with "the correct way" of doing it. The hub throws location events for sunrise, sunset, sunriseTime and sunsetTime. Things to be scheduled at or after sunrise or sunset are very straight-forward, and just use those location events. Things to be scheduled before sunrise or sunset are trickier, and use the sunriseTime and sunsetTime events, plus some math, to schedule such events.
This change is already in place in Rule Machine, and Mode Manager. Coming to Simple Lighting soon.
Makes sense now. The SS / SR events are actually working on time. I’ve only been up and running a few days but they are now verified to work. I was just confused by the 2:05 event showing up.
That's one reason it's going away. Plus, it probably didn't work on the day you first installed it, at least not for sunset -- since it hadn't run at 2:05 am that day.
This has been changed in the new release: Hub Update 1.1.3
Now, instead of scheduling a job to schedule things at 2:05 AM each day, it uses the location events to trigger the correct timing for sunrise/sunset events, and offsets before or after sunrise/sunset.
Probably not an issue for new users, but for existing, I noted a pre-RM 2.5 rule still shows that 2:05am schedule time. Will this go away tomorrow at 2:05am or is it an artifact that simply going to remain for older rules?
This is not a RM 2.5 rule, just to be clear for others reading this post.
Old rules have the old scheduling code. New rules have the new scheduling code. Funny how that works.
It's one of the reasons we did the 2.5 shift upgrade, to not blow out of the water existing rules.
So we can remove old simple lighting rules and create new and they will use the new coding?
No need to remove old. All you have to do is open it and hit Done. Then you can see the scheduled jobs and subscriptions on the app detail page.
All of my sunrise based rules failed to run this morning after the upgrade last night. The upgrade didn’t automatically “fix” existing sunrise/set rules but old scheduler code didn’t work either, though that might have been intentional. In case anyone else has simple Lighting rules based on sunrise/set, solution is this:
I think you may have to open them and click done to get it to update and then they should work
Yes done that and all good. I was calling out the fact that this upgrade breaks existing simple lighting rules based on sunrise/set and action (steps you mention) is required after the upgrade. This wasn't called out in the release notes nor automatically fixed during the upgrade. I wanted to make sure that folks reading this thread with similar experiences are aware they are required to "fix" their existing rules.
Oh sorry, I must not have scrolled enough on my phone before I replied. Missed that you were pointing out the solution.
This is entirely unintentional. I will update the release notes to reflect this issue.
